Is this place still alive?
Still check once in awhile. Not a lot of new stuff regarding 3rd Gen trucks.
Just under 75,000 miles on my truck.
Preview
AEM Brute Force intake
Gibson CAT back exhaust
Super Chips Flashpac Tuner
Wet Okole seat covers
Line-X bed coating
Trac Rac Sliding Lumber Rack
H2 rims
Line-X bed coating
H2 rims
			Morning.
 good morning !NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
				gtomike60
Good morning guys!!
									2012
			Up right and breathing.
				gtomike60
2012
 top of the morning!NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Good Evening
I guess she identifies as a cat
			Talk about taking it down the throat.
			Just wonder if that critter has been in other holes on her body.
2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Full SmartBar Bypass®,  Abel Components Nanny Kill Switch®,  2000 Watt ProMariner TruePower Plus Pure Sine Wave Inverter, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God,  Share the Umbrella, Make sure you're right with God before you meet him!
			I'm alive and kicking.
Thanks...22 I picked up in Knoxville TN...came with airbags.. couldn't pass on it ...for me was a great deal...I've been looking ..8k miles...
The 05 I've owns for 12 yrs...not abused at all...my hunting truck...past 2yrs it received:
Carli balljoints,trackball
Thuren springs,control arms and tuned fox shocks
Powerstop rotors and pads
Raybestos front calipers(new),SRT rear calipers
Spicer axle u joints
SKF hub bearings
PSC steering box,oem cooler
EMF STEERING KIT, shaft bushing
OEM fuel pump
OEM water pump,thermostat
OEM power steering pump
New alternator, battery,starter
About 6k miles on all ...
 good luck & hope the 22 is as good to,you as your ‘05 was!NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
 have a Great day!NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
