Speedometer calibration for 2014
- ScalerFab
I'm looking to put some 285/75/17's on and will need to re-calibrate the computer to the new size. Anyone know what products are available for the 2014 - 6.4L?
Thanks in advance,
Troy
Thanks in advance,
Troy
- SheepdogOutdoorsman
Re: Speedometer calibration for 2014
The 2014 PW comes with 285's on it already ... You wouldn't need to recalibrate the speedo ...
- JBM Power Wagon
When I got my 2014 I went straight to 315/70/17 tires and the dealer bought a Hypertech speedo calibrator that they used. Good news is when I picked up the truck, for some really odd reason, the salesman gave me the Hypertech speedo calibrator and said "I guess this is yours".
- ScalerFab
The aspect ratio is different 75 vs 70. 285 is the width. 285/75/17' are 34". The stock 285/70/17's are 33"SheepdogOutdoorsman wrote:The 2014 PW comes with 285's on it already ... You wouldn't need to recalibrate the speedo ...
- ScalerFab
Do you know the hypertech part#? They gave it to you because it can only be used on (1) VIN at a time...JBM Power Wagon wrote:When I got my 2014 I went straight to 315/70/17 tires and the dealer bought a Hypertech speedo calibrator that they used. Good news is when I picked up the truck, for some really odd reason, the salesman gave me the Hypertech speedo calibrator and said "I guess this is yours".
It's only a 14mm difference, which is about a half an inch. 5% of 285 is roughly 14mm. There's roughly 25mm in an inch. I don't think that half an inch is going to throw your speedo off that much.
- JBM Power Wagon
I have it at home so will post it up later.ScalerFab wrote:Do you know the hypertech part#? They gave it to you because it can only be used on (1) VIN at a time...JBM Power Wagon wrote:When I got my 2014 I went straight to 315/70/17 tires and the dealer bought a Hypertech speedo calibrator that they used. Good news is when I picked up the truck, for some really odd reason, the salesman gave me the Hypertech speedo calibrator and said "I guess this is yours".
In this case the speedometer would be off by 2.23 mph at 65SheepdogOutdoorsman wrote:It's only a 14mm difference, which is about a half an inch. 5% of 285 is roughly 14mm. There's roughly 25mm in an inch. I don't think that half an inch is going to throw your speedo off that much.
These trucks all have GPS capability... Ram should take advantage of that and automatically apply a speedometer compensation periodically. This would keep the speedo's accurate as tire treads wear down AND reset the compensation factor for all the masses that change tire sizes.
After all, the trucks already adjust their engine and shifting tuning based on how it's being driven.
I got my speedometer calibrator from Hypertech I would give them a call and see if they have one for the 6.4 Hemi.
EXACTLY...x2. This is so easy, it should be a built in user feature you can input in the "settings" menu.Bill2014 wrote:These trucks all have GPS capability... Ram should take advantage of that and automatically apply a speedometer compensation periodically. This would keep the speedo's accurate as tire treads wear down AND reset the compensation factor for all the masses that change tire sizes.After all, the trucks already adjust their engine and shifting tuning based on how it's being driven.
- JBM Power Wagon
X3!!! That is a GREAT idea!!!adeluca73 wrote:EXACTLY...x2. This is so easy, it should be a built in user feature you can input in the "settings" menu.Bill2014 wrote:These trucks all have GPS capability... Ram should take advantage of that and automatically apply a speedometer compensation periodically. This would keep the speedo's accurate as tire treads wear down AND reset the compensation factor for all the masses that change tire sizes.After all, the trucks already adjust their engine and shifting tuning based on how it's being driven.
loveracing1988
It is probably like the tuners and it is Vin locked to your truck.JBM Power Wagon wrote:When I got my 2014 I went straight to 315/70/17 tires and the dealer bought a Hypertech speedo calibrator that they used. Good news is when I picked up the truck, for some really odd reason, the salesman gave me the Hypertech speedo calibrator and said "I guess this is yours".
loveracing1988
Diablosport has the intune and Trinity for the 6.4, you can use that to reset the tire size and tune the engine if you want.ScalerFab wrote:I'm looking to put some 285/75/17's on and will need to re-calibrate the computer to the new size. Anyone know what products are available for the 2014 - 6.4L?
