37" tires on my 2005
				lastmanalliance
Anyone ever squeezed 37's underneath a 2005. I will be upgrading to bilstien 5160 here shortly and I am wondering if 37x12.50 will fit underneath my truck. Thanks
									2005 Dark Gray PW  K&N air filter, straight piped, Bilstien 5100
Re: 37
I did bfg km2s in 37x12.5/17 on my 06 all stock. Trim a little plastic and some control arm rubbing but nothing major. Was worth it. Fully flexed no problem
				lastmanalliance
Re: 37" tires on my 2005
Thanks. I'm looking at getting the procomp mt2 they should be about the same size as the bfg
						Re: 37
I say do it!! then let us know how it goes.  I don't need tires at the moment but really wanted to bypass the 35s and get 37s with stock wheels and no lift.  I don't mind trimming and could probably work up some bent control arms if need be.  Once the tires are on there you can see where you need to make "adjustments"
									2006 PW stocker, 35" Tires, lots of dents and scratches
Had everything from Land Rovers to Duece and a halfs
Re: 37
Yes, yes, yes try them!
On a side note, it would be nice if someone made a 37x10.5 but I sure do like my 37x12.5 (4th Gen, bent arms, stock everything else)
Re: 37
My understanding is wheel wells and 3rd gens generally sit up a little higher... They seemed to have lifted our trucks higher and then with the 4th gens lower and then with the 5th gen I think they are back to being higher lol.06PW wrote:what is the main difference between the 4th gen and 3rd gen? is it the wheel wells?
				lastmanalliance
I can't wait to get these tires. I'm so freaking excited!!! I will be in Santiago Chile for a month so the anticipation is literally going to kill me
						- Mr.Smith
Re: 37
Rated for our trucks...That would be sweet!Will wrote:Yes, yes, yes try them!
