31 gallon fuel tank?Retired BLM Rig wrote: ↑Mon May 13, 2019 12:26 am2015 in Marksville, LA. No pictures currently.
Here's the build sheet to confirm it's a PW.
Another Government Wagon Auction
Re: Another Government Wagon Auction
- Low_Sky
Yeah, that’s the normal tank size. Why the query?olyelr wrote:31 gallon fuel tank?Retired BLM Rig wrote: ↑Mon May 13, 2019 12:26 am2015 in Marksville, LA. No pictures currently.
Heck, I guess I just thought they were smaller lol. I fill up on empty about every time and rarely put much more than 26 gallons in it seems.Low_Sky wrote: ↑Mon May 13, 2019 5:52 pmolyelr wrote:31 gallon fuel tank?Retired BLM Rig wrote: ↑Mon May 13, 2019 12:26 am2015 in Marksville, LA. No pictures currently.
Ramboxes... granite crystal... sounds like a nice truck!
- Low_Sky
I think ~29 gallons is the most I've ever put in mine, and that was on a highway road trip, willfully ignoring the range calculation on the dash and calculating it myself based on hand-calculated MPG. Had extra fuel in the back of the truck, so I had a safety net for playing the "will I make it to a gas station?" game.olyelr wrote: ↑Mon May 13, 2019 6:09 pmHeck, I guess I just thought they were smaller lol. I fill up on empty about every time and rarely put much more than 26 gallons in it seems.Low_Sky wrote: ↑Mon May 13, 2019 5:52 pmolyelr wrote:31 gallon fuel tank?Retired BLM Rig wrote: ↑Mon May 13, 2019 12:26 am2015 in Marksville, LA. No pictures currently.
Ended up going for just over $28k.EasyDoesIt wrote: ↑Mon Jun 03, 2019 12:10 pm2016 in Phoenix
https://gsaauctions.gov/gsaauctions/auc ... CI19422001
A 2011 in Palm Springs, CA with 65K on the clock and it looks like it's going to need a cam and lifters or maybe just a broken valve spring.
Sorry for the short notice, but these end on Saturday August 17 in the afternoon.
The first one is a 2014 in Phoenix, AZ. with 99K miles.
The second one is a 2015 in Spokane, WA. with a Rambox, Ranch Hand style front bumper and dual alternators with 73K miles.
As of this posting, both are currently in the $17,000 range.
I've been watching that 2015.
Here's a similar 2015 from last year that went for $27.6k. Now for sale of AutoTrader for $26k
https://gsaauctions.gov/gsaauctions/auc ... CI19053012
http://atcm.co/S2PVDP/1e060835
Not sure what you mean, but if you’re talking about the offset radiator, that’s normal.
??? What am I missing?
NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton Hemi transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist, Hill control;recalls; 5” oval SS steps; Brakes: Extreme Z36 Truck and Tow Drilled/Slotted F&R rotors & pads; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Two 2016's in Lewistown, MT
https://gsaauctions.gov/gsaauctions/auc ... CI19648040
https://gsaauctions.gov/gsaauctions/auc ... CI19648041
And a 2009 in Idaho Falls, ID
https://gsaauctions.gov/gsaauctions/auc ... CI20002017
A 2013 in Safford, AZ. https://gsaauctions.gov/gsaauctions/auc ... CI20006003
2016 Blue - w/rambox
https://gsaauctions.gov/gsaauctions/auc ... FI20855035
Higher mileage but not bad.
Current $17,600 - closes tomorrow 12/18
edit: Closed at $21,200
Was semi-interested in the one in Susanville, CA; has anyone purchased one with the holes in the pillar from the spotlights? That to me seemed like a major disincentive, but it's already over $18k. Is there a way to fix those holes that's still cost effective?
https://gsaauctions.gov/gsaauctions/auc ... CI20283002
2005 PW, 14' RAM CCLB CTD, 84' W150
There's this option: https://www.ebay.com/itm/Police-Vehicle ... 1628885240
Or this option:https://policecarownersofamerica.bigcar ... delete-kit
These trucks are selling cheap, but they are high milage.
2015 in Phoenix: https://gsaauctions.gov/gsaauctions/auc ... CI20361012
2012 in Yuma: https://gsaauctions.gov/gsaauctions/auc ... CI20361013
How long before the 2019 Power Wagons are on the auction block? Timing might be right for me to get that new transmission
A 2016 in Tucson, AZ. with pre-bent rocker panels, holes in the tailgate and a missing center console.
A 2011 in Elko, NV. with a Backrack and a missing center console.
Twins in Springfield, OR.: Almost identical trucks (the VIN# has two digits different).
A 2008 with holes where A-pillar spotlights were removed, a missing center console and possibly a missing winch.
A 2008 with A-pillar spotlights, a missing center console and possibly a missing winch.
Somewhere there's a government landfill full of center consoles (or maybe they're just stacked up next to the alien spacecraft in Roswell, NM).
The land of lost and found consoles.
I bet that 2016 with rocker damage will go for closer to $15k than $20k.
A 2016 in Roswell, NM. with a Ranch Hand bumper and RamBox bed. https://gsaauctions.gov/gsaauctions/auc ... CI20484017
A 2011 in El Centro, CA. missing the center console and right rear door panel. Also has holes in the front fenders, bed and tailgate where emergency lights were removed as well as damage to the metal at the front of the bed. Sounds like a good candidate for a utility or flat bed. https://gsaauctions.gov/gsaauctions/auc ... CI20484018
