Damn winch.
Damn winch.
Alright, so we found out on the get together that my winch isn't working.
So today I stopped at a local parts supply place bought some welding tip cleaners dielectric grease and fluid film. After I got the cap off, I started clearing the connectors, and found one to be corroded right away, I know there one blank spot and the rest all have pins.
Can I get a new connector for my controller, and where? This one will be packed with grease so this doesn't happen again.
What a pain in my ass.
Re: Damn winch.
I have read about this happening before here. Now what was that name.....?
Re: Damn winch.
Don't sure, but I don't recommend searching 'winch issues' in the search bar....
Winch is too commonly used on the forum. Winch is kind of funny it's own way. Just makes searching for winch related issues. An issue.
- jeep_boy02
Re: Damn winch.
Are you talking the remote? If so, yes just about any off the shelf controller will work... but a wise investment would be the Warn wireless remote system now.
Re: Damn winch.
Nope the remote is fine, it's the socket :/.
- ramit99
Re: Damn winch.
Mine rotted also. I rewired it to a 7 pin trailer plug up near the rad support. Then you have to rewire the remote to match. Had a picture but can't find it. Friend of mine did the same but mounted the socket in the cab.
Re: Damn winch.
What ever you do to fix it.........................Fluid Film is your friend when it comes to stopping corrosion before it is too late.
Re: Damn winch.
you can buy the replacement socket. I helped a fellow owner rebuild his winch and that was one of the parts needed, along with 4 solinoids and a new motor. Part is around $75. Just go to warn.com download the parts list for a m15000 12v winch. its got all the part numbers you need. The 24v part number is : 39887
Re: Damn winch.
39886 is the 12v part number. $50 on amazon
Re: Damn winch.
Thanks guys parts ordering will commence when I wake up.
Back to bed now.
Back to bed now.
- Trouble Maker
Re: Damn winch.
I see you are from the Ponoka area Interior Offroad in Edmonton has them in stock and is where I bought mine.
https://www.warn.com/corporate/authservicecenters.shtml
Black 09 purchased Dec 21/13
180K kms on the clock
Re: Damn winch.
interior offroad has lots of stuff and really good prices.
