finickey oil pressure gauge
I just finished a week of vacation driving around Nevada and Death Valley. I posted pictures in the “Get Together” section. I had some problems with my 06 PW…about 3oo miles into the trip my red “Brake Warning” and yellow ABS lights came on, steady at first then intermittently. After a couple of hours they went out and never came back on for the rest of the trip/7 days. So I’m not concerned about that at this time. The other problem was the oil pressure gauge. The first day during the Brake Warning Light issue I stopped for gas – when I started the engine I had a “check gauges” light and zero oil pressure. I checked the oil and re-started and the gauge worked. For the next 7 days about 50% of the time when I started the engine I would have to turn it off then on again to get the gauge to work and check light to go off. Anyway long story-I’m planning on changing the oil sending unit-does anyone know where on the engine it is located? It would save me some time on my back. Thanks Ben.
Re: finickey oil pressure gauge
Yeah, sounds like the sender has a piece of crap in it. To tell you where it's at. I don't know.
From the picture I have of the engine, it looks as though its just above the oil filter.
Rausch Creek Spring '12
delete...
Mine does the same thing. Been like that for 6 months. Have to shut it off and start it back up and then it works. Let me know If that fixes the problem.
thanks coder...did I read that there is an oil temp gauge option?
OK I goofed, ignore the previous post that is for an SRT10 only, the SRT10 has the oil temperature sensor not the 5.7.fbenross wrote:thanks coder...did I read that there is an oil temp gauge option?
Here is the 5.7 oil pressure switch location and testing procedure.
all right -thanks again !
I put the new OEM oil pressure sending unit on today. Very easy, you just need channel locks. I really won't know if that was the problem till I put some miles on it. The OEM part # for a 2006 is 5149097AA.... NAPA $52...Dealer $42...MoparPartsOverstock.com around $30 delivered...
Good to know Ben, thanks. Keep us posted if this fixes it.
