Aftermarket ball joints?
jeep_boy02
Post by jeep_boy02 » Thu Mar 11, 2021 10:53 pm
Getting ready to tear into the front end. Have just over 120k miles on all factory components. I'm leaning towards synergy stuff, mainly ball joints and a track bar, may go with thuren on the bar. What's y'alls experience with the rebuildable bjs on the market and what/why would you reccomend?
pdavey
Re: Aftermarket ball joints?
Post by pdavey » Thu Mar 11, 2021 11:40 pm
What year is your PW?
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
jeep_boy02
Post by jeep_boy02 » Thu Mar 11, 2021 11:50 pm
'10 on 35s. Future 3" coils, LAs, and 37s
pdavey
Post by pdavey » Fri Mar 12, 2021 12:05 am
The Carli ball joints would be my suggestion on that rig. That said if you are at that mileage and the mopar ball joints worked that well why the hell not this another set in for half the price.
If you spend the extra money on a new track bar from Carli or Thuren and and a king steering damper from Thuren you may get 200K out of the next set of mopar ball joints.
The one thing about suspensions and big tires I have learned is rubber bushings are the devil.
Performance Mods:
Other Mods:
Style/Other Mods:
Post by RustyPW » Fri Mar 12, 2021 9:14 am
My Carli ball joints are still going strong. Have about 60,000 miles on them, and they are still tight. :rockon:
VMAX
Post by VMAX » Fri Mar 12, 2021 11:32 am
I just installed the Carli ball joint at 75000 on the original Mopar ball joints on my 2012. running 35's and maybe going with 37's or bigger tire soon.
I plan on keeping this truck and thought it was a good investment / upgrade. I had no issue with them and no regrets.
jeep_boy02
Post by jeep_boy02 » Fri Mar 12, 2021 1:17 pm
So I did a little shop comparing last night...
Mopar - $306
Moog - $160
Tera-flex - $265
Synergy - $350
Carli - $800
Dynatrac - $800
At those price points not go synergy? Why are the carli and dynatrac ones twice as expensive? They are all 3 rebuildable, and unless you're cheap they seem the most sensible.
SeppW
Post by SeppW » Sun Mar 14, 2021 8:35 pm
EMF are rebuildable too. Would be the last ball joints installed. OEM are pretty good too if price point is a consideration. Assume this is a DIY chore. The last time I had ball joints replaced on a 2500 'Burb was $900 parts and labor, 15 years ago. I bet it's significantly more today.
Post by RustyPW » Sun Mar 14, 2021 11:17 pm
Stay away from any ball joints that are splined unless you want to ruin your axle. The splines on the ball joint ruin the hole that the joint sits in.
jeep_boy02
Post by jeep_boy02 » Sun Mar 14, 2021 11:40 pm
I believe EMF makes Carli's, so they're probably the same. And yes the splines or knurled BJs are only for use in a hole that a smoothie is loose in.
I have still yet to jack the front up and test any of the joints, hubs, etc so this is just a shopping comparison and questionnaire. But I'll most likely go with the synergy ones.
Post by RustyPW » Mon Mar 15, 2021 12:49 am
EMF doesn't make the Carli joints. Carli was the first on the market with the ball joints and are not rebuildable.
Ak68w
Post by Ak68w » Mon Mar 15, 2021 10:11 am
I did the EMF’s probably 20k ago and have had no trouble.
jeep_boy02
Post by jeep_boy02 » Mon Mar 15, 2021 10:13 am
Must of been thinking Thurens then but Thuren just sells EMF... IDK.
Post by coder » Tue Mar 16, 2021 7:53 pm
I have Dynatrac ball joints on my truck. I got 10 years and them for 150k miles out of them before I rebuild them last summer. The lowers where a little loose the uppers were still tight. I put a fair amount of hard off road driving on them and them and they held up very well, I highly recommend them.
jeep_boy02
Post by jeep_boy02 » Tue Mar 16, 2021 8:47 pm
Thanks for the reply coder. I remember you from before, good to see you still around. Right now I just can't justify $800 for ball joints, but half that I can
