Off and On Road Lights
Re: Off and On Road Lights
Post by TwinStick » Sun Feb 22, 2015 12:34 am
:rockon:
Mpersicke87
Post by Mpersicke87 » Sun Feb 22, 2015 6:13 pm
So, ordered these, here's the scoop.
300w 24,000 lumen 52" curved
288w 21,000 lumen 20" curved
6x 24w squares. Will start mounting when switches are on.
Cactus Red
Post by Cactus Red » Sun Feb 22, 2015 11:15 pm
Better upgrade your alternator! That's 56 amps just to run lights...
Sent via Carrier Pigeon
Mpersicke87
Post by Mpersicke87 » Mon Feb 23, 2015 12:22 am
Didn't even think about that, all the lights should never be on all at once, but still. What's an upgraded alternator for the 13's?
Cactus Red
Post by Cactus Red » Mon Feb 23, 2015 10:30 pm
Can't help ya there...
I'd check with a local automotive boom box store.
Post by Will » Tue Feb 24, 2015 4:54 am
61 amps....
Post by 2wagons1driveway » Tue Feb 24, 2015 8:34 pm
Hahaha wow that's a lot of light! I know 35 amps (3 halogen day lighters )used to dim my headlights on my 1500 ram.... Lol
Sent from somewhere your not
08TwinStickPW
Post by 08TwinStickPW » Wed Feb 25, 2015 3:50 pm
Got my KC gravity lights and man are they heavy. I was expecting light Polly casing and they feel almost like cast Alum. housings.
FYI I ordered (2) 1644 individual lights as I already have a relay harness run, unfortunately the lights do not come with any splice in connectors for the lights (I.E. the lights have a female connector pre-wired and they don't come with a short male that you would connect to an existing harness). I did call KC and they are sending me a set on the house (normally $5 each) which is cool of them (did not want to cut off the connector.
I will update when I get them installed.
2011TXPowerWagon
Post by 2011TXPowerWagon » Wed Feb 25, 2015 5:09 pm
I will always love the look of a bed mounted roll bar with 4 or 5 KC's mounted to it.
Cactus Red
Post by Cactus Red » Wed Feb 25, 2015 5:39 pm
High power LED's need a heatsink since they create the heat internally vs a bulb that project both the light and heat outward.
08TwinStickPW
Post by 08TwinStickPW » Thu Feb 26, 2015 7:58 am
Cactus Red wrote:High power LED's need a heatsink since they create the heat internally vs a bulb that project both the light and heat outward.
I am a bit more aware if this than the avg. person (I work for a high end Lighting MFG.). I almost wonder if they could get even more output from a new housing that exposes the heatsink to air and upping the drive current vs. keeping it in the poly housing.
I know the case is Poly I was just really not expecting them to be as heave and solid feeling. The light engine package in the housing must be a solid/cast metal heat sink (pics online of the inserts are deceiving vs. the weight they are).
Over all I think they will be a very solid light.
Post by 04Ram2500Hemi » Thu Feb 26, 2015 10:47 am
Mpersicke87 wrote:So, ordered these, here's the scoop.
That's a lot of light! I look forward to seeing how you mount these.
Backwoods
Post by Backwoods » Sat Feb 28, 2015 8:45 am
I'm likely going to put a Rigid 54" RDS bar on mine, but am leary of the wind noise everyone is talking about. I had the 50" on my JKU and it wasn't bad, but that was a brick on wheels too.
Anyone run a curved bar on a truck yet?
Mpersicke87
Post by Mpersicke87 » Mon Mar 02, 2015 2:37 am
Both mine are curved, hoping to mount the roof bar and mind as well hack up the stock bumpers for shits and giggles until tax return comes in to get my bumpers.
joeschmidt
Post by joeschmidt » Wed Mar 11, 2015 6:11 pm
Well. I decided to upgrade my hella 700's. I have on order 4 ARB intensity 7 inch series, 2 spot, 2 flood. I will post up when the get put on
Graveltravels
Post by Graveltravels » Wed Mar 11, 2015 6:27 pm
Holy smokes!! That's gonna be BRIGHT!! I've got one of each, and almost find the flood is too much! Looking forward to seeing what yours will look like. I'd been planning to run a couple more lights, but have found the 2 I have are more than sufficient.
08TwinStickPW
Post by 08TwinStickPW » Thu Mar 12, 2015 10:04 am
KC gravity's installed (finally lol)
Here are a few pics, I will be redoing the mounts a bit and using SS as the current ones are rusting.
Overall the spread/driving pattern is great, has good punch/distance, clean/wide distribution, and the instant on is so much better than the HID's warm up time.
I will try and get some nigh time light shots this weekend.
w2dodge
Post by w2dodge » Thu Mar 12, 2015 10:19 am
Very nice...can't wait to see the night photos
08TwinStickPW
Post by 08TwinStickPW » Mon Mar 16, 2015 12:09 pm
Have a family emergancy going on and was not able to get night shots this weekend, I will post up night pics when I can.
joeschmidt
Post by joeschmidt » Fri Mar 20, 2015 6:49 pm
got them on, gonna try getting out tonight to check them out
Juday
Post by Juday » Fri Mar 20, 2015 8:25 pm
That......is a thing of beauty. It brings a tear to my eye. :cheers:
2012 RAM Power Wagon
Graveltravels
Post by Graveltravels » Sat Mar 21, 2015 10:27 am
Holy smokes!!! Let me know how many planes try to land on the hiway in front of you with 4 of them!! I've got two, and they're amazing!! After lighting mine up, I abandoned plans to put two more lights on it!! Where did you get them?
joeschmidt
Post by joeschmidt » Sat Mar 21, 2015 4:34 pm
A buddy of mine has his own fab shop in town and ordered them through a company called " poly performance" . I'm pretty stoked to see what they do at night. I will let you know if I get a 747 to land. Lol.
Side note. Any of you on Instagram?
stubiePW
Post by stubiePW » Sat Mar 21, 2015 7:38 pm
Those look great. Might go that route one day i am on the instgrams. Stubie82
Post by adeluca73 » Sat Mar 21, 2015 8:53 pm
Awesome looking. Are those mounted on a KC or Smittybuilt light bar?
