I don't know if I have the correct front shocks for my 2007 Power Wagon.
The old shocks are original OEM Bilsteins. The old rear shocks (P/N 52121458AD) are an exact match to the new Bilstein 24-186094. The old front shocks (P/N 52121970AA) are an exact match EXCEPT the extended length is almost 3 inches longer than the new Bilstein 24-186070.
If I look up front shocks on the Mopar website it comes up with P/N 5179653AA, which crosses to the same Bilstein 24-186070 on Bilstein's website.
It seems that the new Bilstein front shocks are wrong. The 24-186070 shock says it also fits the non-Power Wagon 2500.
I emailed Bilstein and after several days they replied saying that I should use the B8 5160 series 25-311754.
I want to stay with the original 4600 series. Does anyone have any input on this?
Thank you.
2007 front shocks
Powerlinefixer
2007 front shocks
2007 Power Wagon, G56 Six Speed
2005 Dakota Crew Cab, 4.7, Getrag 238 Six Speed
1983 Ramcharger, 5.9 Cummins (1992.5), NV4500
1942 Dodge WC, 1/2 ton 4X4 Pickup, Military
Re: 2007 front shocks
When we replaced ours on our 2005 PW running 35’s went w the B8 5160 front & back & everything worked fine. Is your rig lifted or have a leveling kit? That may make a difference,,,
Most replaced the oem shocks with something. Like the 5100, 5160. I went to the 7100's with remotes. Then to custom Kings. The stock oem's are a bit under dampened.
Powerlinefixer
It's 100% stock. No lift or leveling kit.
Powerlinefixer
Nice.
