AEV Ram!
Re: AEV Ram!
And now, the BIG question. How much for that truck as it sits ??? The Jeep 4 door w/Hemi, 545RFE lift & tires & options is $65,000- $85,000. Don't get me wrong, it is certainly badass. Realistically most will not be able to afford one. If they would do a small lift & 37's & still get full flex for 3rd gens & fender flairs/fenders/bed sides, they would sell some of those for sure. So, anyone know how much ???
edit; Just priced one out. $59,095 without including the $42,000 for the Jeep Rubicon 4 door.
Re: AEV Ram!
HijackBlkWgn wrote: ... and I had to go through Pismo to get home.
BlkWgn, did you get a chance to play around, how'd your truck do ?
Re: AEV Ram!
Remember though, we already have the truck. AEV will sell just parts, you don't have to buy it all. I'm actually fairly content with my truck now, but I could always do a Carli Suspension and then buy AEV wheels and the bumper. We don't need the whole setup.TwinStick wrote:And now, the BIG question. How much for that truck as it sits ??? The Jeep 4 door w/Hemi, 545RFE lift & tires & options is $65,000- $85,000. Don't get me wrong, it is certainly badass. Realistically most will not be able to afford one. If they would do a small lift & 37's & still get full flex for 3rd gens & fender flairs/fenders/bed sides, they would sell some of those for sure. So, anyone know how much ???
Re: AEV Ram!
Yeah, but still, uber expensive. Bumper is not just ugly, it is FUGLY, but thats just my oppinion. Fender flares with more clearance would be great. I may even go with trimming fenders. 3" lift for 37's & no rubbing at full flex would be great. I'm just looking at this from a poor mans perspective i guess. I just think you can do almost as good for wayyyyyyy less money is all.
Re: AEV Ram!
i hate to say it but if i went the AEV route with 40's, i'ld sell the pw and buy a diesel just to turn those 40's, then i'ld get real lockers....air lockers. i can't imagine a hemi turning those meats effectively.
mike
mike
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Gooseneck
2016 Volvo XC90
Re: AEV Ram!
You're probably 100% correct. However, 37" tires with minimal to no lift would be sweet.MSCH2112 wrote:i hate to say it but if i went the AEV route with 40's, i'ld sell the pw and buy a diesel just to turn those 40's, then i'ld get real lockers....air lockers. i can't imagine a hemi turning those meats effectively.
mike
wingerak92
Re: AEV Ram!
They say they used stock springs on their set-up….. why? We are all changing out ours on our suspension set-ups.
Re: AEV Ram!
from the story on Expedition Portalwingerak92 wrote:They say they used stock springs on their set-up….. why? We are all changing out ours on our suspension set-ups.
While most aftermarket suspensions have either a gas or diesel motor spring, AEV did the research and found 37!!! factory front spring part numbers for these trucks, so it is impossible to provide the correct ride, handling and frequency tuning with only two aftermarket springs. Avoiding the "two size doesn't fit all" approach, the AEV suspension engineering team retained the factory springs, improving performance and value to the consumer.
http://expeditionportal.com/dodge/2528- ... ndard.html
wingerak92
Re: AEV Ram!
I read that. That is why I am questionin. We are all changing out our springs to help with our suspension set-ups. Why are they not? I understand that a Power Wagon is going to have different springs than the Outdoorsman is going to have different springs than a standard 3/4 ton… And Half tons will be different than 3/4s which will be different than 1 tons…BlkWgn wrote:from the story on Expedition Portalwingerak92 wrote:They say they used stock springs on their set-up….. why? We are all changing out ours on our suspension set-ups.While most aftermarket suspensions have either a gas or diesel motor spring, AEV did the research and found 37!!! factory front spring part numbers for these trucks, so it is impossible to provide the correct ride, handling and frequency tuning with only two aftermarket springs. Avoiding the "two size doesn't fit all" approach, the AEV suspension engineering team retained the factory springs, improving performance and value to the consumer.
Re: AEV Ram!
I am in no way qualified to make this statement, but I would bet that Carli or Thuren have put more thought into their springs than Dodge did. Personally if I was going with the AEV setup, I would probably get aftermarket springs elsewhere to go with it.
Re: AEV Ram!
Tire size won't really be an issue w/Hemi if you can regear to 5.13's. The 2014's have 11.5" rear & 9.25" front---both of which 4.88's & 5.13's are avail.. Would that be much different than the Jeep Pentestar 3.6 turning 37's, (which is quite common) ???
