"Frankenwagon" short and sweet.
Re: "Saggin wagon" short and sweet.
Post by 2wagons1driveway » Tue Dec 15, 2015 11:14 pm
I want to go to Moab pit! Well see works been good and busy and supplying me with as much as I want so I'm debating on it with a few others maybe!
Rear truss just needs to be massaged a bit more so the gaps aren't as big and I get more area to weld to on the tops! I just used some heat shrink tubes for now to close up my air locker actuator line until my compressor set up is good to go and I'm waiting on hub seals some
New u bolts and a solution for the rear driveshaft being a C you NEXT Tuesday a hair to long for the new diff. Also id like to slap some
New wheel speed sensors on there as I think the old one will be damage coming out and it will make install faster I plan on just tack welding the cable holder/ the brake line holder that goes around the diff breather "normally" as I relocated diff breather and just used 1/4" npt pipe adaptor and fitting to give me a new breather. Looking forward to having this thing together piece by piece she's coming along! I do believe for my truck and for tims trucks you don't actually have to correct for gear ratio changes as tims truck (09) references the speed of the vehicle off the tone wheel on the actual ring and pinion. Since that doesn't change when the ring and pinion changes it shouldn't matter. My truck uses it's speed signals from abs sensors on each wheel so since I am not changing my overall tire diameter/ ratio and just the diff ratio I don't think I will need changes to my ecu/ programming.
Sent from Canada
Post by 2wagons1driveway » Mon Dec 21, 2015 9:31 pm
air tank finally came in! It's taller
Then I expected but I may be able to make it work
In the spot I originally wanted where the spare used to go.
Sent from Canada
2011RPW
Post by 2011RPW » Tue Dec 22, 2015 10:18 am
5 gallon?
2011
Post by 2wagons1driveway » Tue Dec 22, 2015 10:31 pm
Yessir
Sent from Canada
Post by 2wagons1driveway » Thu Dec 24, 2015 7:52 pm
truss is on! .250" x2" tube. My welding is getting better.
Sent from Canada
Re:
Post by Colibri » Thu Dec 24, 2015 10:41 pm
That's looking really good man, poly has some cool clamps for running brake lines down tubing, could make it real easy to do your custom lines following the truss
Comes in several different sizes
Post by 2wagons1driveway » Thu Dec 24, 2015 10:58 pm
Oooo shit! thanks man!! That's a good idea. I was even thinking of just finding some stuff around the shop. I have lots of rubber grommets around the shop but shit those look smooth.
Sent from Canada
gun45boat
Re:
Post by gun45boat » Sun Dec 27, 2015 1:07 pm
Great Job!!!!!!!!!! I do not see that housing taking a "spin" anytime soon:):):):):) GREAT WORK
Post by 2wagons1driveway » Sun Dec 27, 2015 4:43 pm
gun45boat wrote:Great Job!!!!!!!!!! I do not see that housing taking a "spin" anytime soon:):):):):) GREAT WORK
let's hope not! Hopefully the welded tubes will help against any in expected impacts. A friend of a friend came over while I was just finishing up and said he'd really be interested to help
Me out by making some
Fish plates for the frame rails to strengthen them and also around coil
Bucket areas as well as help me build a new bed cage with a spare mount and some provision for an emergency jack my bed mounted tool storeage and possibly a new area for some sort of roof too tent I was thinking an easy base like this! Not sure if I want to hold off and jut but a sweet trailer with an rtt built into it. That way I can just dump it and truck on if I feel the urge! I just worry about having to back up in a tight trail with it on there....:/
Sent from Canada
Re:
Post by Will » Mon Dec 28, 2015 10:32 am
:cheers:
Post by 2wagons1driveway » Mon Jan 04, 2016 8:35 pm
cause I don't have enough on the go lol new led bar with some ambers
Sent from Canada
Post by 2wagons1driveway » Sat Jan 09, 2016 12:03 am
home stretch is in site finish tomorrow morning and work out the details in the afternoon.
Sent from Canada
Re:
Post by nts007 » Sat Jan 09, 2016 1:27 am
Your truck spends more time on that lift than on the road. According to all your pictures anyway lol. So many of her on the lift
Post by 2wagons1driveway » Sat Jan 09, 2016 9:40 am
nts007 wrote:Your truck spends more time on that lift than on the road. According to all your pictures anyway lol. So many of her on the lift
lol so true.... The hoist wagon
Sent from Canada
Post by 2wagons1driveway » Sat Jan 09, 2016 9:27 pm
new rear ends in and she's quiet and it sucks with no posi or locker yet so have to get on that ASAP! Also need new u bolts as I only got .half inch and I need 9/16" and a bit shorter! So air compressor wire up and new switches soon.
Sent from Canada
Re:
Post by nts007 » Sat Jan 09, 2016 9:36 pm
Look at that shiny new driveshaft
Post by 2wagons1driveway » Sat Jan 09, 2016 11:45 pm
nts007 wrote:Look at that shiny new driveshaft
polished and shit lol still the original with all the scraps and scratches
Sent from Canada
Re:
Post by nts007 » Sun Jan 10, 2016 12:31 pm
You aren't running a shorter driveshaft?? The PW shaft is too long. Or were u running the 11.5 already with the shorter shaft I can't remember....
Post by 2wagons1driveway » Sun Jan 10, 2016 2:47 pm
It's shorter they just polished it and cleaned it before they cut it.
looks like she means bussiness now!
Sent from Canada
Re:
Post by nts007 » Sun Jan 10, 2016 5:04 pm
I got yea. Looks good. When I can manage to get a second truck for work I might be takin a few pages from your book n goin all out. I'll stick with 4.56 gears though. For me it's similar ratio as your 5.13s. Now get some seat time and tell us how it is!!
Post by 2wagons1driveway » Tue Jan 12, 2016 2:54 pm
Front shocks just got to Oregon hopefully not to much longer on the rears
really excited to try the 3.5 IBP! Comp adjusters and finned resi look awsome :) super excited!
Sent from Canada
Re:
Post by Will » Tue Jan 12, 2016 3:23 pm
those are going to fill up the springs :rockon:
Re:
Post by nts007 » Tue Jan 12, 2016 4:13 pm
Filled with enough nitrogen he won't need springs with the size of those bad boys.
azracer
Re:
Post by azracer » Tue Jan 12, 2016 5:14 pm
WOW! :jawdrop:
Re:
Post by Colibri » Tue Jan 12, 2016 6:38 pm
That's sofa king cool man! :rockon:
