"Frankenwagon" short and sweet.
azracer
Re:
Post by azracer » Mon Feb 01, 2016 7:50 pm
As our economies crumble, as unemployment goes over 20% it is going to get much worse. I had my LED light bar stolen a few months back. I replaced it but put JB weld over the nuts to help prevent it being done again. I now also lock my steering wheel too, as well as put a dark gray beach towel covering my dash to hide anything that might tempt them. It is getting really bad now. They sell your stuff on Craig's list and at swap meets.
Re:
Post by Colibri » Mon Feb 01, 2016 8:19 pm
Sorry to hear that lee, that should still be a hanging offense :angry:
Re: "Saggin wagon" short and sweet.
Post by 2wagons1driveway » Mon Feb 01, 2016 9:02 pm
Ya I am surprised it happened I live in a good well lit neighborhood!
Deffinately have to keep my good offroading stuff in the truck hidden well under the floor or inside the house.... Started working on ideas how to mount my jack. Pulled the wheels off and the swivel casters just have to make an aluminum base for it and some sort of quick mounts for it just can't decide what part of the bed I want to put it in. The opposite side of the swivel reel is looking good somewhere close to the tailgate but out of the way....
Also need to figure out a spare set up....
These decisions are haunting me! Lol
Sent from Canada
Re:
Post by nts007 » Mon Feb 01, 2016 9:38 pm
Sucks dude. Especially the Canadian tire money. That's the only currency we have that hasn't lost value
Post by 2wagons1driveway » Mon Feb 01, 2016 11:33 pm
nts007 wrote:Sucks dude. Especially the Canadian tire money. That's the only currency we have that hasn't lost value
fact
Sent from Canada
Mr.Smith
Re:
Post by Mr.Smith » Tue Feb 02, 2016 1:51 am
Faaaawwwk! That sucks...is it worth it insurance wise? Keep your head up Sir!
Post by 2wagons1driveway » Tue Feb 02, 2016 9:09 am
No totally not for the 120$ worth of stuff I won't bother!
Just have to order a new arb next time I'm getting stuff from four wheel parts I'm looking into t case index rings now so that will probably be at the same time
Sent from Canada
Re:
Post by nts007 » Tue Feb 02, 2016 11:32 am
I'm still not believing it could be tcase. While your on the highway and the vibration starts put your hand on the shift lever. And vary your speed into and out of that vibration area. If it is tcase you will feel it in that shift lever. It will be very obvious. You should feel almost no noticeable vibrations. If you are then something is shaking your tcase. If you feel a weird almost grinding feeling (and if you do you will know what I mean) then it could be chain. The bearings could feel perfectly fine and spin nice but they could still be going bad. Or your chain has stretched and the slack is causing problems. I don't think indexing will be your solution. Just more future long term issues with oiling internally. Great for a rock crawler mud truck but a daily driver. I would hesitate
azracer
Re: Re:
Post by azracer » Tue Feb 02, 2016 3:29 pm
nts007 wrote:I'm still not believing it could be tcase. While your on the highway and the vibration starts put your hand on the shift lever. And vary your speed into and out of that vibration area. If it is tcase you will feel it in that shift lever. It will be very obvious. You should feel almost no noticeable vibrations. If you are then something is shaking your tcase. If you feel a weird almost grinding feeling (and if you do you will know what I mean) then it could be chain. The bearings could feel perfectly fine and spin nice but they could still be going bad. Or your chain has stretched and the slack is causing problems. I don't think indexing will be your solution. Just more future long term issues with oiling internally. Great for a rock crawler mud truck but a daily driver. I would hesitate
I was told that on the 4th gen with the OEM drive line you can do one of two things either get a 3rd gen driveshaft and hope it works or get an index ring. There are simply no other options for the 4th gen. If it were me I would do the index ring to make my driveshaft live longer.
