Anyone have the Bilstein shock package from 8 lug?
Thoughts about the package offered at 8 lug for a budget OEM 140k mile replacement?
http://www.8lugtruckgear.com/Dodge-Susp ... -p267.html
‘17 AEV Prospector XL
‘06 RCLB Laramie - Gone
Re: Anyone have the Bilstein shock package from 8 lug?
That doesn't seem like a bad deal to me.
Put them on more than a year ago and am happy. Slight improvement over stock and George is always great to deal with........
Black 2006 QC Power Wagon - 315/70R17 Goodyear Wrangler Duratrac's - Bilstein 5100's - Upgraded "T" Steering - Line-X and Drop-in Liner - Eliminator Ultra AGM Battery - Randy Ellis Light Bar - Hella 700FF's - Hella 500FF's - K&N CAI - Locker Bypass - BackRack - Toolbox - Mopar Rock-Rails -
2006 Dodge PW
2005 TJ
2017 Grand Caravan GT
2003 Saturn ION
2008 F550 Dump
1955 CJ-5
2006 Dodge PW
2005 TJ
2003 Saturn ION
2008 F550 Dump
1955 CJ-5
Put them on about 1.5 months ago and am happy. As Pzoeller said slight improvement over stock.
Thanks, yea the stockers are shot and I am looking at all my options. Unsure if I want to spend 2800 on a full kit or 300 or so on something like this which would leave plenty of money left over for other items such as the spendy ball joints and maybe airbags and some new tires.
- Cactus Red
IMO, it was more than a slight improvement. The 5100 is a much better shock than stock - I saw a change in roll control (sloshing) when off road.
Sent via gigawatt laser...
I just purchased some Carli parts from 8 lug and George was great to deal with. You could also get the bilstien 7100 Carli tuned shock package for $1330. I know that's over a grand more, but just wanted to make sure you knew that you don't have to buy the whole kit. In fact, you can't even use the end links and rear leaf packs on the Power Wagon so it's better to piece together your own kit.
The 5100's are a good replacement for the stock Bilstein's. The shock has the exact same hardware with slightly stiffer valving than the OEM shock.
I got the 7100's from 8Lug. Love the shocks.
- GunniPWguy
I bought the 5100's from 8lug a couple years ago as well. OEM's were about toast. Definite improvement in ride quality and they look nicer than the yellow/blue OEM'S IMO.
- wagonfarmer
So... how do you tell if the shocks are bad and actually need replacing?
2006 QC Power Wagon, BFGoodrich AT2
- BigRed2007
Compress one corner of the truck with your body weight if it moves more than down, up, down to original position...they are bad...
Flame Red 07 PW - BIG RED
KE0BZG
WQUY939
KE0BZG
WQUY939
Also look for any oil leakage on the shocks. When the seals start to go bad. You will see some light oil around where the shaft goes into the shock body.
