SheepdogOutdoorsman wrote:Payload capacity isn't solely dependent on the suspension. The total gross vehicle weight listed on your driver's door takes into account a myriad of other factors such as braking distance, tires, tire air pressure, mass of the vehicle during an impact, and other such factors. There are many safety factors that go into the calculation. The 2014+ PW's have a lighter payload than the 2005-2013 PW's mainly because of the rear coil suspension. My 2013 PW has a payload capacity of 1900 lbs.
Well, most of that is just completely untrue.... I don't know how else to call BS. The only thing you are even close on is tires, they have to account for the load capacity of the tires. The tires fitted stock to the PW have nearly 6400 lbs capacity, they are NOT a limiting factor. If it is the coil springs can you explain to me how the standard 2500 series truck, which is nearly identical to the PW version, can carry ~3200 lbs? That model uses coil springs and is rated to carry over double what a PW is. Yet the PW has the same frame, axles, suspension layout, brakes, etc, etc.
The PW uses softer rear springs for off road use. It also has a raised suspension. These two things are surely the cause for the 8510 GVWR instead of the 10,000 of the standard 2500. They were both designed with the factors you mentioned in mind but, those do not constitute any actual differences between models that would account for the payload differences.
Get some airbags, as mentioned right off.
