Rebuilt Valve Body
				unitedwagon
Rebuilt Valve Body
Hey guys, been a long time. My wagon needs a replacement valve body. I've narrowed my choices right now to the Nextgen Economax, or the Revmax towing H.D. unit. Anyone have a review on either unit? I.m leaning towards the Economax because I like the idea of an anodized switch valve bore. Thanks
				unitedwagon
Re: Rebuilt Valve Body
Well, I guess I'm the guinea pig. I just ordered one yesterday. I'll post an update when installed.
2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Full SmartBar Bypass®,  Abel Components Nanny Kill Switch®,  2000 Watt ProMariner TruePower Plus Pure Sine Wave Inverter, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God,  Share the Umbrella, Make sure you're right with God before you meet him!
				unitedwagon
So, last weekend I installed the unit from Nextgen Drivetrain love it. After the quick learn took a long test drive and it 100 percent took care of the P0871 code and super clunky shifting in the upper gears. After many stop and go light throttle runs to perform the drive learn it really feels tight. My original valve body had been "massaged" by the shop that rebuilt the trans at 160K and had developed problems and pressure leaks... honestly it never felt right but they insisted it was fine, it also worsened over time.  Looks like I caught it soon enough as the fluid was still fresh and there was absolutely no debris of any kind in the pan. It's probably the cleanest pan I've been in with 35K miles of use.
 Congratulations! Am glad to see your problem appears resolved.
 SOLD: Never forgotten: Mule - 2005 Power Wagon, “Laramie”
 SOLD: Never forgotten: Mule - 2005 Power Wagon, “Laramie”NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
