Post
by Reloaderguy » Fri May 06, 2016 9:08 pm
There seems to be a lot of discussion about what is so special about Power Wagon wheels but I have never seen pictures of the beads. I have my wheels broken down so I thought I would take some pictures of the outer and inner beads. These wheels are off of a 2016 model year truck.
Outer:
Inner:
Post
by RustyPW » Fri May 06, 2016 9:14 pm
Yep, looks the same as a 3G.
My build thread.
http://forum.powerwagonregistry.org/vie ... =13&t=2826
walc
Post
by walc » Fri May 06, 2016 9:22 pm
Interesting.
Thanks for taking the time to post.
2016 Power Wagon SLT
- Model Year: 2010
Post
by Will » Fri May 06, 2016 9:23 pm
And the axle will give before the rims!
Post
by nts007 » Fri May 06, 2016 9:30 pm
The pw rims are heavier than the regular alloys. It's noticeable when you hold them side by side. 3-5 lbs I would guess. Reloaded guy can you throw one on a scale. I'll throw a regular dodge alloy from a 12 on a scale tomorrow and we will maybe get a real number
Post
by RustyPW » Fri May 06, 2016 10:12 pm
Make sure it's lbs, not kilo's. I hate to convert.
My build thread.
ramv
Post
by ramv » Fri May 06, 2016 10:23 pm
I have got a bunch of trashed 2500/3500 3rd gen non PW rims lying around. I'll have to take a look to see how they compare to the PW wheels. I blew beads and broke wheels all the time with them. Total junk. My 2nd gen 1500 wheels were much better (broke a few, but seldom lost a bead).
Post
by nts007 » Fri May 06, 2016 10:29 pm
21lbs ish on the 2500 alloys. Is says 22ish I know but I was holding the rim gently at an angle to get the pic and it bumped up a hair
nts007 on Fri May 06, 2016 11:36 pm, edited 1 time in total.
fbenross
Post
by fbenross » Fri May 06, 2016 11:33 pm
I have 24 lbs for my 2006 rims and 34 lbs for the spare steel rim.
2006 Power Wagon-6spd, rear air bags, Diff Guards:Carli F. RockCrusher R., matching rim for spare tire, removed back seat for storage----I own the following: 2005 Hallmark pop-top Camper---1970 Scout 800 4x4 w/232ci 6cyl 4spd---2006 Yamaha XT225 Dual Sport---Pictures @
https://www.flickr.com/photos/powerwagon/collections
Post
by Low_Sky » Sat May 07, 2016 12:25 pm
Thanks for posting these pics, Reloaderguy. I'm still on the factory tires, and haven't had a chance to see the inside of our wheels yet.
Post
by Reloaderguy » Sat May 07, 2016 3:13 pm
nts007 wrote:21lbs ish on the 2500 alloys. Is says 22ish I know but I was holding the rim gently at an angle to get the pic and it bumped up a hair
I think the older wheels weigh a lot more. My postal scale says .4oz.
Post
by nts007 » Sat May 07, 2016 7:56 pm
Lol that's good pocket weight
Here's the non pw bead seats
Post
by coder » Sun May 08, 2016 6:32 pm
I have a copy of the 07 wheel specs from Mopar. The PW wheel weight is right at 23.0 lbs, all the other aluminum wheels are between 23-24 lbs.
Post
by Reloaderguy » Sun May 08, 2016 7:31 pm
I think the new wheels weigh more because the hubcaps are integrated into the wheel instead of the old large removeable section.
Post
by cruz » Sun May 08, 2016 7:36 pm
Reloaderguy wrote:I think the older wheels weigh a lot more. My postal scale says .4oz.
So does this make a 2005 Made in America Alcoa wheel the heavy weight ?
btsbarton
- Model Year: 2019
Post
by btsbarton » Thu Jan 21, 2021 7:52 pm
Just wanted to revive this thread to say it doesn’t look like the newer style (black) wheels have as much bead as the older wheels, this wheel is from my 2019...
I might have to consider swapping for an older Alcoa set...I like the look of the silver wheels a bit more too
jeep_boy02
Post
by jeep_boy02 » Thu Mar 11, 2021 9:27 pm
^ man that's a bummer, doesn't look different at all from a normal bead.
Alakablamo
Post
by Alakablamo » Fri Mar 12, 2021 6:27 pm
I noticed that the Method Trail series wheels have something similar to the PW bead retention nub, plus some biting ridges at the bead itself. This isn't a recommendation for their wheels, as I don't actually own a set, but curious how much it helps retain the bead in low pressure situations.
jeep_boy02
Post
by jeep_boy02 » Fri Mar 12, 2021 6:36 pm
Better than nothing but there still I isn't a "raised inner (safety) bead"