Re: AEV Ram!
I'd love to have 5.13s now with my 35s!
Re: AEV Ram!
Tell me about it, I had an 04 2wd 2500 with the 4.10 on stock size tires (I think they were 285/70/17) and the 06 wagon with the extra weight, and the 33's I bought it wil seemed very sluggish, now with the 35's, it is noticeably slow on the mountain roads. It would sure be nice to up the gearingmyoung84 wrote:I'd love to have 5.13s now with my 35s!
- Cactus Red
Re: AEV Ram!
They also mention a 3" lift is in the works, and that will probably use an AEV tuned spring/shock combo. If that comes to be, I'll buy it. The AEV lift on our Jeep is phenomenal; it just works flawlessly both off and on road.
Re: AEV Ram!
That's what I was thinking, too.Cactus Red wrote:They also mention a 3" lift is in the works, and that will probably use an AEV tuned spring/shock combo. If that comes to be, I'll buy it. The AEV lift on our Jeep is phenomenal; it just works flawlessly both off and on road.
2012 RAM Power Wagon
Re: AEV Ram!
Well here are some pictures. The set they have here is just the 1 off fiberglass pre production and they will be going into production in 4 to 5 months. No price estimate or guess even.
Re: AEV Ram!
A few more then I will explain what they said.
Re: AEV Ram!
The inner fender liners are just mockups and nothing like what the finals will be (done for show only). The ends of the bumper are removable and will allow for different designed ones to be bolted to the ends for different years and light applications. The center section of the bumper will be generic to all years 2010>201? and require no modifications between years other than the outer sections being different. They have no intent to adapt this kit to the PW but plan for a zero suspension lift/mod 37" tire set.
He said the 40" kit required a little over 2" of metal fender removal to attach the flares and clear 40" tires. He did not know the wheel offset but said they did not deviate much from OEM.
To use the 40" tires they lengthened the front suspension radios arms over an inch and did " a total reengineering of the steering for the axle to move forward and accommodate the lift" they put in. I think he said 3" lift. The rear suspension is stock geometry but lifted just enough to level the truck.
He Suggested that we PW folks wait for the no lift 37" flare kit and just move the front OEM bumper forward about an inch or so with spacers or new longer brackets they might design if there ends up being enough interest in them. He also suggested that the 2014 guys might do 40" and just re-gear to 513s since we are gassers and now have that option with the new axle.
I got the third degree for doing my photos like I did. I gave them the website but I figure they will round file it and wait to see what interest and traffic this information generates.
wingerak92
Re: AEV Ram!
That's good! I remember watching their show on RADX (TV Channel up here) where they outfitted a Jeep Commander for arctic expedition. I quite enjoyed it.
Thanks for taking the risk! haha
I will definitely wait for that kit.. Helps me create a better budget! Haha. If I could get away with just doing larger tires I would.
Re: AEV Ram!
Nice work, Ken. Very thorough report.
Do you know what size shocks they were able to fit on the rear?
Re: AEV Ram!
Thanks, I have one more day and can do special angles or questions if needed I can try to go and get pictures or answers.FirerescuePW wrote:Nice work, Ken. Very thorough report.
The Shocks are 2.0 Bilstien and are nothing we should count on for final production as they were chosen for the show because of fitment and no final decisions have been made about shocks or valving. I quote when saying that " we barely got this stuff to fit together and need to refine our package from here".
Re: AEV Ram!
Thanks. I was curious what would fit with the shock mounts up inside the frame. I guess we'll have to wait for more research/engineering from them and others.
Re: AEV Ram!
Thanks for the pictures! Now it makes me wonder if they're just going to build this kit for the radius arm/rear coil suspension crowd, or if they'll go back and produce items for those of us with control arms and leaf spring rear?
Re: AEV Ram!
I like the Power Wagon suggestion. That may be the way I go if I ever do anything with my truck. I really have no urge for 40" tires with my truck.azracer wrote:The inner fender liners are just mockups and nothing like what the finals will be (done for show only). The ends of the bumper are removable and will allow for different designed ones to be bolted to the ends for different years and light applications. The center section of the bumper will be generic to all years 2010>201? and require no modifications between years other than the outer sections being different. They have no intent to adapt this kit to the PW but plan for a zero suspension lift/mod 37" tire set.
- GunniPWguy
Re: AEV Ram!
That is way cool that you are able to be at the show and see that stuff first hand. Jealous. Thanks for posting the pics for us. These possible upgrades from AEV have my full attention.
