2008 Winch repair/rewire help
				UncleYarbie
OK,
So I pulled my winch the other day so that I could go about removing the LVI and TPS. When I purchased my truck the winch never functioned as the previous owner said the LVI was out. My main cables from the battery were already removed and zip tied out of the way.
First I know where the ground goes but which solenoid does the battery +cable go to?
Second I understand the one cable gets wired out of the LVI circuit. Is it the red wire that's going to the controller that's supposed to go directly to the ground?
Third- I pulled the motor out and pulled the wires off the TPS it should work with that completely unwired right? I just need to jumper the return? Or do I also need to bumper either side of the TPS? I would think if it's not being used it wouldn't need current through it right?
My case was severally corroded so I am cleaning and painting it along the way. Here's a few pictures of that I'm doing and the wires in question
This truck was originally from Marysville Washington, I purchased it from the 2nd owner in Colorado and brought it back with me to Idaho. The rest of the truck hardly has corrosion or rust but for some reason the winch got ugly
Jeff
Jeff
2008 PW QC G56
Re: 2008 Winch repair/rewire help
Some where here on the forum is a complete diagram of the winch. Where? I don't know.
I have the 38 page factory diagnostic and repair manual supplement for the PW winch. This forum doesn't support the PDF file format, so I'll email it to you.
									2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Full SmartBar Bypass®,  Abel Components Nanny Kill Switch®,  2000 Watt ProMariner TruePower Plus Pure Sine Wave Inverter, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God,  Share the Umbrella, Make sure you're right with God before you meet him!
Based on this picture from page #29 of the manual, it looks like you're missing a bus bar between solenoid #1 & #3 and the positive battery cable is supposed to connect to the outer terminal of solenoid #3.
				UncleYarbie
I have that bus bar, I was taking everything apart and cleaning the connections at the time. That's the info I needed though, I appreciate it.
Thank you
									Thank you
2008 PW QC G56
				JRHPWRWAGON06
Will send you a PM for the PDF...Retired BLM Rig wrote: ↑Mon Feb 13, 2023 9:57 pmI have the 38 page factory diagnostic and repair manual supplement for the PW winch. This forum doesn't support the PDF file format, so I'll email it to you.
OPTIONS-
MODS-
						OPTIONS-
MODS-
Hate to Hijack. Would anyone have a copy of the winch wiring for a 2015.
				Sierra1boy
Same question for a 2005, and also not trying to hijack. thank you
This forum doesn't support the PDF file format. If you send me an email, I'll forward you the PDF factory service manual supplement for the Warn/PW winch. AbelComponents@yahoo.comSierra1boy wrote: ↑Sat Dec 09, 2023 9:53 pmSame question for a 2005, and also not trying to hijack. thank you
						- SimonandSimonBeast
Once you have the winch hooked to power, hook up the remote and power it one direction or another.   If you hear strong clicking, your solenoids  are most likely good.  While powering in one direction take a mini-sledge to somewhat forcibly tap the motor housing to see if it frees up the motor to start operating.
