Tripped 30K, started ordering Maintenance supplys
08TwinStickPW
Post by 08TwinStickPW » Fri Jul 25, 2014 8:15 am
Ordered some NGK G series which are partial platnium, fine tip, $2.99ea vs. $2.50 for normal V-power copper core. I know copper core is best however I wanted to try something else and for $.50 more I figure it can't hurt.
Gonna pick up some Amsoil for the Diff's shortly and order some filter mags to put in the diff's as well (also will clean the magnets).
Needs an oil change too and gonna go back to running conventional, for some reason my truck does not like Full or Blended synthetic oil...tends to burn it (I assume as it does not leak out).
The Transfer case needs a new output shaft/drive shaft boot (should have been done while the tranny was out !) so I am gonna ask the dealer to just change the fluid if they don't do it automatically.
Anything else I should look into doing maintenance wise at 30K?
Tunes:Pioneer AVH-X5800BHS w/stock infinity amp, Infinity ref. dash/reardoor speakers, kappa component front door, JL rear stealth box and JX500.1d.
leo72987
Re: Tripped 30K, started ordering Maintenance supplys
Post by leo72987 » Fri Jul 25, 2014 8:47 am
08TwinStickPW wrote:Ordered some NGK G series which are partial platnium, fine tip, $2.99ea vs. $2.50 for normal V-power copper core. I know copper core is best however I wanted to try something else and for $.50 more I figure it can't hurt.
Only other thing I can think of is greasing up that front driveshaft. Hell I still have to do mine on my 2005 Power Wagon haaha. Funny you mention the oil burning with Synthetic I have 165,000 miles on mine and it does that to. I want to say a quart every 4,000 miles I spoke with a Dodge mechanic and he said it's within spec for the hemi's lol. Oh I would also check out your pcv valve make sure that's still good. I just replaced mine the other day original lasted 165,000 miles lol.
Post by Will » Fri Jul 25, 2014 9:15 am
30K miles on an '08 :shock:
w2dodge
Post by w2dodge » Fri Jul 25, 2014 10:08 am
I just did an oil change..tried royal purple..fn $$..75k...cleaned out locker conections...and smart bar...gotta grease the front driveshaft also...pain
08TwinStickPW
Post by 08TwinStickPW » Fri Jul 25, 2014 10:36 am
Will wrote:30K miles on an '08 :shock:
Yup, bought it with only 9K almost 4 years ago lol (I have a short commute).
In the past 5K it got a new clutch, flywheel, etc.. and a re-built tranny under warranty (bad day at the factory I guess).
Post by coder » Fri Jul 25, 2014 4:20 pm
08TwinStickPW wrote:Anything else I should look into doing maintenance wise at 30K?
At 30k you don't need to flush the transmission or transfer-case just check the fluid level, new fluid is at 60k.
At 30k replace:
- Air Filter
- Engine oil w/filter
- Front/rear axle gear oil
- PCV valve
- Spark plugs
Synthetic motor oil will burn a little more because doesn't thicken up as much as regular oil over time and gets past the rings easier. I've used synthetic oil since I got my 07 new and change it every 3k miles. I burn about 1 quart between oil changes and have since I had about 45k miles, I'm at 110k right now so I wouldn't worry about it.
By the way the factory spec for oil consumption is 1 quart every 1500 miles under 75k miles, and 1 quart every 750 miles after that is acceptable, so you are well within specs. Keep in mind not all engines will do this and "acceptable" only means that it is not a sign of abnormal engine wear or damage that requires you to fix something.
Post by cruz » Fri Jul 25, 2014 5:34 pm
After reading countless threads on spark plugs, the general consensus seems to be, stick to stock Champions.
bstefanic
Post by bstefanic » Fri Jul 25, 2014 8:54 pm
At 30k replace:
- Air Filter
- PCV valve
- Spark plugs
Great to know on the oil consumption, its been something I've been wondering about for a while. Thanks
fyrfytr704
Post by fyrfytr704 » Fri Jul 25, 2014 9:39 pm
I'm almost certain that 30k miles is when you're supposed to add the lift and tires...
Post by Bill2014 » Fri Jul 25, 2014 10:02 pm
fyrfytr704 wrote:I'm almost certain that 30k miles is when you're supposed to add the lift and tires...
That made me smile :lol:
Post by adeluca73 » Sat Jul 26, 2014 2:31 am
cruz wrote:After reading countless threads on spark plugs, the general consensus seems to be, stick to stock Champions.
Funny how so many folks return to stock parts after trying so many aftermarket " upgrades"!!
Post by adeluca73 » Sat Jul 26, 2014 2:32 am
It's in the owner's manual, right?
fyrfytr704
Post by fyrfytr704 » Sat Jul 26, 2014 8:07 am
I'm pretty sure. The locker bypass is mentioned as a part of the first service - I'm kind of surprised that the OP missed that. Always follow the manual!
Stickman
Post by Stickman » Sat Jul 26, 2014 11:11 pm
Me also, lol. Are E3s frowned upon on here for plugs? Everything I see and read says they are better than any other plug. I've put them in my other vehicles and seen noticeable gains in fuel economy and power (use that loosely, probably the placebo effect but hey..) I may do them on my plug service if anyone wants to see if they help any.
fyrfytr704
Post by fyrfytr704 » Sun Jul 27, 2014 6:14 am
I'd be interested to see what the E3's do for you. I considered them but ended up sticking with stock.
Post by FirerescuePW » Sun Jul 27, 2014 5:29 pm
I think there are writeups on DodgeTalk about E3s. IIRC, mostly unsatisfactory results.
diggerdude69
Post by diggerdude69 » Sun Jul 27, 2014 6:00 pm
Got almost 120k on my 05. Been running AMSOIL on the 1year 25,000 mile cycle for the past few years. I thought it was better on oil. Only add a quart or so over a year. :mrgreen:
08TwinStickPW
Post by 08TwinStickPW » Mon Aug 04, 2014 7:39 am
Seafoamed the truck (Intake, in the fuel, little in oil) and drove the piss out it, only got a little smoke.
Changed the oil and went with Nappa brand gold filter and Nappa regular 5w-20.
Changed the plugs (forgot how much a pain in the ass the rear ones are), took 2 hours or so with a few breaks.
Cleaned the PCV and the TB.
Overall she idle's a little smoother and seems to have more throttle response, now on to the diff's.
Post by Will » Mon Aug 04, 2014 9:14 am
Changed my serpentine belt yesterday, looked fine but at 103K miles, I figure, why not... took about 5 minutes.
GunniPWguy
Post by GunniPWguy » Mon Aug 04, 2014 3:14 pm
:rockon:
fyrfytr704
Post by fyrfytr704 » Mon Aug 04, 2014 11:03 pm
08TwinStickPW wrote:Seafoamed the truck (Intake, in the fuel, little in oil) and drove the piss out it, only got a little smoke.
I think that you're on the same path I am - it's almost scary. I've still got a tiny bit of roughness at idle. I guess I will need to work on figuring that out. Although, at 101k I don't think that I can expect it to run like my old lady's 2013 Charger. Oh well..
lastmanalliance
Post by lastmanalliance » Mon Aug 04, 2014 11:26 pm
Getting ready to do the same service on my 05. Time for a tune up gentlemen
