Boogie wagon take 2
Re: Boogie wagon take 2
Post by Will » Mon Dec 28, 2015 7:01 pm
While you're there, what color is the main wire that powers the clearance/cab lights? I want to put them on a separate switch.
Post by 2wagons1driveway » Mon Dec 28, 2015 10:05 pm
Buddy that's mint just keep her like that no interior!
Sent from Canada
Post by Colibri » Wed Dec 30, 2015 7:51 pm
I'll check it out and let you know will!
Man, I thought long and hard about leaving it stripped and caging it now lee lol. I'm putting the interior back in though. Sadly this is still the most comfortable and sensible vehicle I own currently so I'll keep it a nice daily driver. If I want stripped and caged I have the jeep or the 86 lol
Post by Will » Wed Dec 30, 2015 8:45 pm
Lol
Post by 2wagons1driveway » Wed Dec 30, 2015 9:39 pm
Lol just don't get to crazy! "Pre run" everything like you've been doing before giving her shit lol
Sent from Canada
Post by Colibri » Tue Jan 12, 2016 6:48 pm
Been busy with insulating the interior, just about have the floor done, then hitting the back of the cab, roof, and doors. I went with raam mat as a base layer then I'll be laying down 1/8" ensolite foam before the carpet goes back in.
Gps and radio have been delivered! I'll lay out location and run wires once I'm done with the sound deadening.
Will-the cab lights on mine only have 2 wires running to them from up the passenger side a pillar. White and black.
Not sure if that's the same from year to year.
Hope the tin foil will stop the voices
Anti getting lost device
External antenna for when mounting the gps without clear view of sky
Reach out and touch someone
Post by Will » Tue Jan 12, 2016 6:53 pm
10-4, thanks for the info. Looking good on your insulation.
gun45boat
Post by gun45boat » Tue Jan 12, 2016 8:03 pm
Damn nice interior work... Stupid flex on that Heep.. Awesome..
Post by Colibri » Wed Jan 13, 2016 9:41 pm
Thanks fellas :cheers:
Finished first layer on the back wall and ensolite foam on the floor. Put the carpet back in today! Tomorrow finishing the back wall and underseat area then Friday I'm running wires for gps and radio and lines for fire system!
Post by 2wagons1driveway » Wed Jan 13, 2016 10:31 pm
So excited the carpets back in it!!!! Lol that's awsome
Sent from Canada
Post by Colibri » Tue Jan 19, 2016 11:19 pm
Pull cables for fire system routed - check
Antenna cable routed from center of roof to under drivers seat - check
Gps power wire and antenna wire routed up through dash - check
Drilling the hole through the roof tomorrow then mounting antenna base and reassembling the full interior. Going with a blendmount above the rear view for the ham head unit and gps mounting in the center console. Have to fab up a bracket to hold the fire system cables soon as well.
azracer
Post by azracer » Wed Jan 20, 2016 12:44 am
Just WOW! I want to do this too!
Mule
Post by Mule » Wed Jan 20, 2016 1:23 pm
Damn. Nice job.
Post by 2wagons1driveway » Wed Jan 20, 2016 4:36 pm
Because #racetruck :)
Sent from Canada
Post by Colibri » Wed Jan 20, 2016 6:56 pm
Haha thanks guys! Man what a day. Drilled the roof for the NMO mount and pulled the antenna cable out to feed it down through the roof. Got the cable re-routed and foamed the roof. Headliner is back in along with most of the interior!
3/4" skylight
NMO base in position
Fully installed!
Passed the leak test!!
Post by Colibri » Wed Jan 20, 2016 7:04 pm
Used to have a full bench in the back, but no longer!! Doing split bench and fold flat floor! Thank you eBay lol. The cab is fully insulated now and the interior is all back except where I still have wires to run.
Antenna cable jacketed and run
Ensolite foam on roof
Testing fit and function of 60 side bench
To access fire system
Cargo floor deployed!
Post by nts007 » Wed Jan 20, 2016 9:19 pm
I honestly did not know the back seat came any other way then the split. I've never seen a full bench. Except in the 2nd gens. Let me know how much of a difference the added insulation is for sound and road noise. I've been debating doing it for awhile. Although I doubt I could do as nice a job as you have
Post by Colibri » Wed Jan 20, 2016 9:32 pm
Yeah my truck is a base model and pretty option free lol. I'm lucky it had power windows. I'm not sure the juice is worth the squeeze for all this sound deadening stuff, but I'll let you guys know how it works for sure. It was a lot of work doing it this way, probably easier to spray something like lizard skin
Post by Will » Thu Jan 21, 2016 11:47 am
I'm sure it will insulate better. I'd be interested in doing my roof at least. Gets hot in summer
2011RPW
Post by 2011RPW » Fri Jan 22, 2016 12:09 pm
I've also been interested in matting/sound deadening mine. I haven't looked too far into it though. I remember when Dynamat was the shit, but that's been years ago. Why did you go with Raam?
2011
Post by Colibri » Fri Jan 22, 2016 5:07 pm
Raam has a better price point for the foil backed butyl rubber and it's essentially the same thickness as dynamat extreme. Combined with the ensolite foam enough to do the entire truck was about 700 shipped, dynamat was almost 400 more for the same coverage even going through Amazon. Sound deadener showdown was about 900 but if audio quality is the motivating factor they're probably the best choice. It just seemed like way too much work to glue all that mass loaded vinyl. So cost ease of install and using both a sound dampener and absorber/decoupler was why I went with raam.
Started the doors today, holy shit what a pain! Was able to do both inside the door and the interior panel. It shuts with a deeper tone and thumping on the door it sounds solid compared to oem. There are 4 screws and one bolt on the door handle then pull upward to remove the panel. The extra width of the insulation made it a tight squeeze to get back on.
Door panel and plastic liner
Naked door!
Foil first, close as many holes as possible!
Foam layer
Oem liner back in place
Post by Colibri » Mon Jan 25, 2016 8:55 pm
Got the control head for the radio mounted today, I went with a blendmount and put it above the rear view mirror. Also finally figured out how I want to run the air lines for the air toggle switches and ordered the push to connect fittings and 1/4" dot air line today.
2011RPW
Post by 2011RPW » Mon Jan 25, 2016 9:15 pm
Damn that's clean. Looks great. I would've never thought to put it up there.
2011
gun45boat
Post by gun45boat » Sun Jan 31, 2016 4:51 pm
damn man.... THat thing is going to be quieter than a Bentley driving down the road (internal noise or lack there of) NICE!!!!!
Post by 2wagons1driveway » Sun Jan 31, 2016 8:51 pm
So awsome with the radio!!!!! Love it!!!
Sent from Canada
