37s
Re: 37s
So where's your 37's! I'm working mine till they die. Have a set on hold with deposit now. Safer than wanting and not being able to get
- 2011TXPowerWagon
Re: 37s
Mine are still on back order, or so they say. I am beginning to think I am going to get screwed over...ordered them on May 20th. I am stuck between a rock and a hard place. I don't want to push to hard and lose the deal but I am starting to think maybe just suck it up and buy elsewhere..
Re: 37s
It wouldn't hurt to call around.2011TXPowerWagon wrote:Mine are still on back order, or so they say. I am beginning to think I am going to get screwed over...ordered them on May 20th. I am stuck between a rock and a hard place. I don't want to push to hard and lose the deal but I am starting to think maybe just suck it up and buy elsewhere..
- 2011TXPowerWagon
Re: 37s
I have and everyone tells me the same. 4-6 weeks out still.
Re: 37s
That sucks. I could order you a set here. But shipping would suck
Re: 37s
Awesome!! Pictures pictures pictures!!
- 2011TXPowerWagon
Re: 37s
Did you lift it at all? or just the control arms?stubiePW wrote:Tire store called today. I'll be getting them installed tomorrow after I finish putting the control arms on
Re: 37s
So here they are guys. I think the really make the truck look good. I have some rubbing on the upper contol arm on both sides at full lock and some of the driver rear fender line (cut). I am also rubbing a little on the sway bar on both sides at full lock. It flexes great no rubbing from what I've seen
The tires are quiet and behave well for only driving 18 miles
- 2011TXPowerWagon
Re: 37s
Re: 37s
Beautiful!! Sticking with stock rims they fit perfectly. They don't look stupid sticking out and you can use them!! You get used to the rubbing. It only takes one look over and down at the 6" lifted Chevy on 33's beside you to make you forget the rubbing...
Re: 37s
Nice lookin truck...
I'm partial to the color.
With Thuren diesel coils and his track bar you will only rub on right side sway bar at full lock.
DT Pro Fab sway bar end links
Rugged Ridge floor mats
AMP bed step
37" Toyo RT's
AMP bed step
37" Toyo RT's
Re: 37s
Of just ditch the bar and get a Thuren fab swaybar.
move your module to around the airbox. So your lockers still work this brings the module up and out if harms way so no more water ingress issues.... Looks awsome man
we just finished kens truck with 3" overland set up. Pretty swayey with no swaybar and the moderately valved overland shocks but rides awsome on the highway. Used his level shackles to give it a good stance
"Escalators are never really broken...their just stairs for alittle while... "
Re: 37s
Did the tire dealer give you any flack about putting those 37" tires on 8" wheels?stubiePW wrote:My tires? None. I'm running stock
I've been wanting to run certain 35" inch tires on my factory rims but they always start at 8.5" minimum rim width.