Post by 2wagons1driveway » Tue Feb 02, 2016 5:58 pm
^ this is my thoughts to. Everything else has been done and I don't want to go to a smaller driveshaft realistically... Plus I can always rebuild the t case afterwards if I require or get a dropped version t case and further mod the cross member if I need to.
Sent from Canada
Post by 2wagons1driveway » Tue Feb 02, 2016 6:00 pm
I was thinking that also with the oiling but it has an internal pump so as long as the pump still stays lubricated should be fine. I an always overfill it a few ml also as much as people hate that I don't think it will cause an issue unless I take it overboard
Sent from Canada
Re:
Post by Colibri » Tue Feb 02, 2016 6:11 pm
The pick up tube for the oil pump is on the low side of the case once it's been clocked down, I can't see you having oiling problems from an index ring install.
Post by 2wagons1driveway » Tue Feb 02, 2016 10:04 pm
Such good info thanks Tim! ^^^ I really can't see any down sides to it being lower I hate the angle on it it clearly isn't happy
Sent from Canada
Re:
Post by nts007 » Tue Feb 02, 2016 11:58 pm
Yep the oil pickup is on the low driver side. You can see the line in the back half of the tcase. But here u can see the inside. You don't have a tcase skid or won't after you index it. I can't remember if u tossed it yet. Should make some protection for it. And maybe make a brace. Or you will end up with a stripped tranny output if the bolts holding the case to the tranny let lose. Ask me how I know
Post by 2wagons1driveway » Wed Feb 03, 2016 6:58 pm
Lol if they haven't broke yet they might not ever break lol I'm sure it will
Be fine lots of guys use them On daily driver trucks and if that had that bad of a rep I'm
Sure we'd hear about it ! But hey good news picked up some new stuff at the boarder today!
Sent from Canada
Re:
Post by Colibri » Wed Feb 03, 2016 8:20 pm
Oh shit!!!! Is that a long travel leaf pack I see? Nice man, any word on your rear shocks yet?
Post by 2wagons1driveway » Wed Feb 03, 2016 9:55 pm
No word yet but fronts
are in house!
3.5's are no joke... Lol towers look damn pretty as well
the Thuren fab swag is dope! Lol beer cozy makes my year
Sent from Canada
Re:
Post by nts007 » Wed Feb 03, 2016 10:02 pm
DAMN!!!!! What are you gonna feed those things!!!!!
Stickman
Post by Stickman » Wed Feb 03, 2016 10:19 pm
I don't know if anyone with an insanely lifted heavy rig like yours has ever ran an indexed t case and jumped it like you do. I'd definitely be keeping and eye on it.
Post by 2wagons1driveway » Wed Feb 03, 2016 10:38 pm
Lol I will trust me I'm under the thing three times a week inspecting
Sent from Canada
Black Pearl
Re:
Post by Black Pearl » Wed Feb 03, 2016 10:57 pm
Thought that was an anaconda she was wrestling!!!!!!
That is so rad!
Can not wait for instal and updates.
These trucks are very cool and have so much potential.
:rockon:
Post by 2wagons1driveway » Wed Feb 03, 2016 11:00 pm
Hells ya! I will probably notching my lower coil buckets on the axle out alittle so they won't ever have the chance to bang an end cap on full compression no matter what the articulation or speed of compression. Looks like they forgot to put stud rings in the box so I may have to re use Carli stud rings or have don and Aaron send me some up! So stoked to see the rears....
Sent from Canada
Post by 2wagons1driveway » Wed Feb 03, 2016 11:01 pm
And I can't wait to see some droop out of these leafs! The 3" ones are capable of 19" of travel so I'm hoping these will pull 18" with no shocks and 16" with new shocks!
Sent from Canada
Re:
Post by nts007 » Fri Feb 05, 2016 7:32 am
When u gonna have them swapped out. All this anticipation is killing me here lol. Besides. When you start jumping again I wanna see what breaks next!
Post by 2wagons1driveway » Fri Feb 05, 2016 9:02 am
Lol when I get back from
Ontario springs are first thing on my list so two three weeks.
Sent from Canada
