Wheel hop, axle wrap...
Re: Wheel hop, axle wrap...
Post by olyelr » Sat Jan 09, 2016 12:55 pm
True. That shock isnt gonna help much for hop i wouldnt think. Looks like it was addded to combat wrap. But how the hell can the axle wrap?!
Post by Will » Sat Jan 09, 2016 7:50 pm
Quit talking about it and video it, its not wrap, it can't be, my front has done what you describe and there's no way it will wrap with upper and lower control arms with solid joints, not factory control arms here. It's hopping which is more than likely tire related.
Post by olyelr » Sat Jan 09, 2016 8:37 pm
Will wrote:Quit talking about it and video it, its not wrap, it can't be, my front has done what you describe and there's no way it will wrap with upper and lower control arms with solid joints, not factory control arms here. It's hopping which is more than likely tire related.
... And the nice soft, plush, flexy suspension. But yes, low air pressure would definitely help the matter i would believe.
But yes, for the love of God somebody gopro that sheeeeiit!
Post by adeluca73 » Sat Jan 09, 2016 9:31 pm
I'm designing up a mount in Solidworks , then will get a GoPro, & mount it, first big snowfall here, I'll have at it w/ normal 60-65PSi & then progressively air down in 10PSI increments
Post by nts007 » Sat Jan 09, 2016 9:35 pm
2wag is the one who go pros everything lol.
Simply put we have a known issue across all generations of trucks. We all agree that it's a pain and can be damaging. Dodge redesigned the rear end to improve ride and claimed load capacity. Some of us think that the KISS system of leaves is still superior to the new design even though there are other ways to design the rear end using multi link that can be tailored to each or our usages. We work with what we got right.
Post by 2wagons1driveway » Sat Jan 09, 2016 11:55 pm
I don't gopro anything.... http://youtu.be/S89FRaiyY2c ever... http://youtu.be/Rlktf__Bnh4
Sent from Canada
Post by TwinStick » Sun Jan 10, 2016 12:05 pm
:lol: In my humble, non-college educated mind, one brings on the other. Yes, in my mind, it IS that simple. When the axle wraps, it can only go so far & then it hops back with a loud bang. It repeats this (sometimes very fast) until something breaks, you back off the throttle or tires start spinning faster.
:lol: That's my story & I'm sticking with it !!! :lol:
Post by 2wagons1driveway » Sun Jan 10, 2016 2:48 pm
TwinStick wrote::lol: In my humble, non-college educated mind, one brings on the other. Yes, in my mind, it IS that simple. When the axle wraps, it can only go so far & then it hops back with a loud bang. It repeats this (sometimes very fast) until something breaks, you back off the throttle or tires start spinning faster.
lol I agree with this they seem to be paired together. The twist of the axle causes a hop after it springs back and loses traction plus dodge bushings are never that strong as it is five link or not there's always a ton of play to keep noise levels down and Squeeking to a minimum .
You can see in those videos how much that axle twists on accel it's quite astonishing to see for the first time.
Sent from Canada
Post by Will » Wed Jan 13, 2016 1:52 pm
The new Kings have planted mine now, no more wrapping/hopping in soft sand. Mine was apparently due to worn out shocks and no axle control.... just saying...
Post by adeluca73 » Wed Jan 13, 2016 4:53 pm
Will wrote:The new Kings have planted mine now, no more wrapping/hopping in soft sand. Mine was apparently due to worn out shocks and no axle control.... just saying...
ah--the world of engineering is at peace again.... :lol:
Post by adeluca73 » Wed Jan 13, 2016 4:56 pm
Sent from Canada
Yes the motions are similar, and wrap, if violent, coupled with undulating road conditions, will result in vertical movement of the axle in the air, which can be interpreted as hop. However, the kinematics of the two, the instigating mechanical conditions, and the necessitating dynamics resulting in the on-set of both phenomenon, are distinct.
Post by FirerescuePW » Wed Jan 13, 2016 5:02 pm
Indubitably
Post by olyelr » Thu Jan 14, 2016 12:51 pm
Hows it coming?!
Post by Will » Thu Jan 14, 2016 1:02 pm
:lol: When in doubt, stick a King on it and hit the gas :lol:
Post by adeluca73 » Fri Jan 15, 2016 10:33 am
Hows it coming?!
Slow---it's near graduation time, and I've got 3 Master's students I'm trying to graduate, evaluate their thesis research, and still do my other day job, so nights are busy reviewing and editing thesis documents...but I've taken a few measurements under the frame that should work for a mount, then I need to get a drawing of the go-pro so I can design a mount for around it...or I may just be lazy and buy an off-the-shelf mount, and figure a way to bullet proof it to deal with driving under the truck.
Post by coder » Fri Jan 15, 2016 1:47 pm
With my King 2.5' shocks and airing down my tires to about 20 psi. I almost never get any wheel hop, even in deep snow, sand, mud, etc.
Post by 2wagons1driveway » Fri Jan 15, 2016 3:05 pm
Well see how bad the wrap from my atlas LT leafs will be....
Sent from Canada
Post by Colibri » Fri Jan 15, 2016 3:51 pm
I see traction bars in your future lol
Post by Will » Fri Jan 15, 2016 3:58 pm
Will the new leafs go to the axle without spacers? That would help reduce some leverage.
SheepdogOutdoorsman
Post by SheepdogOutdoorsman » Sat Jan 16, 2016 10:10 am
FirerescuePW wrote:Indubitably
Post by 2wagons1driveway » Mon Jan 18, 2016 7:09 pm
Will wrote:Will the new leafs go to the axle without spacers? That would help reduce some leverage.
apperantly their pretty bad on the diesels for wrapping/ hopping but a lot of those guys seen to not know about airing down??? Strangely enough..... They say it makes traction higher so axle hop worse?
Doesn't look like there's any spacers at all just leafs!
Sent from Canada
Post by Will » Mon Jan 18, 2016 7:38 pm
Send them to me, I'll let you know. Haha
Post by nts007 » Mon Jan 18, 2016 8:04 pm
Will wrote:Send them to me, I'll let you know. Haha
Hey those are mine damit!!
azracer
Post by azracer » Mon Jan 18, 2016 8:31 pm
Neener neener I have mine already and someone else broke them in for me so they haven't settled any since I put them on. I love them they are about what a PW offers but much more travel and little or no axle wrap even when running bypass shocks. I love mine!!!!!!!!!!!!!!!!!!
Post by 2wagons1driveway » Tue Jan 19, 2016 2:27 pm
azracer wrote:Neener neener I have mine already and someone else broke them in for me so they haven't settled an since I put them on. I love them they are about what a Pw offers but much more travel and little or no axle wrap even when running bypass shocks. I love mine!!!!!!!!!!!!!!!!!!
AZ did you have to drill out your forward mounting bolt to run them? I'm trying to figure out if they'll fit with my fourth gen with the bushings dom had in them
Sent from Canada
