Steering box
Steering box
Doing a overhaul on my front end....have factory steering box....i would like to change...05154349ab mopar item...will this box work?...found one for 350$...going to use EMF steering set up also....any suggestion on steering box...?..or should I purchase this ...?...
Re: Steering box
I'm using a PSC steering box. It's the same as the 6 bolt top cover of the newer 3G boxes. It's been in the truck since 2009. When I broke the oem box in Moab.
Re: Steering box
Rusty would you know if a box from an 2012 or newer 6 bolt...work ?..yes pitman arm has to be change . But is there any differences from a Mopar upgrade box and 2012 and newer?
Re: Steering box
If I remember right. Someone did the swap, think they had to drill out the bolt holes bigger. Don't really sure.
Re: Steering box
Geez....ain't doing that....Rusty hows PSC holding up?..
Re: Steering box
It's been doing great. Never had any issues with it.
Re: Steering box
Sounds good.. thankyou
Re: Steering box
I have 4 trips to Moab and 10 trips to Rausch Creek with the PSC box.
