Clunking universal?
AceMan
Site Admin
Site Admin
Re: Clunking universal?
Post by AceMan » Thu Jul 19, 2012 3:44 pm
Oh, that thing. I keep that greased at least twice a year. I forgot to do it this year.
Power Wagon Owner's Club #110
Black '06 PW QC
Image Image Image
pdavey
Post by pdavey » Fri Jul 20, 2012 2:00 am
FirerescuePW wrote:
ABFargo wrote:Nope, front driveshaft.
Early d-shafts had no grease zerk.
Gen 4 front d-shafts have a needle zerk, allowing the centering ball in the CV to be greased, prolonging life.
Re: front axle u-joints, normally get 50-70,000 out of them as well.
Good front axle shaft upgrade is RCV replacement axle shafts. (minor thread jack)
If you are talking about a grease zerk on the double cardan joint, PWs have always had them. I have an '05, and there is even a warning decal on the rad support directing mechanics to find it and grease it.
Sent from an undisclosed location.
Problem is it is like the "G" spot, you can only find it if you are an "expert" :)
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
AceMan
Site Admin
Site Admin
Post by AceMan » Fri Jul 20, 2012 11:24 am
Lol! Just close your eyes. You'll find it!
Black '06 PW QC
Image Image Image
pdavey
Post by pdavey » Sat Feb 02, 2013 4:28 pm
Resurrecting this thread. I am not sure what is going on with my truck. Just a string of unrelated issues.
I have a clunking coming from the front passenger side of the truck when I turn the wheels side to side from center. I can feel it on the tire and sounds like it may be a steering linkage, bit thought I would see what the group thought. Could it be a linkage, u-joint?
It doesn't take a lot to make the noise and it seems loudest from center to the left but clunks as you pass left and right it seems, but it is only one clunk............
Sent from my DROID DNA
Performance Mods:
Other Mods:
Style/Other Mods:
Post by TwinStick » Sat Feb 02, 2013 9:58 pm
My moneys says u-joint, tie rod end, ball joint (all the weight is on the bottom ball joint), trac bar bushing or possibly a unit bearing: in that order.
SilverWagon05
Post by SilverWagon05 » Sun Feb 03, 2013 7:21 am
TwinStick wrote:My moneys says u-joint, tie rod end, ball joint (all the weight is on the bottom ball joint), trac bar bushing or possibly a unit bearing: in that order.
X2
VA_Wagon Man
Post by VA_Wagon Man » Sun Feb 03, 2013 8:36 am
I'm going another direction to check out. I know you have Thuren control arms, but if the bolt was to loosen any little bit, you will get some 'slop' where the bolt goes through the lower arm, and it'll pop or clunk sometimes. Does it do it at all while moving or applying your brakes?
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
pdavey
Post by pdavey » Sun Feb 03, 2013 12:59 pm
VA_Wagon Man wrote:I'm going another direction to check out. I know you have Thuren control arms, but if the bolt was to loosen any little bit, you will get some 'slop' where the bolt goes through the lower arm, and it'll pop or clunk sometimes. Does it do it at all while moving or applying your brakes?
Good thoughts. Will check it all out.
Sent from my ASUS Transformer Pad TF700T using Tapatalk HD
Performance Mods:
Other Mods:
Style/Other Mods:
Throttle 8
Post by Throttle 8 » Sun Feb 03, 2013 4:08 pm
Did you check the blinker fluid? :cheers:
VA_Wagon Man
Post by VA_Wagon Man » Sun Feb 03, 2013 6:01 pm
Among the long list, including the blinker fluid, check out the bearings in the glove compartment hinges. I hear they're prone to failure. :popcorn:
Long Gone:
pdavey
Post by pdavey » Mon Feb 18, 2013 3:09 pm
So I finally was able to take some time to troubleshoot the problem. Appears the clunking is coming from my track bar. I lifted the truck up and tightened the track-bar to spec, plus greased it and it is still happening. I have the Thuren track-bar so I am going to email Don and see if he has any suggestions. Sounds like the joint might be too loose. Will keep you all posted.
