Discussions including  Electrical / Lighting & Accessories / Onboard Air
								myoung84
						Post
								by myoung84 » Mon Oct 21, 2013 8:20 pm
			JBM Power Wagon wrote:Is it wrong that I feel all warm and fuzzy inside every time there is an update to this thread?
Not at all.
Just to give an update, I am unable to source the 4 pin connector that's a couple feet upstream of the axle plug. I was hoping to use this connector since it will be a cleaner look, but I have to order 1200 connectors and wait 14 weeks if I want them! Ouch! So, we'll just have to take the wiring harness all the way down to the front axle.
								Pit Slave
						Post
								by Pit Slave » Mon Oct 21, 2013 8:48 pm
			verdesardog wrote:WOW! that's a lot of relays. Couldn't you do that wtih some logic circuits and solid state drivers?
Yes you can. Myoung  and I were talking about that today. This is more of a walk before you run solution and using relays is a tried and true method. The logic side of it as well as the driver circuits will come in time as we learn the in depth function on the smart bar electronics.
								Pit Slave
						Post
								by Pit Slave » Mon Oct 21, 2013 8:50 pm
			Haha I had to break for food mid type!
								verdesardog
						Post
								by verdesardog » Mon Oct 21, 2013 8:51 pm
			the relays will probably more reliable too....
									2006 Big Horn 2500 Ram CTD.      IMAGINE ALL THE PEOPLE LIVING LIFE IN PEACE
						Post
								by 04Ram2500Hemi » Mon Oct 21, 2013 9:02 pm
LOL- at least I'm not the only one.
								myoung84
						Post
								by myoung84 » Mon Oct 21, 2013 9:07 pm
			verdesardog wrote:the relays will probably more reliable too....
That was my thoughts as well. The last thing I want is to get 20+ of these out in the field and logic boards start failing. I [will] stand by the stuff that I will build and this makes repairs much more difficult. If a relay or relay board fails, I can ship a new one out and most customers can replace it themselves. Also, say 5 years down the road, I may not be around (I hope I am) and these need to be simple enough for someone else to troubleshoot if there is an issue.
Also, after talking with Pit today, digging into the smartbar itself and controlling the electric disconnect is a much bigger undertaking than the lockers. We're talking replacing circuit boards and that's something most people with warranties won't want to do. What I have planned is going to be very easy to install and remove.
						Post
								by 04Ram2500Hemi » Mon Oct 21, 2013 9:20 pm
			I think for most of us the sway bar is the least of our concerns. I honestly only use the sway bar when I'm messing around- I've actually never needed it. The lockers on the other hand are a huge reason all of us bought the Power Wagon. When I'm in deep snow I need to know the lockers are going to work, not hope they are going to work.
								JBM Power Wagon
						Post
								by JBM Power Wagon » Mon Oct 21, 2013 9:54 pm
			myoung84 wrote:verdesardog wrote:the relays will probably more reliable too....
I don't think we need to change the smartbar. I just like the idea of hardwired lockers and the Evo manual disconnect for the smartbar.
								myoung84
						Post
								by myoung84 » Mon Oct 21, 2013 10:08 pm
			I've got everything figured out and will be ordering parts tomorrow.
						Post
								by 04Ram2500Hemi » Mon Oct 21, 2013 10:29 pm
																			 BlkWgn
						Post
								by BlkWgn » Mon Oct 21, 2013 10:48 pm
			here
My new photography site  - BlkWgn Photography  http://blkwgn.smugmug.com
2006 Dodge Power Wagon production number 44 - Mercenary Offroad Prototype Bumper - Toyo 35 MT  - Caril Springs - Carli Track Bar - Thuren Overland Shocks - Carli Front Diff Guard - RockCrusher Rear Diff Guard - Airflow Snorkel - Locker Bypass - Leer shell w/Roof Rack and 125w Solar Panel - and an empty wallet
								myoung84
						Post
								by myoung84 » Tue Oct 22, 2013 11:00 am
			Parts for the prototype of my "Smartbar Locker Bypass" have been ordered.
