2010 Improvements
Re: 2010 Improvements
I feel it rides better disengaged for the most part. I did haul a tractor yesterday and could feel more sway so I locked it and that made a difference, but for normal driving, I like it. I like having the option and not having to go as slow as a turtle to disconnect.
I agree with that I did really enjoy no swaybar
I've been running no sway bar now for a year. Including towing. I haven't had any issues. Even going around off ramps at speed. It's a really fast back forth that would do it but even then it doesn't lose traction. Just makes your head hit the window
Is the EVO disconnect the same one they use for the Rubicon?
Or is it a different part # for the PowerWagon?
2012
Same one as far as I know, one of the best mods, anything to bypass the factory nanny controls
Exactly why I want it.Will wrote:Same one as far as I know, one of the best mods, anything to bypass the factory nanny controls
Mine takes forever to disengage in a level parking lot,and haven't been able to do it when offroad.
Just get the flashing light.
2012
Sometimes I had to flex mine a little for it to disengage. Yeah, no more of that 18mph and below and only in 4wd crap. I can lock me lockers whenever, where ever, right then and have the swaybar manually disconnected for however long I want no matter what. I've actually gotten so used to the sway bar disconnected, I might just take all that off.
But you have to keep the smart bat and mount it somewhere so the 4WD service light doesn't come on.
Well after tagging the deer, I took off the Plasti Dip and ordered a new factory bumper. In the mean time, I cut this one so I can still use the winch.
- 2011TXPowerWagon
Looks good. What would happend if you cut it straight across the bottom?
could just ditch it for a Thuren bar with disconnect links and pick up some street ride also...?gtomike60 wrote:Exactly why I want it.Will wrote:Same one as far as I know, one of the best mods, anything to bypass the factory nanny controls
Sent from Canada
2wagons1driveway wrote:could just ditch it for a Thuren bar with disconnect links and pick up some street ride also...?gtomike60 wrote:Exactly why I want it.Will wrote:Same one as far as I know, one of the best mods, anything to bypass the factory nanny controls
Sent from Canada
True.But this way is only $100 shipped.
2012
I think mine rides better on the street with it disconnected. When you turn into elevated drives or cross speed bumps with one tire then the other, the truck stays level instead of swaying. Now, in curves, it does lean more but you get used to that. The topper and some weight in the back of mine may be whats making the difference but the front definitely floats much better. I could probably just take the entire setup off and be fine. At least then, my tires wouldn't rub the sway bar.
you'll barelly ever have to disconnect the Thuren bar. The amount of articulation u get with it is three times what the factory bar will allow when connected. And it's a ride improvement but still allows you to corner without lifting a tiregtomike60 wrote:2wagons1driveway wrote:could just ditch it for a Thuren bar with disconnect links and pick up some street ride also...?gtomike60 wrote: Exactly why I want it.
Sent from Canada
Sent from Canada
I just sold my Carli bar. My right rear wheel came off ground yesterday just enough for traction control to freak out and limit powerWill wrote:I think mine rides better on the street with it disconnected. When you turn into elevated drives or cross speed bumps with one tire then the other, the truck stays level instead of swaying. Now, in curves, it does lean more but you get used to that. The topper and some weight in the back of mine may be whats making the difference but the front definitely floats much better. I could probably just take the entire setup off and be fine. At least then, my tires wouldn't rub the sway bar.
It's nice having a bar in there for everyday use but the factory bar rides way to stiff for most of us. For guys with in bed campers probably best to leave factory bar in there!
Sent from Canada
To save space on the shock sticky thread, I'll jump over here because I'm about to make a decision. I've gotten away from the over the counter shocks; the Ranchos are toasted in 35K miles. I've been talking to Don and I am on the fence about his tuned Fox 2.0's or the Kings. It's looks, sounds and appears like the Fox will do what I want but curious about the longevity of each before needed to be rebuilt. I'm not going to be hitting dunes and such here in Florida, mostly backwoods trails with washouts and occasional power lines of sand that could allow some speed. On top of it all, my future plans will be to sell my topper and Bedslide and lighten the truck some (in about 8-10months) Once I get done with my current project, I wont need that stuff anymore and wont need to carry around 400-500lbs in the bed all of the time and will probably go with tube style bumpers and such.
Using the search and searching the internet provides hours upoon hours of threads to sort through. Has anyone on here had both or been around both to provide any education on whether the Kings are worth the extra cost? I could spend the same amount and get a steering brace and upgrade a couple of more items with the Fox versus spending it all on the Kings.
