PW Battery Suggestions?
vanished
Post by vanished » Thu Oct 25, 2012 7:31 am
Just thinking as the snow, ice and cold are coming and my factory battery is pushing 7 yrs... It might be time to be proactive.. Suggestions winch mob? :)
08TwinStickPW
Re: PW Battery Suggestions?
Post by 08TwinStickPW » Thu Oct 25, 2012 8:03 am
My factory one gave up the fight this summer....all 19K miles on it and 4 years ( :wtf: )
I did lots of research, and ended up with a sears platinum with 930CCA, (Same as a odyssey 65-PC1750T for almost half price).
Has a great warranty and give me piece of mind to not have to worry about hte battery again for a while (It is expensive though)
http://www.sears.com/diehard-platinum-a ... ockType=G1
http://www.odysseybattery.com/
Others out there are almost all the same, they just have different labels (really only 1 or 2 parent companies that make all the batteries).
I have read that the optima batteries have gone to crap and to stay away (they were sold and sent to Mexico or something now :secret:)
Post by TwinStick » Thu Oct 25, 2012 8:39 am
Sears Die Hard Platinum. Made by Odyssey for Sears. Made to exceed Military specs. Designed to hold a full charge for up to 2 years on shelf.
Gp 65 for stock replacement.
Gp 31M for the big boy.
I have one of each. No issues.
:cheers:
Cactus Red
Post by Cactus Red » Thu Oct 25, 2012 9:08 am
Ditto - Group 65 Diehard Platinum is the only way to go. Spendy, but well worth the money.
Post by FirerescuePW » Thu Oct 25, 2012 10:04 am
^ X4
MSparks909
Post by MSparks909 » Thu Oct 25, 2012 10:41 am
I'll be getting a Sears Diehard Platinum later this fall. Stock battery is 6 years old.
2006 QC PW G56
BlkWgn
Post by BlkWgn » Thu Oct 25, 2012 12:16 pm
I put the sears platinum (odysee) group 31 "big boy" in. It is a bit snug, but it will drop right into an 06 http://www.sears.com/diehard-platinum-m ... ockType=G1
Worth every penny
vanished
Post by vanished » Thu Oct 25, 2012 3:37 pm
I love it when everyone actually agree's on something! It looks like the 65 will work... Is the 31 a deep cycle? I didn't think that was good for vehicles?
BlkWgn
Post by BlkWgn » Thu Oct 25, 2012 3:48 pm
vanished wrote:I love it when everyone actually agree's on something! It looks like the 65 will work... Is the 31 a deep cycle? I didn't think that was good for vehicles?
They are both marine batteries of the same make up, the group 31, is physically larger allowing it to be "more battery"
Group 31 specs
Dimensions:
Height (In.): 9.5
Item Weight (lbs.): 75
Length (in.): 13
Width (in.): 6.8
1150 Cold Cranking Amps – Provides power for RVs, trolling motors, marine accessories, and starting needs in all weather conditions, due to the use of 99.99% pure virgin lead plates and tin-coated brass terminals
205 Minutes of reserve capacity - Ideal for multiple electronic accessories
Deep discharge recovery – Ideal for marine & deep cycle applications
Combination stud/post terminal design – for multiple connections
Longer off-season storage time – Ideal for boats
AGM (Absorbed Glass Mat) construction - Provides mounting flexibility & guarantees longer service life
Worry and maintenance-free operation - High purity grade acid held safely in place by glass mats makes a non-spillable design that gives mounting flexibility
Military-grade construction & proven vibration resistance – Offers superior vibration resistance
Group 65 specs
Dimensions:
Group Size: 65
Height (In.): 7.4
Item Weight (lbs.): 60.0
Length (in.): 11.8
Width (in.): 7.2
4-year FREE Replacement, 100 Month Pro-Rated Limited Warranty
930 CCA (Cold Cranking Amps) - Reliable starting power in all weather conditions, due to the use of 99.99% pure virgin lead plates and tin-coated brass terminals
135 Minutes of reserve capacity - Ideal for luxury vehicles with multiple electronic accessories
Longer off-season storage time – Ideal for show cars & classic cars
Military-grade construction & proven vibration resistance – Ideal for off road applications
vanished
Post by vanished » Thu Oct 25, 2012 7:00 pm
Sweet! Thanks for the information. Looks like a no brainer.. I won't worry about them being deep cycle. Thanks!
Post by cruz » Thu Oct 25, 2012 7:16 pm
FirerescuePW wrote:^ X4
Cactus Red wrote:Ditto - Group 65 Diehard Platinum is the only way to go. Spendy, but well worth the money.
MSparks909 wrote:I'll be getting a Sears Diehard Platinum later this fall. Stock battery is 6 years old.
^ X5.
I can't believe that my original battery is still crankin' , 7yrs. 2 mos. old.
Definitly going to replace it with a Diehard when the time comes.
Post by FirerescuePW » Fri Oct 26, 2012 7:26 am
I replaced the original battery in my '05 back in June. It wasn't showing any age, but I felt that I was pushing the envelope keeping it in there. It seems like the OEM batteries last close to forever. I don't get it. Nothing seems to last as long once you replace it.
08TwinStickPW
Post by 08TwinStickPW » Fri Oct 26, 2012 7:51 am
The older batteries (Pre 2006, maybe 2007) were far superior from what I was reading over on the cummins forum.
The new ones that come in the truck are junk they say (lots of threads on them dying young)
vanished
Post by vanished » Fri Oct 26, 2012 7:50 pm
I was honestly surprised mine is still original and doing good...
Mopar Bob
Post by Mopar Bob » Fri Nov 01, 2013 8:11 pm
Anyone try stuffing a group 65 or 31M in a fourth gen?
