I'm curious ... What advantage did you see to the BDS Long Arm kit over kits offered by Carli or Thuren? So ... You got the 6" LA kit which gave you 4" of lift?2wagons1driveway wrote:4/6" bds coils and rear leafs and long arms with Carli 2.65 acv shocks. 37" Mickey thompsons
Thanks ... It's a Trail Ready Pre-Runner GuardstubiePW wrote:Looks good sheepdog. What bumper is that?
Looks goodautogateman wrote:Got my 35's put on!
You getting plenty of rain to check it out, every picture you got, the trucks wet...autogateman wrote:Got my 35's put on!
 Looks good
  Looks good
The bds was a million dollars cheaper. The design of bolt on was nice. And I didn't have to chop any parts on the truck to install the kit or weld anything permanently. I would have liked a radius are because they do flex like a mofo!! But their big dollars and the maintenance on the axle control shock is kind of a let down. Id imagine it's the same problem with all the bilstein offroad shocks and the bushings go often! But also a 4 link long arm seems to flex better over a radius arm any day. The only draw back is there's some more body roll ?? I don't notice but this is what the pros say! It sucks that you have to run such a huge offset with the bds long arms though....at least a 4.75/4.50" bs to clear 36/37/38" tiresSheepdogOutdoorsman wrote:I'm curious ... What advantage did you see to the BDS Long Arm kit over kits offered by Carli or Thuren? So ... You got the 6" LA kit which gave you 4" of lift?2wagons1driveway wrote:4/6" bds coils and rear leafs and long arms with Carli 2.65 acv shocks. 37" Mickey thompsons
Good info ... I appreciate it2wagons1driveway wrote:The bds was a million dollars cheaper. The design of bolt on was nice. And I didn't have to chop any parts on the truck to install the kit or weld anything permanently. I would have liked a radius are because they do flex like a mofo!! But their big dollars and the maintenance on the axle control shock is kind of a let down. Id imagine it's the same problem with all the bilstein offroad shocks and the bushings go often! But also a 4 link long arm seems to flex better over a radius arm any day. The only draw back is there's some more body roll ?? I don't notice but this is what the pros say! It sucks that you have to run such a huge offset with the bds long arms though....at least a 4.75/4.50" bs to clear 36/37/38" tiresSheepdogOutdoorsman wrote:I'm curious ... What advantage did you see to the BDS Long Arm kit over kits offered by Carli or Thuren? So ... You got the 6" LA kit which gave you 4" of lift?2wagons1driveway wrote:4/6" bds coils and rear leafs and long arms with Carli 2.65 acv shocks. 37" Mickey thompsons
No worries man! Pain in the ass sourcing all the info and trying to make a decision on suspension I can tell you I'm very happy with all the Carli products I've installed latelly. And I'm very happy with the Thuren products that I've gotten also! Bds I am just happy that the arms are stout lol keep that in mind.SheepdogOutdoorsman wrote:Good info ... I appreciate it2wagons1driveway wrote:The bds was a million dollars cheaper. The design of bolt on was nice. And I didn't have to chop any parts on the truck to install the kit or weld anything permanently. I would have liked a radius are because they do flex like a mofo!! But their big dollars and the maintenance on the axle control shock is kind of a let down. Id imagine it's the same problem with all the bilstein offroad shocks and the bushings go often! But also a 4 link long arm seems to flex better over a radius arm any day. The only draw back is there's some more body roll ?? I don't notice but this is what the pros say! It sucks that you have to run such a huge offset with the bds long arms though....at least a 4.75/4.50" bs to clear 36/37/38" tiresSheepdogOutdoorsman wrote: I'm curious ... What advantage did you see to the BDS Long Arm kit over kits offered by Carli or Thuren? So ... You got the 6" LA kit which gave you 4" of lift?
That looks awsome!!!! Like it with the murdered wheels. What style are they very sharp looking look like your bearing/hub kit was made for them!bstefanic wrote:[attachment=-1]uploadfromtaptalk1402618045450.jpg[/attachment] new wheels came in so finally got the tires mounted up
Sent from my DROID RAZR HD using Tapatalk
So far all seems good, like riding in a Cadillac after running worn KM2's missing a bunch of chunks. The place I took them to to get mounted used bags over weights so interested to see how that works...haven't gotten a chance to get up to highway speeds yet to see how they balance out. Definitely requires some fender trimming now thoughJuday wrote:Nice! How do you like the SS-M16 tires?
