"Frankenwagon" short and sweet.
Re: "Saggin wagon" short and sweet.
Post by 2wagons1driveway » Tue Jan 12, 2016 9:58 pm
Whoot whoot! Some comparisons for sizes
this is a mini can anyways according to Aaron lol
and I found a spot I'm happy with to mount the air compressor! Obviously alittle higher than where it's sitting but on that pillar rf of the engine bay. Should leave me enough room for snorkels and stuff too if I go that route one day ;)
Sent from Canada
Re:
Post by nts007 » Tue Jan 12, 2016 10:21 pm
You're not fooling anyone using those new calorie wise mini Pepsi cans there. Sweet though dude. I think you need more truck for those things. Maybe a diesel swap next
Post by 2wagons1driveway » Wed Jan 13, 2016 12:15 am
Lol no I think a fresh hemi and a nice charger
Sent from Canada
Re:
Post by nts007 » Wed Jan 13, 2016 1:48 am
Lol so you're not challenging the mini soda can debate??? Look at pro charger for belt driven. They have good stuff with good warranty.
But let's face it. A dynoed 521hp and 1137ft-lbs doesn't get your goat well then you arnt getting my engine lol. Shh I should t post that in a pw forum.
Post by 2wagons1driveway » Wed Jan 13, 2016 9:07 am
Haha for the stuff I do I like to rev stuff up. ..... Above 3000rpm.... Lol
Sent from Canada
Re:
Post by nts007 » Wed Jan 13, 2016 9:10 am
Yea I know. That's why I rev to 4. And besides. My turbo revs freely to 80k.....lol. Gonna be sweet having those shocks. You may be sand bagging when your just driving around just to make them work
Post by 2wagons1driveway » Wed Jan 13, 2016 3:36 pm
Lol I always fine ways to test suspension on the street
Sent from Canada
Re:
Post by nts007 » Wed Jan 13, 2016 4:37 pm
2wagons1driveway wrote:Lol I always fine ways to test suspension on the street
Sent from Canada
Running over little cars and Ford trucks isn't considered off roading. Just an FYI. You need to find a new name for it
Post by 2wagons1driveway » Wed Jan 13, 2016 10:32 pm
Lol I think that's called berta rage.
Sent from Canada
Re:
Post by nts007 » Thu Jan 14, 2016 12:04 am
Ahahahahahahahaha
Re:
Post by Will » Thu Jan 14, 2016 7:10 am
Hey 2wags... you might want to do this now also. :lol:
http://www.cjcoffroad.com/Synergy-Dodge ... 569-01.htm
Post by 2wagons1driveway » Thu Jan 14, 2016 10:26 am
Will wrote:Hey 2wags... you might want to do this now also. :lol:
those are already in my tool
Box lol just haven't had time to burn them in along with more stainless brake lines for the rear and emf joint tools to tighten my track bar and a new Chinese baja designs amber light bar and 5 gallon air tank and 50' air line reel lol. Time in the shop is hard to find!
Sent from Canada
Re:
Post by Will » Thu Jan 14, 2016 10:37 am
NICE
Post by 2wagons1driveway » Sun Jan 17, 2016 10:21 pm
got the arb in put a desiccant moisture filter on it also. As I'm told exterior compressors are very bad for filling the arb locker with moisture so hopefully this will help. And they were like 1$ I will keep an eye on it and make sure it doesn't plug up.
Sent from Canada
Post by 2wagons1driveway » Sun Jan 17, 2016 10:26 pm
Just have to plumb the locker and figure out a quick connect area for the soft air locker line above the axle that way if one tears I can replace it quickly and easily! I must say wiring the compressor looked daunting with all the switch plugs and what not but it was way easier then I expected. There's really only three connections at the battery and the IGN. And the dash illumination and everything works nicely!
Also have to rig up my air line from that shut off valve pictured to the 5 gallon tank I have but first I have to chop out the factory spare tire mount...
Sent from Canada
Re:
Post by nts007 » Sun Jan 17, 2016 10:34 pm
Nice dude. Stop by one of the semi big rig shops. They have all the quick connects you need.
Post by 2wagons1driveway » Sun Jan 17, 2016 11:03 pm
The air line that comes from arb is actually unique to them it appears so all the fittings and shit all have to be 5mm.... I thought about big rig brake system line but couldn't find the right sizes
Colibri is sending me some extra stuff and the quick connects are like 20$ at 4 wheel parts
Sent from Canada
Re:
Post by nts007 » Sun Jan 17, 2016 11:11 pm
Sweet. That works. I've found all sorts of goodies at the rig shops.
Post by 2wagons1driveway » Sun Jan 17, 2016 11:19 pm
Totally! I was going to do synflex down the whol frame then just a small union/ quick connect for a blue line section to the axle this way like I said it's easily replaceable with a spare kept in the truck in case ice or something takes it out. I'm going to route it with a hard protective outter layer and mimic the brake lines and and sensors so this way it has a smooth path to follow and less likely to be seperated and cut away.
Sent from Canada
Black Pearl
Re:
Post by Black Pearl » Sun Jan 17, 2016 11:45 pm
I just trip on how much you guys know about this stuff.
At what point do you consider the c-gusset?
And those 3.5 kings look are very heavy duty. :rockon:
Just put my order in for some king 2.5s. Think I have shock envy!
Post by 2wagons1driveway » Mon Jan 18, 2016 12:13 am
Black Pearl wrote:I just trip on how much you guys know about this stuff.
I learn from lots of peoples mistakes and my own lol!
You should consider a truss (c gussets are a secondary truss... Apperantly there's no evidence they are actually required...) if/ when your trucks wheels ever leave the ground even accidently or at slow speeds. If you want to get the most out of those kings look into a Thuren truss. It's a big step but those 2.5's will literally out run your chassis quickly. Everything will feel so smooth the faster you go untill bam! Shit let's go lol
C gussets I think are just to ease some peoples minds
If the main truss is installed properly the knuckles shouldn't ever move-according to don Thuren. The few knuckles he's seen move was actually a truss bent!
https://www.thurenfabrication.com/produ ... s-kit.html
I would be pairing those kings with boogie bumps also! https://www.thurenfabrication.com/produ ... stops.html
Then you've got a six seater whoop eater that rides Tities on the street :)
Sent from Canada
Black Pearl
Re:
Post by Black Pearl » Mon Jan 18, 2016 8:31 am
Already have the Boogies on order, along with all the trimmings, Coils,arms, Shackles, Trac bar.
The info I have obtained on this site has defiantly helped me decided to try to do it proper the first time. Not cheap. But worth the cash if it is used and taken care of.
Thanks for the tips :)
Now I need to get better at posting pics so I can get off the side lines and get in the game with some build pics.
Post by 2wagons1driveway » Mon Jan 18, 2016 5:34 pm
Black Pearl wrote:Already have the Boogies on order, along with all the trimmings, Coils,arms, Shackles, Trac bar.
get the tapatalk app for your phone makes it easy to post pictures and what not!
Sent from Canada
Post by 2wagons1driveway » Thu Jan 21, 2016 12:23 am
thanks Tim!!!!!!
(Colibri)
Ballistic fab cover for the new rear axle super stout and well made! Extra capacity as well keep them 5.13's happy.
I will install shortly after my 500 mile break in fluid is done
Sent from Canada
Post by 2wagons1driveway » Sat Jan 23, 2016 8:55 pm
china bar
Sent from Canada