Performance Mods:
Other Mods:
Style/Other Mods:
AceMan
Site Admin
Site Admin
Post by AceMan » Mon Feb 18, 2013 4:16 pm
Sounds like a loose or wrong size crush sleeve. It maybe the bushing was the wrong size. I had the sane problem with my Carli. Finally got the right one. I wound up drilling the hole out for a 16mm setup, got a new bolt kit from Chrysler, and put close to 275-300 on the bolt, per Russ' recommendations.
Sent from my Galaxy Nexus using Xparent Skyblue Tapatalk 2
Black '06 PW QC
Image Image Image
AceMan
Site Admin
Site Admin
And changed my blinker fluid while I was at it.
Black '06 PW QC
Image Image Image
pdavey
Post by pdavey » Wed Feb 20, 2013 7:25 am
AceMan wrote:Sounds like a loose or wrong size crush sleeve. It maybe the bushing was the wrong size. I had the sane problem with my Carli. Finally got the right one. I wound up drilling the hole out for a 16mm setup, got a new bolt kit from Chrysler, and put close to 275-300 on the bolt, per Russ' recommendations.
Don also seems to think the bolts aren't tight enough. Based on how much you tightened yours down Ace, mine isn't even close. I am only at 150ftlbs per the spec in the FSM. Don is recommending 180 ftlbs.
The oddest thing is that it wasn't doing it until about a month ago, so something was keeping it tighter. Sounds like I will be back out in the garage this weekend tightening the bolts :)
Performance Mods:
Other Mods:
Style/Other Mods:
pdavey
Performance Mods:
Other Mods:
Style/Other Mods:
MSparks909
Post by MSparks909 » Wed Feb 20, 2013 9:14 am
My Thuren tracbar also clunks. Bushing at the frame end is worn out (45K miles on it). I'm replacing the bushing today actually. Frame end bolt is torqued to roughly 200ft./lbs. and it still moves when I grab the bar and wiggle it back and forth. Don recommends replacing the bushings roughly every 40K miles. Figure I can have my bushing replaced in under 10 min :rockon:
2006 QC PW G56
pdavey
Post by pdavey » Wed Feb 20, 2013 12:17 pm
Hmmm. Odd that he hasn't recommended that to me. I will try tightening and it it still does it will replace. How much did he charge you for replacement bushings?
Performance Mods:
Other Mods:
Style/Other Mods:
MSparks909
Post by MSparks909 » Wed Feb 20, 2013 4:21 pm
I honestly don't remember. I bought some other stuff from him at the same time and the cost slipped my mind. I want to say it was pretty cheap IIRC.
2006 QC PW G56
pdavey
Post by pdavey » Sun Feb 24, 2013 5:30 pm
MSparks909 wrote:I honestly don't remember. I bought some other stuff from him at the same time and the cost slipped my mind. I want to say it was pretty cheap IIRC.
Well I tightened the bolts to 200 ft lbs and it still clunks so it may be the bushings. I sent Don an email to get his thoughts as well.
Performance Mods:
Other Mods:
Style/Other Mods:
MSparks909
Post by MSparks909 » Tue Feb 26, 2013 2:34 pm
It's probably the bushing. After my truck gets out of the transmission shop I'm swapping the bushing out.
2006 QC PW G56
pdavey
Post by pdavey » Wed Feb 27, 2013 12:41 pm
He thinks it is the bushings as well and is sending me a new set.
Performance Mods:
Other Mods:
Style/Other Mods:
pdavey
Post by pdavey » Fri Mar 22, 2013 11:05 pm
Swapped out the bushing on the trackbar and the clunk is gone.
Performance Mods:
Other Mods:
Style/Other Mods:
Post by coder » Sat Mar 23, 2013 7:50 pm
pdavey wrote:Swapped out the bushing on the trackbar and the clunk is gone.
Was it the bushing on the drivers side at the frame?
pdavey
Post by pdavey » Sat Mar 23, 2013 11:40 pm
Yes. The one on the frame.
Performance Mods:
Other Mods:
Style/Other Mods:
