I have a 2016 Ram Powerwagon Laramie with 111,000 miles. It’s been the best vehicle I’ve ever owned. I’ve been running Cooper Discoverer STT Pro’s 285/70r17. I’m considering going to 35’s with my original wheels. According to Coopers website, the 315/70r17 will work. Has anyone done this? Will I notice a big change with gearing or gas mileage? Will I have any rubbing?
Eddie
Running 315/70r17 on 2016 Powerwagon
Re: Running 315/70r17 on 2016 Powerwagon
I'm running 35s on my 2016. The 315/70 setup is very similar. Fitment wise I had 0 rub. The gearing could be better. It does tend to lug around town, especially up hill. The rpms drop too low and until they build up or you lay harder into the pedal it doesn't wanna move. Mileage I lost about 2mpg, I avg 12-13 overall. The look of 35s over 33s or factory 285 is night and day tho. I have modified the truck best I could without re gearing just yet. The truck has plenty of power, dont get me wrong, just a little annoying having to open it up and roar it all over town.My opinion may be a little tainted as I daily drive a cummins on 35s. Totally different animal and sets me back when I get into the wagon. I have learned to live with the shortcomings of the 35s and I would never go back. Too many positives over negatives in my opinion.
2016 flame red slt
S&B cold air intake
Mufflex muffler delete
Moes 87mm throttle body/afe spacer
Diablosport pulsar tuner
Abel components full smartbar/nanny killswitch
Purple cranium front and rear half spider guards
Dethloff mfg rear sway bar spacer kit
Dodge offroad steering brace
Thuren front and rear track bars
Thuren 1.5 front coil springs
Thuren front and rear sway bar endlinks
Thuren king steering stabilizer
Bilstein 5100 front and rear shocks
Thuren front boogie bumps
Synergy drag link and tie rod
CJC method gold 315s nitto 35 ridge grapplers
Powerstop z36 front and rear brakes and rotors
Retrax pro xr bed cover
Optima yellow top
Randy ellis front light bar mount 30" rigid bar
Rigid dual pod fog lights
Rigid d2 pro rear bumper lights
Led hi/lo headlights leds through entire truck
Arb twin on board air desert does it seat mount
Uniden cb firstik antenna
Factor 55 2.5 hitchlink and ultra hook
Weathertech front and rear floor mats
*Future*
White knuckle sliders
Yakima overhaul hd rack
Leather heated seats
Rigid ditch lights
Dethloff mfg transmission skid plate
S&B cold air intake
Optima yellow top
*Future*
Rigid ditch lights
Using a tuner/programmer will recalibrate your speedo and bring your transmission shift points back into their proper range and you'll recover some of that lost MPG and performance. These trucks look anemic until their wheel wells get filled with rubber. 315s/35s are the first step in the addiction.
Welcome to the forum!
