Transfer Case Position Switch
Chubbs
Post by Chubbs » Fri Oct 11, 2024 7:47 pm
My 2018 PW is regularly getting the "4wd shift in progress" message. My assumption is the transfer case position switch. Unfortunately, I can't see how to operate the catch on the wiring harness. Anyone know a trick for releasing the harness when the catch side is opposite of what can be seen?
2018 Power Wagon
Re: Transfer Case Position Switch
Post by Mule007 » Fri Oct 11, 2024 10:42 pm
Good evening ,,,,,if you contact David, Retired BLM rig,,,,his contact info can be found in our Marketplace, Vendors, Able products. He is Able Products & is very knowledgeable on our rigs & is quick to respond & help.
Post by Retired BLM Rig » Sun Oct 13, 2024 1:24 am
The latch pivots when you squeeze it.
Apply pressure by squeezing the very top of the latch.
This will lift the latch off of the locking tab on the face of the connector. The problem is that the connector faces down, which allows grains of dirt and sand to get trapped in the latch area, inhibiting movement. The best thing to do is use compressed air and a blowgun to try and clear that debris out of the area so the latch moves freely.
You could also try to get a small dental hook tool under the face of the connector and pry out gently.
If you break the connector, you can find a replacement by searching for a "Toyota ignition coil connector" on Amazon or Ebay.
Toyota part# 90919-02216 or 90919-02205.
Good luck! :patriot:
SimonandSimonBeast
Post by SimonandSimonBeast » Sun Oct 13, 2024 2:04 am
I also find with these connectors that if I apply some prying pressure with a broad flat head screwdriver on the face of the connector while I press the latch and pull at the same time with the other hand, they come off without damage. This allows the latch pressing hand to concentrate on pressing the latch while the screwdriver assists with overcoming the grit and applying pressure in the right direction to push the connector off. Just be real careful so to don't pull a wire or crack the connector.
:rockon: :chug:
Chubbs
Post by Chubbs » Sun Oct 13, 2024 11:59 am
This is exactly what I needed. I knew I had to apply pressure to release the latch, but I was pushing on the lower section.
I'll get under the truck later today and see if I can get it off.
2018 Power Wagon
unitedwagon
Post by unitedwagon » Tue Nov 12, 2024 12:10 pm
Is this switch adjustable? Mine has been doing this since a trans rebuild. I kind of figured there was some adjustability, but maybe it's just faulty
Post by RustyPW » Tue Nov 12, 2024 7:39 pm
Nope. Screw it down tight. That's it.
