Working on an Electric Sway Bar Bypass
Retired BLM Rig products
Re: Working on an Electric Sway Bar Bypass
Post by Retired BLM Rig » Thu Dec 26, 2019 1:37 pm
SimonandSimonBeast wrote:
Thu Dec 26, 2019 7:45 am
There are 10 wires going in and out of that connector on my truck. What does that mean regarding the bypass possibilities?
It means that your truck has the newer CAN-BUS system that won't allow the use of the factory dash switches to control the sway bar bypass.
It will work with a dedicated rocker switch that I provide with the system. Here's a picture of what the amber rocker switch looks like installed in the dash.
If you don't want to drill a 20mm hole in your dash, I provide an under-dash mounting bezel, seen in the upper left corner of this image.
The official thread for the Sway Bar Bypass
SimonandSimonBeast
Post by SimonandSimonBeast » Thu Dec 26, 2019 3:10 pm
I guess it kinda sucks that Ram nannyfied it that far. Regarding drilling that panel on my dash, I have no fear. I already put 2 KC light switches there. It's pretty much the perfect little panel to put aux switches.
:rockon: :chug:
