Mexican Import
12. Mexican Import - 2013
13. MSCH2112 - 2012
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Gooseneck
2016 Volvo XC90
1. myoung84 - 2012
2. 04Ram2500Hemi - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
6. Wingerak92 2012 (next year, need tires first)
7. TwinStick-----3rd Gen 2008 w/G56 (LATER)
8. Hemi46. 05 gen 3 (later)
9.gtomike60-2012
10.glidehm
11. ScottWagon1-later
13. MSCH2112 - 2013
14. BMWS52-2011
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
15. Mopar Bob (2012) - Later
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
PIAA 570s behind grill (to be moved to light bar soon), HID low beams, "cheap bulb" upgrade high beams and fogs, LED tail light and reverse light bulbs, DOR Diff Covers, Warn wireless remote, Magnaflow y-pipe and 22" muffler, AFE Air Filter (stock box) and a Lund Genesis™ Elite Tri-Fold Tonneau Cover covering up the gear.
I'm very interested. I have mine wired direct to toggle switches and have been working great ever since. Would be very nice to use the stock knob instead and not see flashing lights. I have a 2005 and would need to get a little more details on install. I have no problems cutting and splicing wires if there is a diagram and instructions. Gotta order my lift and tires this month and next. So probably be early next year before I could purchase one.
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
16. Juday (2012) - Later
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
2012 RAM Power Wagon
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
17. Nrooney21 (2012)
Sent from my SCH-I605 using Tapatalk 2
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
18. RustyPW '08 3G (when you get the 3G figured out)
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
- jeep_boy02
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
19. Jeep_boy02 (2010)
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
Txhillbilly
Add me on the list for this.jeep_boy02 wrote:1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
20. TxHillbilly
Thanks guys! That's a pretty good list!
I'm just waiting on my new relays to come in now. They were supposed to be here today but weren't in the mailbox this morning. Thanks USPS!
- SheepdogOutdoorsman
I guess I'm just not sure if this is something I should do to my truck. So far, I haven't had issues with my lockers when I've needed them. They lock up when the wheels start to slip, which for me seems to work like it should. Albeit, I haven't done a whole lot of wheeling in my truck yet, I'm just not sure if risking my unlimited warranty is worth it. I'm open to thoughts on my logic though ...
Warranty shouldn't be a problem. 5 minutes and a set of wire cutters to cut the zip ties and the entire bypass kit is out of the truck and there's no way to tell it was ever there. As far as the bypass kit harming the truck, it's highly unlikely. The lockers themselves won't know the difference between the bypass sending them power or the smartbar. I think the biggest benefit is being able to lock up whenever you want to. Flip the knob to Front/Rear and both axle solenoids get power immediately rather than the smartbar holding back the front until the rear is locked. Then it's just a matter of getting the teeth to align and lock the axle together.
Do you ever use your lockers in 4-High or would you want to be able to lock the rear in 2wd? This will allow you to do so.
- GunniPWguy
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
20. Rgory (3rd Gen) When you get it figured out
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
bajaben48
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
21. Bajaben48. (later....tax return
Great work by the way. I am super amped about this
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
Ben
Us Army EOD
Us Army EOD
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
21. Bajaben48. (later....tax return )
22. Iamahemi (2012) later
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
2012 bright white,decal delete package,ARE cap,bed rug,Mopar black side steps,2010 rear headrest swap,1 child carseat,1 booster seat,Toyo AT2 285/75/17,Mopar mud flaps, cabin air filter mod .....
- Mr.Smith
1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
22. Iamahemi (2012) later[/quote]
23. BigMike 2009
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
- GunniPWguy
BigMike wrote:1. myoung84 - 2012
3. BlkWgn 2006
4. TrueBlue13PW
5. HotRod929 - 2013
9.gtomike60-2012
10.glidehm
13. MSCH2112 - 2013
14. BMWS52-2011
23. BigMike 2009
24. GunniPWguy (2005) worthy mod someday
tygerwagon
Brand spankin new to forum. Joined due to having much trouble with lockers on my 05 PW. Need lockers, NOW, hunting season is here. Any help would be appreciated. Love the sound of plug and play hardwire.
It works! The relay boards work like expected. The lights are hooked up to the relay outputs to demonstrate functionality. Once the lights are hooked up to the sensors they won't illuminate until the axle is locked. Now I just need to run the wires to the axles and get offroad for final testing.
Nice! Good News!
I would take one when you get one available for a 3rd gen 2008 thanks
AWESOME!!!myoung84 wrote:It works! The relay boards work like expected. The lights are hooked up to the relay outputs to demonstrate functionality. Once the lights are hooked up to the sensors they won't illuminate until the axle is locked. Now I just need to run the wires to the axles and get offroad for final testing.