																			 ScottWagon1
						Post
								by ScottWagon1 » Tue Oct 22, 2013 12:08 pm
			myoung84 wrote:Parts for the prototype of my "Smartbar Locker Bypass" have been ordered.
Hope his works for the sway bar too. With these new tires I don't have a traction problem as much as a rough ride problem! Having the sway bay disconnected is the biggest ride improvement on the rough roads hunting.
Sent from my iPhone using Tapatalk -
now FreeCarl Scott: Black 2012 PW 35/12.50/17 Nitto Mud Grappler. Thuren control arms. Carli 3" Hmei coils. Carli Track bar. Magnaflow dual inlet/single outlet muffler. Front window tint. Clear Bra. Cold air intake. Hard wired lockers. All options but leather and dual climate
																			 wingerak92
						Post
								by wingerak92 » Tue Oct 22, 2013 12:23 pm
			ScottWagon1 wrote:myoung84 wrote:Parts for the prototype of my "Smartbar Locker Bypass" have been ordered.
now Free
Have people been having issues with the away bad? I haven't had an issue with mine, just the standard locker issue.
I normally disconnect the sway bar when I'm off roading because I have been off camber a few times and without it I would have felt like tipping haha
2012 SAGEBRUSH POWER WAGON SLT
Aluminess Front Bumper, Air Raid Intake, Auxiliary Switches, Hooker Aerochamber Muffler, Stock size Duratracs on Stock Wheels for winters.... For now....
								myoung84
						Post
								by myoung84 » Tue Oct 22, 2013 12:32 pm
			This will not work with the sway bar. After talking with Pit Slave, the electronics for the sway bar disconnect is much more involved.
																			 ScottWagon1
						Post
								by ScottWagon1 » Tue Oct 22, 2013 1:18 pm
			wingerak92 wrote:ScottWagon1 wrote:myoung84 wrote:Parts for the prototype of my "Smartbar Locker Bypass" have been ordered.
now Free
No sway bar issues with me. Been good so far and used it a bunch. Found a truck though-flat ground wheels straight seems to engage and disengage quicker.
																			 BlkWgn
						Post
								by BlkWgn » Tue Oct 22, 2013 1:29 pm
my sway bar has not reconnected in a year and a half
						Post
								by cruz » Tue Oct 22, 2013 8:00 pm
 myoung84, will this mod work on an '05 switch like below ? I don't know what a 4G switch set-up looks like.
								myoung84
						Post
								by myoung84 » Tue Oct 22, 2013 8:27 pm
			Yes and no. The electronics should work but I don't think the plugs under the hood are the same.
																			 wingerak92
						Post
								by wingerak92 » Tue Oct 22, 2013 9:22 pm
now Free
Yeah I always try to find a nice staging area to disconnect/reconnect the sway bar and get set up.
								myoung84
						Post
								by myoung84 » Thu Oct 24, 2013 9:54 am
			For those that are interested, here's the diagram for the plug at the smart bar. If you notice, there's no wires that can engage the sway bar disconnect, it's all internal to the smartbar. Manual control of the disconnect is much more involved than the lockers and would require modifications to the electronics within the smartbar...
Also, I really wish I could purchase the male and female ends of the locker plug. Having a single T harness to insert between the smartbar plug would be awesome!
								Pit Slave
						Post
								by Pit Slave » Thu Oct 24, 2013 11:58 am
			Another thing to note is the pin out on the smart bar is different from year to year.
								myoung84
						Post
								by myoung84 » Sun Oct 27, 2013 8:08 pm
			The plugs showed up yesterday along with 800' of wire! Hopefully the relay board will be here this week...
						Post
								by 04Ram2500Hemi » Sun Oct 27, 2013 9:04 pm
			I like where this going!!!
																			 TrueBlue13PW
						Post
								by TrueBlue13PW » Sun Oct 27, 2013 10:42 pm
			Good luck keep us updated on the status
