2015 Front Axle Nut Size
NickTF
Post by NickTF » Tue Oct 06, 2020 12:55 pm
After 94k (from 26k to 94k with 37s), looks like it's time for a new wheel bearing front driver side. Can someone indicate the size of the front axle nut so I can make sure I have the right socket before pulling the anvil tires off :lol: ?
On a side note, to get the bearing out, does the turn the wheel with one of the bolts backed out and a socket, extension etc. wedged between the knuckle and bearing work to push the bearing out of the knuckle? I did this on my old 97 2500.
NickTF
Re: 2015 Front Axle Nut Size
Post by NickTF » Sun Oct 11, 2020 6:49 pm
33mm is correct size.
Using the backed out bolts a socket and the extension worked perfect to push wheel bearing off while turning wheel.
Having ability to lock axle with lockers (bypass switch) made this job easier.
Side note: even with locker bypass the front locker refused to engage with wheel speed sensor unplugged.
