Another Government Wagon Auction
Re: Another Government Wagon Auction
Here's a 2016 in Montrose, CO. It looks like the winch is missing, along with the center console. It also says that it needs an engine because of low compression on the #7 cylinder. Lots of problems, so this one might sell pretty cheap.
For you guys in the northeast, here's a 2017 in Swanton, VT. It says the winch doesn't work. Not much other information.
So the 2017 in Swanton, VT (one post above) didn't meet the reserve price, so they're listing it again. Here's the new link:
https://gsaauctions.gov/auctions/preview/295945
Here's a 2018 in Shoshone, ID. Comes with side steps just waiting to get ripped off on the first obstacle you encounter.
Its also missing some center console pieces due to having law enforcement equipment removed.
Edit: Closed for $22,185.
A 2020 in Meeker, CO. It has an aftermarket front bumper, high milage and lots of holes in the body.
Edit: Closed for $14,000.
Third time's a charm?
This is the third time they've listed this 2017 in Swanton, VT. They're having a hard time reaching their reserve price, hopefully they keep dropping the reserve each time they list it. Maybe someone will get a good deal this time.
Here's a 2012 in Fritch, TX. Looks like it has an LE console, steps and a dead battery.
Edit: Closed for $10,487.
Here's a 2013 in Atlanta, GA. Looks like it has pretty low miles and they say the 4X4 doesn't work, so it's either the transfer case or the lockers.
Edit: Closed for $11,111.00 (Reserve Not Met).
Here's a 2018 in Moab, UT. Missing the center console and possibly the winch (can't tell in the picture).
Here's a 2019 in Montrose, CO. with a RamBox. Missing the winch, lots of damage inside and out from law enforcement equipment that was removed, not to mention high milage. Not bad if you're looking for a trail ready beater.
$14.5K for 6 yrs old, 112k miles, beat all to hell tradesmanRetired BLM Rig wrote: ↑Sun Mar 16, 2025 12:25 amHere's a 2019 in Montrose, CO. with a RamBox. Missing the winch, lots of damage inside and out from law enforcement equipment that was removed, not to mention high milage. Not bad if you're looking for a trail ready beater.
- Strip LEDs
- New style tie down cleats - Garmin Power Switch Powering:
Here's a 2020 in Gila Bend, AZ. Missing the center console and has high milage. It doesn't look like the hook was ever installed on the winch.
Here's a 2018 in Winnie, TX. Has a RamBox, needs a transmission, five pending recalls and is missing the center console.
A couple of 2019s up for auction this week:
- Here's one in Columbia, SD. Missing the center console and high milage.
- Next one in Moab, UT. Also missing the center console, used for law enforcement. Off road usage impacts (I wonder how that happened in Moab?).