PIAA 570s behind grill (to be moved to light bar soon), HID low beams, "cheap bulb" upgrade high beams and fogs, LED tail light and reverse light bulbs, DOR Diff Covers, Warn wireless remote, Magnaflow y-pipe and 22" muffler, AFE Air Filter (stock box) and a Lund Genesis™ Elite Tri-Fold Tonneau Cover covering up the gear.
Post by TwinStick » Sat Nov 02, 2013 12:35 am
I have my Gp 65 under the hood, in stock location with stock hardware & hold downs & no issues.
I have the Gp 31M in my bed tool box. It is a plug & play set up to under hood battery. I charge it after use & every now & again when not using it. No issues. Makes the winch work like it was supposed to. They can draw 400+ amps :jawdrop: at full load.
:rockon:
Fireman78
Post by Fireman78 » Sun Nov 03, 2013 10:01 pm
Yup.. SEARS Diehard Platinum, x 1,000,000,000
The consensous has been made.... :winchmob:
Hilldweller
Post by Hilldweller » Tue Nov 05, 2013 8:23 am
TwinStick wrote:Sears Die Hard Platinum. Made by Odyssey for Sears....
EnerSys makes the DHP for Sears and for Odyssey.
There are quite a few battery companies and quite a few considerations to be made on battery selection. I don't think that internet speculation is a good solid way to go about picking one...
08TwinStickPW wrote:...I have read that the optima batteries have gone to crap and to stay away ...
Pernicious nonsense. I have two D31M Optima BlueTops in my trailer, don't treat them well, and they're working great. I got them directly from the factory in Mexico.
One of the considerations to make about a truck battery that sees severe service is recharge time. Optimas have low internal resistence and charge back up fast.
Cold cranking amperage is another thing.
How well do they handle shock, vibration, trail/work abuse? How are they constructed? How many parts & welds?
For me, an ideal battery set up in a PW is a pair of YellowTops. Just need a bigger tray...
Safety fast,
Bill
Post by Ducky's Dad » Tue Nov 05, 2013 10:28 am
Per my battery supplier, Advanced Battery in Culver City CA, the Optimas have gone to crap in recent years. Advanced sells Optima and Odyssey, among others, and they tell me that they have more failures with Optimas than with their other lines. My personal experience confirms that (small sample), in that I have been running primarily Optimas in three GMC trucks for most of the last 15 years, and I have had short life spans from several of my Optimas, but no mechanical failures of the batteries. My Z71 is currently running two Optima Yellows that replaced a Red/Yellow combo during the summer. The old batteries lasted about three years. A few years ago, there was some discussion about whether Optima Yellows were suitable for starting service (based on early failures reported by multiple sources). I cornered an Optima rep at SEMA and he told me that there is no reason not to use the Yellow as a starting battery, and that in trucks that sit for long periods of time the Yellow is probably better than the Red because it's deep cycle. I use Red or Yellow, depending on what I have in my spares or what I can get on sale. Having said all that, the PW is running a pair of Odysseys, with a 31M 2150 under the hood and a 34/78 1500 under the cab. My first Odyssey 1500 developed a loose connection (mechanical failure, known problem and now supposedly corrected) on one of the terminals and became useless to me because I need all the terminals to work in my application. It was out of warranty when I figured out what was going on, so I keep it on the shelf for emergency backup. The first 31M in the PW was a Sears PL-1, and it developed a bad cell right at the end of the three-year warranty. When I figured out what was going one with that one, I went back to Sears and they told me there was nothing they could/would do, even though it was less than a week out of warranty. Was I pissed? Yes, big time. Called Odyssey to bitch to them about their battery and the treatment from Sears, and they told me to go to Advanced and they would swap out my Sears Pl-1 for a real Odyssey 2150. So, 2/3 of my Odysseys have failed prematurely but Odyssey treated me fairly. Several of my Optimas have failed prematurely, but I'm getting 3+ years out of them and replacement is just a cost of doing business. Moral of the story: They are all crap and you just have to choose the best crap for your needs.
Post by TwinStick » Tue Nov 05, 2013 10:45 am
This is just sad. Who ever would have thought that W-Worlds batteries just might be as good or warranty would be as good & get treated better there, than paying top dollar for a supposedly top-notch battery. Where are Optima's & Odyssey's made now ? In America ? Probably not would be my guess but IDK for sure. :doh:
Hilldweller
Post by Hilldweller » Tue Nov 05, 2013 11:13 am
Ducky's Dad wrote:Per my battery supplier, Advanced Battery in Culver City CA, the Optimas have gone to crap in recent years. Advanced sells Optima and Odyssey, among others, and they tell me that they have more failures with Optimas than with their other lines. ...
I bet that Optima would love to talk to Advanced Battery.
Safety fast,
Bill
Post by Ducky's Dad » Tue Nov 05, 2013 11:47 am
I think Steve at Advanced talks with Optima on a regular basis. They always have multiple pallets of Optimas out in the warehouse. These things sell like hotcakes to the tuner crowd in Los Angeles, and most of the rice rockets with massive audio systems are using Optimas. I'll continue using both Optima and Odyssey until I can find something better for my specific purposes.
verdesardog
Post by verdesardog » Tue Nov 05, 2013 1:13 pm
I have two Ever Start Max batteries from walmart in my CDT. Best product for the money. Sure you can get higher cost batteries but how much better are they? AGM's are nice but hard on alternators.
Hilldweller
Post by Hilldweller » Tue Nov 05, 2013 2:19 pm
verdesardog wrote:I have two Ever Start Max batteries from walmart in my CDT. Best product for the money. ....
Yup; good battery. I have one in my FIAT.
Look up who makes it...
What makes you say that AGMs are hard on alternators?
Safety fast,
Bill