Thanks in advance,
Troy
- ScalerFab
Just installed 315/70/17's and have a message in to Hypertech. The speedo is off a little less than 5%...
If anyone has the part# of the recalibration unit I need, that would be great.
No rub with the 315's on stock wheels...
- ScalerFab
Well, this is the message I sent to Hypertech:
To whom it may concern,
I'm looking to purchase a speedometer re-calibration unit for my 2014 Ram 2500 Power Wagon with the 6.4 Hemi. I just mounted bigger tires and would like the compter to be in sync again.
Please let me know the part# of the product that I need.
Thanks,
Troy Loftus
And, this is the response I received:
Troy
We do not have a tuning device for this make and model, we may eventually but no word as to when at this time. We will not know the availability for a new application until a week or so prior to the release. I've entered your contact information so you'll be notified once ready. Thanks
Jim
So, if anyone knows the part# of the unit that folks have used to recal a speedo on a 2014 with 6.4, that would be greatly appreciated
Thanks,
Troy Loftus
Troy
Jim
- JBM Power Wagon
Hi Scaler, when I bought my truck the dealer used a Hypertech speedo calibrator and it worked. I did get your email so when I get a chance I will find it and pull the part number.
- ScalerFab
I found and purchased Hypertech part# 752501 for $163 w/ free shipping, and after updating the unit via the internet, it worked flawlessly. I had to try a few different tire heights to get the speedo corrected according to my phone gps. I actually am using 33.5". The tires I have measure about 34-ish", but when I used those numbers, the speedo was over the correct speed...
- JBM Power Wagon
Glad to hear it worked!!!
- ScalerFab
Thanks, man... I appreciate you taking the time to look that up for me. I can't believe that the folks at Hypertech stated that they didn't offer a unit that would work with my truck...JBM Power Wagon wrote:Glad to hear it worked!!!
Question, is the Hypertech good for anything other than reprogramming the speedometer? If not, $163 is awfully expensive to adjust just that one parameter, right?
- ScalerFab
Just good for gear changes, tire size changes, and reading/clearing DTC's... That's all I needed, so spending $400-$500 on a tuner that I don't want would have been wasting my money in my opinion.adeluca73 wrote:Question, is the Hypertech good for anything other than reprogramming the speedometer? If not, $163 is awfully expensive to adjust just that one parameter, right?
I know this does not pertain anymore really as the OP got a set of 315's, but anyway. Your numbers a re a bit off. Your "about a half inch" number should have been doubled, as it is only the sidewall height number (and there are 2 sidewalls in the overall height of the tire). Your picture clearly shows the overall tire height is over 1" taller. Certainly not a big changing factor, but...SheepdogOutdoorsman wrote:It's only a 14mm difference, which is about a half an inch. 5% of 285 is roughly 14mm. There's roughly 25mm in an inch. I don't think that half an inch is going to throw your speedo off that much.
The extra height is determined by radius, not diameter. So, "about a half inch" would still be correct.olyelr wrote:I know this does not pertain anymore really as the OP got a set of 315's, but anyway. Your numbers a re a bit off. Your "about a half inch" number should have been doubled, as it is only the sidewall height number (and there are 2 sidewalls in the overall height of the tire). Your picture clearly shows the overall tire height is over 1" taller. Certainly not a big changing factor, but...SheepdogOutdoorsman wrote:It's only a 14mm difference, which is about a half an inch. 5% of 285 is roughly 14mm. There's roughly 25mm in an inch. I don't think that half an inch is going to throw your speedo off that much.
The extra height of the truck is determined by the radius. The extra height of the tire is determined by the diameter, which is directly related to the circumference, which is what the speedo and related programming uses to determine the speed of the vehicle.
