damaged wheels
jsemm
damaged wheels
Post by jsemm » Sat Nov 28, 2015 1:55 pm
I recently got stuck and the mud was up to the frame. I had to winch out and the mud was so deep I needed to spin the tires while winching. I scratched one wheel up very bad from spinning in the rocks. Its a 2013 truck. Is there any way to repair the wheel.
RamGentry
Re: damaged wheels
Post by RamGentry » Sat Nov 28, 2015 2:13 pm
Hard to tell wihtout seeing any pics of the scratches. Sometimes polish is enough to lessen or clean up hairline scratches.
Re: damaged wheels
Post by Will » Sat Nov 28, 2015 3:47 pm
I got is some bad mud with rocks and did the same but lived with it. The tires balance so... Haha
jsemm
Re: damaged wheels
Post by jsemm » Sat Nov 28, 2015 6:01 pm
Ya its pretty much ruined it took all the finish off and its only on one wheel. Some are very deep.
Re: damaged wheels
Post by Low_Sky » Sat Nov 28, 2015 6:28 pm
You can repair scratches to forged aluminum wheels, but you'll go through the clear coat to do it and it's a lot of work. Might be easier to just live with it. It is a Power Wagon, and you earned those scratches doing Power Wagon stuff, after all.
Re: damaged wheels
Post by Will » Sat Nov 28, 2015 7:19 pm
Just spray it with Plasti Dip, that's what I did :)
Re: damaged wheels
Post by FirerescuePW » Sat Nov 28, 2015 8:31 pm
Buy one more and use the damaged one for your spare?
Re: damaged wheels
Post by olyelr » Sat Nov 28, 2015 8:55 pm
FirerescuePW wrote:Buy one more and use the damaged one for your spare?
That's what I would do. You will spend dang near as much repairing it as you would to just buy another used one.
Stickman
Re: damaged wheels
Post by Stickman » Sat Nov 28, 2015 10:41 pm
I'm with Will, plati - dip it if you don't want to live with it and don't want to drop the coin on an extra.
Re: damaged wheels
Post by coder » Mon Nov 30, 2015 12:15 pm
Google for a wheel repair shop in your area they can usually fix most types of damage including sand, polish and new clear coat for a lot less than a new wheel.
Mr.Smith
Re: damaged wheels
Post by Mr.Smith » Mon Nov 30, 2015 12:20 pm
That sucks, let's see the damage...
jsemm
Re: damaged wheels
Post by jsemm » Mon Nov 30, 2015 6:57 pm
I ended up sanding the rim with 1500 grit and polishing it with a drill, Looks a lot better except for a few deep scratches. It really brought the shine back.
Re: damaged wheels
Post by Will » Mon Nov 30, 2015 7:22 pm
Must not have been that bad then, mine is missing chunks on the leading edge. Haha
jsemm
Re: damaged wheels
Post by jsemm » Mon Dec 07, 2015 12:24 pm
Looks way better than it did before sanding and polishing but it still has some deep scratches. Im going to wet sand it again and polish it. I think I can make it a little better. I use the truck for what it was intended for. Stuff like this is going to happen.
Re: damaged wheels
Post by Will » Mon Dec 07, 2015 12:33 pm
oh yes, that's about what mine looked like.
Re: damaged wheels
Post by Bill2014 » Mon Dec 07, 2015 12:45 pm
The gouges add character - display it proudly :cheers:
95% of people with pickup trucks don't even take them off-road. :lol:
Re: damaged wheels
Post by Ducky's Dad » Mon Dec 07, 2015 10:59 pm
Years ago I damaged a Jeep wheel so badly that it was not safe to drive on. Sent it to a professional wheel repair shop and it came back good as new, not too expensive.
I once needed a complete set of aluminum wheels for a Jag I was doing, and all I could find was a refinished set. Bought them long distance with return option, and they were great. A competent wheel shop can work wonders.
jsemm
Re: damaged wheels
Post by jsemm » Tue Dec 08, 2015 7:15 pm
I don't have a wheel shop close. Im going to wet sand again, polish, then wax. I think I can get it a little better than it is now. I wish I took a before picture because the wheel looked horrible. It was completely dull.
MSCH2112
Re: damaged wheels
Post by MSCH2112 » Tue Dec 08, 2015 7:41 pm
hey, that looks like my wheel!
i've learned if your going to offroad the PW, ya gotta live with the scratches.
Mike
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Re: damaged wheels
Post by adeluca73 » Sat Dec 12, 2015 12:56 am
An orbital polisher with mild grit wet abrasive polish will greatly help with that
