100% cure for death wobble
ACL123
Post by ACL123 » Tue Feb 25, 2020 9:38 pm
Must use a OEM steering stabilizer
2005 Bright Silver PW
2005 Mineral Grey PW
ACL123
Re: 100% cure for death wobble
Post by ACL123 » Tue Feb 25, 2020 9:45 pm
Although I figured this out about 10 years ago... I figured I would share. Like many of you I was throwing parts at the problem. Finally broke down and took it to the dealership. The mechanic came back after 10 mins and said it was the steering stabilizer. I proceeded to argue with him that I just put a brand new bilstein stabilizer on. He was very adamant that it was the stabilizer. So I said ok. Sure enough it worked. 10 years later and not a whiff of death wobble.
Post by DamageWagon » Tue Feb 25, 2020 10:06 pm
Death wobble is developed from the axle being unable to correct tire direction, or from over correction. Death wobble comes from an issue with alignment-affecting components. Tie rod, ball joints, axle straightness, wheel bearings, tires, control arm bushings, and alignment angles.
The steering damper aids alignment components by preventing over correction and by lessening external inputs. The OEM damper is surprisingly good and I only recommend the OEM damper or the Thuren tunes King damper.
The damper can stop death wobble from happening, but the damper itself is not the cure. Neither is caster alone as I hear frequently said. Every alignment components plays a part, and any one of these listed parts can cause death wobble if worn out or not set correctly.
Post by olyelr » Wed Feb 26, 2020 12:08 am
I have always been a believer that a steering damper does have its purpose, but curing death wobble is not one of them...but they can often mask it, however.
Well, I guess if they can mask/stop it, then its a win win regardless LOL.
Post by DamageWagon » Wed Feb 26, 2020 12:15 am
My OEM damper with a bent shaft, puking oil, with two massive dents in it, kept DW away while I drove 60 miles to a buddy to press in new ball joints. Truck had tires coming off the ground going 40 on the road from DW without the damper.
Post by RustyPW » Wed Feb 26, 2020 12:51 am
I had the same issues years ago. Throw a ton of money at it. Pin pointed it to the steering stabilizer. Had a discussion about it on here. Most guys here didn't want to hear about the stabilizer. :roll: Said it was something else. :roll: Pissed me off to no end.
Post by olyelr » Thu Feb 27, 2020 1:00 pm
Are you over it yet? :rofl:
Post by RustyPW » Thu Feb 27, 2020 5:23 pm
Post by OffroadTreks » Fri Feb 28, 2020 12:51 am
ALL THE STABILIZERS!!!!
STABILIZE ALL THE THINGS!!!
Post by KevinABQ » Fri Feb 28, 2020 3:28 am
Thuren's note on this is is interesting "There are a lot of trusted brands out there producing steering dampers, but they are often very lacking, in actual effectiveness."
Post by DamageWagon » Fri Feb 28, 2020 12:26 pm
The most important jobs of a steering stabilizer are to damp the smallest initial movements, and to output a lot of force at a very low shaft speed to resist big jerks to the steering. Emulsion shocks like almost every Rancho, Bilstein, Fox, etc. do poor jobs of these because the mixed nitrogen in the oil can flow easily through the valves. There’s a lot to be said for a high quality IFP shock in that job.
Post by Reloaderguy » Fri Feb 28, 2020 3:19 pm
There's a better way.
flattire
Post by flattire » Fri Feb 28, 2020 3:29 pm
What are we looking at here?
Post by RustyPW » Fri Feb 28, 2020 4:07 pm
I know for a fact that Rancho takes a regular shock and lays it on it's side to use as a stabilizer. Because of this, the valve is not fully in the fluid. This creates dead spots in the travel. Had a nice long ass chewing session with them a few years back.
Post by olyelr » Fri Feb 28, 2020 6:50 pm
Reloaders is hydro assist.
Post by olyelr » Fri Feb 28, 2020 6:51 pm
Well you done told them! :lol:
Post by RustyPW » Fri Feb 28, 2020 11:56 pm
Felt like TwinSticks on the phone. :angry:
Post by olyelr » Sun Mar 01, 2020 1:19 am
Bahahahahahahaha
MoparFanatic21
Post by MoparFanatic21 » Sun Mar 01, 2020 7:02 am
I would like to see better pics of that hydro assist
Post by Bill2014 » Sun Mar 01, 2020 7:48 am
Twinstick did set the standard for giving vendors feedback - but I suspect he was most effective in person. :excited:
Ah - the ole days...
Post by OffroadTreks » Sun Mar 01, 2020 11:25 am
phpBB [video]
Clickable link for Tapatalk
Post by Reloaderguy » Sun Mar 01, 2020 4:10 pm
Who engineered that tie rod mount for the Synergy bar?
Post by DamageWagon » Sun Mar 01, 2020 5:36 pm
Reloaderguy wrote:Who engineered that tie rod mount for the Synergy bar?
It is from PSC
Post by RustyPW » Sun Mar 01, 2020 9:57 pm
Kind of miss that saw off runt. :lol: He was always good for a good rant. :rofl: Wonder how he is doing with his cheby?
Post by Reloaderguy » Sun Mar 01, 2020 11:29 pm
It is from PSC
Is that it's intended use? I don't see it surviving Moab on the end of a hydraulic ram.
