Abel Components Nanny Kill Switch® - $79
Re: Abel Components Nanny Kill Switch® - $75
Would love this for my '18 PW. Email Sent!
Received my kit in 2 days Cali to Indiana. Very fast an the kit is very well done. Everything went easy and works just as described. Can't wait for the first chance to use it. Thanks so much for a great product.
Sent from my Pixel 4 XL using Tapatalk
Re: Abel Components Nanny Kill Switch® - $79
I think the postal sled dogs lost yours somewhere along the Iditarod Trail.
Last edited by Retired BLM Rig on Sat Jan 01, 2022 10:40 am, edited 1 time in total.
Any luck with a '19 version?MaxSteel19 wrote: ↑Thu Oct 31, 2019 1:22 pmDef let us/me know when you get it figured out for the 19 PW. I'd be in for one in a heartbeat.Retired BLM Rig wrote: ↑Sat Jul 06, 2019 3:15 amI updated the pictures in the first post. I was able to get my hands on a complete fusebox so I could fine tune all the wire lengths to make it fit right where I want it. Also, the generic toggle switch is a little less generic, I'm now including an aircraft style toggle switch safety cover as well as a simple chrome face plate, so you can choose how discreet you want the switch to be.
Yes, the Nanny Kill Switch is now available for 2011 thru 2020. If you want one, email me at: abelcomponents@yahoo.comTime2kyl wrote: ↑Mon Jan 27, 2020 12:55 amAny luck with a '19 version?MaxSteel19 wrote: ↑Thu Oct 31, 2019 1:22 pmDef let us/me know when you get it figured out for the 19 PW. I'd be in for one in a heartbeat.Retired BLM Rig wrote: ↑Sat Jul 06, 2019 3:15 amI updated the pictures in the first post. I was able to get my hands on a complete fusebox so I could fine tune all the wire lengths to make it fit right where I want it. Also, the generic toggle switch is a little less generic, I'm now including an aircraft style toggle switch safety cover as well as a simple chrome face plate, so you can choose how discreet you want the switch to be.
Last edited by Retired BLM Rig on Sat Jan 01, 2022 10:40 am, edited 2 times in total.
- Model Year: 2017
Sounds like a good idea just curious i know I can turn my traction control off when I need to spin the rear tires, does traction control not completely turn off by dash switch? Thanks
Enjoying beautiful east TN
It's always lingering in the back ground and never fully shuts off. Not to mention that the TC switch won't allow you to lock up the brakes and skid to a stop on a gravel/dirt road. ABS can increase the stopping distance in that situation.
Last edited by Retired BLM Rig on Sat Jan 01, 2022 10:41 am, edited 1 time in total.
- Model Year: 2017
Thanks and I saw the guy talking about his brakes better in 4 low why would that be?
It might just be "the observer effect", or it might be real. You can determine it for yourself by pulling fuse #F06 on your truck and taking a little test drive.
Some modern vehicles have a brake pedal position sensor to measure the force and distance of pedal travel which is calculated into the ABS function. I haven't taken the time to research if these trucks are equipped with that or not.
Suffice it to say that the Nanny Kill Switch reverts your truck to a 1970's era basic hydraulic braking system, free of any computer controls.
- Model Year: 2019
Joining the Nanny Kill club. Thanks @Retired BLM Rig for a great Labor Day weekend discount!
The generic toggle switch is even less generic now with printed labels.
Last edited by Retired BLM Rig on Sat Jan 01, 2022 10:42 am, edited 1 time in total.
Thank you Pigpen for posting this video! I'm sure it will answer a lot of questions that others might have about the install and end results.
I found out this week that the nanny's name is Karen.
One of my customers referred to his truck being in "Karen Mode".
That's a good one.Retired BLM Rig wrote: ↑Wed Mar 31, 2021 9:30 amI found out this week that the nanny's name is Karen.![]()
One of my customers referred to his truck being in "Karen Mode".![]()
Bahahahahahahahaha
- Mountaingoat1
Re: Abel Components Nanny Kill Switch[emoji2400] - $75
I never installed the nanny kill switch I bought for my 18’. Will it work on a 21’
Re: Abel Components Nanny Kill Switch - $79
Yes it will work but it uses a different fuse. Send me an email and I'll give you the PDF file for the 2019+ trucks.Mountaingoat1 wrote: ↑Sat Sep 18, 2021 12:31 amI never installed the nanny kill switch I bought for my 18’. Will it work on a 21’
AbelComponents@yahoo.com
Last edited by Retired BLM Rig on Sat Jan 01, 2022 10:44 am, edited 2 times in total.
Email sent
Sent an Email and PM! So pumped to find it all as a plug and play!
Replied to all emails.
i emailed you today some 2012 pics and a question about a 2012
Thank you!
My wife is named Karen and she has the same effect!Retired BLM Rig wrote: ↑Wed Mar 31, 2021 9:30 amI found out this week that the nanny's name is Karen.![]()
In her defense, she had back surgery and her neck fused. So I will only use this switch for the COMPLETE absence of Karen's