Fox will do fine for what you describe and are just as durable as Kings are. If the Rancho shocks were okay for you until worn out then the Fox will be overkill for you. You might consider Thuren Overlands and Boogie bumps as an alternative... that setup is a huge upgrade on Rancho shocks. The Overlands really do well for light duty use (Heavy use for a stock PW). If you need the Fox shocks they would be a great choice too. While I like the Kings they are very costly and serve no real purpose if you are not running hard enough to really need them.Will wrote:To save space on the shock sticky thread, I'll jump over here because I'm about to make a decision. I've gotten away from the over the counter shocks; the Ranchos are toasted in 35K miles. I've been talking to Don and I am on the fence about his tuned Fox 2.0's or the Kings. It's looks, sounds and appears like the Fox will do what I want but curious about the longevity of each before needed to be rebuilt. I'm not going to be hitting dunes and such here in Florida, mostly backwoods trails with washouts and occasional power lines of sand that could allow some speed. On top of it all, my future plans will be to sell my topper and Bedslide and lighten the truck some (in about 8-10months) Once I get done with my current project, I wont need that stuff anymore and wont need to carry around 400-500lbs in the bed all of the time and will probably go with tube style bumpers and such.
The Fox shocks are a great option and would be my choice if money was not an issue for what you describe. Boogie bumps too if you can swing it! .
Cool, I just want to make sure I get it right the first time. There's so many opinions on the two and it appears the majority swings towards the Kings but I dont know if that is a bandwagon thing or legitimate opinions. I've never been the type to get something just because that's what everyone else has... if the cheaper Fox will do the job, I dont see why I need the Kings.
BTW, looking back, I wasn't ever really happy with the Rancho, it was the initial perception of going from completely worn out shocks to something that actually worked.
As time went on, I found the truck didn't have the side to side sway like the factory ones did even when new but I could adjust them and they either had a harsh street ride and did ok offroad but bounced at speed or they would have a decent soft ride on the street but would easily bottom out. Seemed like there was nothing in between.
Thanks for the input, oh, if you get the Fox, can you just order Thurens from CJC or something and they'll be good or do I need to go through him on a specific valving? I'm going to stick with the factory coils and springs for now and maybe upgrade the coils and add shackles later.
I like to go through Thuren directly because I want all the monetary reward to go directly to him. He is why we have options that work for our needs. Yes CJC or Strapt are viable options and are exactly the same price but like I said I want my money in the hands of the producer of the product I want to buy. Reward the man who creates the product and he stays a viable option for us in the future.
I get that, all my Thuren products have been ordered direct. I guess what I meant was are the FOX Thuren tuned his generic tune or are they customer specific like the King?
I would trust Don to make the choice if you are able to convey what your needs are and are being honest with yourself when doing so. If it were me and I needed custom personalized valving I would step up to Kings.Will wrote:I get that, all my Thuren products have been ordered direct. I guess what I meant was are the FOX Thuren tuned his generic tune or are they customer specific like the King?
A Thuren Generic tune is not a stock Fox valved shock. So I think his Fox 2.0 package should work really good and with Boogie bumps you will have a very well balanced advanced suspension system. Generic or "FOX valving" will not be all that great. I know King generic valving sucks big time!. You are going to make a huge difference with just the Fox 2.0 kit from Thuren. If you don't need the King stiff High speed performance then put that extra money into a full set of boogie bumps and you will be very happy!
Does he do specific tuning on the Fox or no? He's emailed me the Kings are way better but they're much more expensive. Are they twice as good?
Screw it, go big or go home, right!
There's no significant performance difference between king and fox on the higher end shocks, six of one half a dozen of the other so to speak. There are proprietary features that may appeal to you and sway your decision (fox has dual speed compression adjusters and King has full sized internal bypass Pistons etc) but both are amazing when valved for your truck. The Thuren fox 2.0 isn't really in the same league but they would be an excellent choice for a truck that is a daily driver and weekend wheeler but isn't seriously abused at speed off-road. AZ is right on, Thuren overlands or his fox 2.0's and boogie bumps would ride great and allow some decent speed and protection for an oops moment but if you want custom valving and more performance don't bother with a 2.0 go 2.5 of either brand at least.
The larger the shock the wider the range of valving. with a 4.0 you can have the street ride of an overland but still have control over the shaft speed for big hits. The smaller diameter piston the narrower the range the valving can cover. The smaller the oil capacity the less time they can be used at maximum shaft speed and travel.
So a 4.5" can cover 2 to 9 stage, a 3.5" can cover 2 to 7 stage, a 3.0 can cover 2 to 6 stage and the 2.5" can cover a 2 to 5 stage and the overland can cover a 2 to lower end of 3 stage. You can always bias them one direction or the other the smaller diameter the faster they will fade due to heat.
Well, I went out to property yesterday, on the way back I hit the dirt road that is usually eat up with pot holes. I never really paid attention but I drive just as fast if not faster on the dirt roads than on pavement and a rain wash out caught me and I knew with the ABS shit, I might well stay at speed. Ba BAM, shocks bottom out and I now have a 3" crack in the windshield. I'm sure it started from a rock awhile back but never the less, I pulled over right then and shot Don an email to get going on the Kings. Mainly because of my unknown future plans of the truck. I know it's a DD but I have always driven aggressive off road except for this truck and that was mainly due to its past handling. I'm afraid that when I get a taste of "better" shocks, I'll kick myself in the ass for not going ahead and getting the custom valved ones. Plus, I'll be set up if I want to go further in the future. I'm slowly replacing parts as needed and upgrading so I suspect it's only a matter of time. I paid the last payment last month and should have the title next week which leaves me some mad money now.
