Mud flaps
Mud flaps
Simple question. Mud flaps or not? I got a new leftover 2024 Tradesman with Power Wagon package. It’s black so I’m debating on mud flaps or not.
2024 Tradesman w/ Power Wagon package Black on Black
35” Goodyear Wrangler Boulder MT tires
Real Truck Swing Case
Katzkin leather
Go Rhino Dominator DS Sliders
Katzkin leather
Re: Mud flaps
If you do serious off roading, I vote
NO TO MUD FLAPS, because they'll get ripped off on the first major obstacle. Even if you don't do off roading, if the mud flaps are too long and you back up into a pile of snow or mud, that could push the mud flap up against the tire rotating backwards and rip it off.
If you just do street/highway driving,
YES TO MUD FLAPS.
NO TO MUD FLAPS, because they'll get ripped off on the first major obstacle. Even if you don't do off roading, if the mud flaps are too long and you back up into a pile of snow or mud, that could push the mud flap up against the tire rotating backwards and rip it off. If you just do street/highway driving,
YES TO MUD FLAPS.2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Full SmartBar Bypass®, Abel Components Nanny Kill Switch®, 2000 Watt ProMariner TruePower Plus Pure Sine Wave Inverter, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God, Share the Umbrella, Make sure you're right with God before you meet him!
Re: Mud flaps
OP,,my $0.02,,,,Retired BLM Rig x 2,,,imho Exellent advice! Enjoy
!NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Re: Mud flaps
I had mud flaps from day one on my 08 PW. Did Moab, Rausch Creek and Hot Springs with them on. Never had one get ripped off. I used a flexible material. I have Weathertech on my Gladiator. I've done the same trails as the PW. Never had get ripped off either, but they do show signs of the trail.
Re: Mud flaps
You're lucky becuase I have watched them get ripped off on other peoples trucks at Power Wagons in Moab.
But I also got all my dents from trees in Idaho where there is no rock crawling and some how not in moab. Draw of the luck.
I'd vote no though, becuase I think there is a greater risk of them getting torn off if you do offroading and DO NOT have clearance. I think the risk is higher when you are on smaller tires.
Re: Mud flaps
I had them on my Ranger, when the rears ripped off they damaged the body. When I built the flat bed for my second gen I built some removable mudflaps to go on Ultimate Adventure 2004 since there was a lot of states that required something (especially since my "fenders" basically ended at the axle. I ended leaving them behind on the trailer when the tow rig blew up and never really used them. I was only harassed in northern Minnesota and even then it was basically the police wanting to take a look at the truck. They basically said if you don't track mud on the road we don't care. (we were rock crawling so no mud to track.)
I haven't ran them on tow rigs or wheelers since.
Re: Mud flaps
Inly if they are required by law or you notice issues.
Re: Mud flaps
I did not install mud flaps on my 2014. The rocks, gravel, and salt did some serious paint damage to the lower rockers and also peeled off the line-x on the front of my WK sliders.
I installed the rubber OEM RAM mud flaps on my new 2024. No real off roading yet, so TBD effectiveness. So far, they’ve kept my truck cleaner and my new WK sliders aren’t beat up, yet.
