5.13 R+P for 10.5"
loveracing1988
Re: 5.13 R+P for 10.5"
Post by loveracing1988 » Thu Nov 12, 2015 11:57 pm
2wagons1driveway wrote:Who has the info for the gear swap on here for the new 2014 wagon? Can't remember what the thread was called! Need some info on the new rear ends in the wagons the 13+ trucks. Is it an aam still? A 11.5 or an 11.8? I presume the locker is still same idea... Debating putting an 11.5 in my truck and swapping to 5.13's within the year but I really want to keep factory smart bar controller and I love the idea of the posi and the elocker in the rear. Can't find any aftermarket companies who make the same thing for the 11.5 dodges
Sent from Canada
Yes it is an 11.5 aam, the locker is of the same basic style as the 10.5.
Post by 2wagons1driveway » Fri Nov 13, 2015 12:05 am
Sent from Canada
this seems like easiest swap over then... Same style locker should
Use the same sensory system for locked and unlocked. Hmmmmm
Sent from Canada
Post by 2wagons1driveway » Fri Nov 13, 2015 12:15 am
Now for next questions will a 513 ring and pinion fit on a factory 13+ carrier? I know the 4.88's do from whoever did the swap last but 5.13's?
Sent from Canada
loveracing1988
Post by loveracing1988 » Fri Nov 13, 2015 11:13 am
2wagons1driveway wrote:Now for next questions will a 513 ring and pinion fit on a factory 13+ carrier? I know the 4.88's do from whoever did the swap last but 5.13's?
Sent from Canada
Anything above at least 4.10 should.
Post by 2wagons1driveway » Fri Nov 13, 2015 11:38 am
Perfect. Just have to find out if carriers are swappable now. From 14 carrier to an 11-12 housing.
Sent from Canada
Post by 2wagons1driveway » Fri Nov 13, 2015 2:20 pm
Just talked to nitro gears said we'd need 200 guys to commit to buying 5.13's and they would make them for the 10.5 lol :/
Doesn't sound that attainable lol
Also a 2014 carrier will not fit in the 2003-2012 11.5 aam. Totally different. Also the new 11.8 in the bigger radius arm trucks is the same rear gear design so nitro will be switching over the 11.5" aam gear sets to 11.8 aam gear sets which are compatible in both axles. However carrier will not swap over. Basically have to look Into modifying a 2013-2015 p.wagon axle housing to leaf spring status to make it work if you want a helical limited slip with a elocker like factory.
Or you run an arb open diff with air locker 11.5 aam
Also the front gears will fit factory carrier in the front he thinks no problem. Said because the gear carrier is a side to side adjust should have no issues running a spacer plate and chev 9.25 FRONT cut gears...
Also the rep at nitro said the 5.13 in a 10.5 he figured would be plenty strong for most of our needs. Says the problem axles are smaller crown gears and can begin to get very weak when running the higher ratios
But for example a chev 10.5 with 5.38's is plenty strong.
Sent from Canada
Post by Colibri » Fri Nov 13, 2015 5:08 pm
For the front I'm running Chevy gears with a spacer, but aam is now making 5.13's for the dodge carrier that don't need a spacer
Post by 2wagons1driveway » Fri Nov 13, 2015 5:15 pm
Well I'm probably going to copy your build then and start putting together a bullet proof 5.13 gears arb locked 11.5 probably with a truss too. Eff it why not lol
Sent from Canada
Post by Colibri » Fri Nov 13, 2015 8:24 pm
I somewhat regret not trussing the rear lol. Probably not really necessary but too much isn't enough sometimes
Post by 05PWrockcrawler » Sun Nov 15, 2015 12:14 pm
I need to see this truck offroad first before u do any more mods lol. You will have to re learn everything about your truck and how to drive it again. You changed everything lol.
Post by Colibri » Sun Nov 15, 2015 5:01 pm
Haha it's true, definitely gonna be a learning curve involved
Post by 2wagons1driveway » Mon Nov 16, 2015 12:14 pm
It's gunna be sick!!! Bypass shocks and the 5.13's
Plus selectable locker running full spool
Out back
How did you say it?
"Power slide city" lmao
Sent from Canada
Dodger
Post by Dodger » Thu Nov 19, 2015 11:18 pm
I would be interested. Maybe some would buy a spare set to help achieve the 200 sets needed to make the production run viable?
Post by 2wagons1driveway » Sat Jan 09, 2016 9:29 pm
11.5aam and 5.13's in
Sent from Canada
