Abel Components Sway Bar Bypass® - $299
The Sway Bar Bypass® is a stand-alone system for giving the driver complete control of the disconnecting sway bar, from the comfort of the driver's seat, in any transfer case range, at any speed. It works on all years of Power Wagon and Jeep Rubicon and is completely electric (no OBA needed) and comes with everything you need to wire it into your vehicle, without cutting or splicing into any factory harnesses. This system abandons the factory sway bar switches and utilizes its own rocker switch with an indicator light, that shows when the sway bar is disconnected. It will also work with your own auxiliary switch panel to control it. There will be no flashing lights on the factory switches and the lockers or Locker Bypass will still function like normal. It does not affect the engine or transmission performance.
Ram only allows the sway bar to work in 4H or 4L and if you exceed 18 MPH, it automatically reconnects. This always frustrated me, because driving off road with the sway bar disconnected really softens the ride, allowing the front axle to move more freely and mitigates jostling in the cab. There are lots of dirt roads that can be navigated in 2WD, at a higher rate of speed that you'll enjoy a more comfortable ride with the sway bar disconnected.
Purchasing this device puts the driver back in control. It is intended for off-road use only, NEVER DISCONNECT THE SWAY BAR ON THE HIGHWAY! Always practice safe off-roading and use common sense. Purchasing this item means that you take back control of your truck, as well as take on full responsibility for your actions and consequences after you flip the switch.
Send me an email to order this item: AbelComponents@yahoo.com
Abel Components... Putting the driver back in control.
Last edited by Retired BLM Rig on Fri Jul 07, 2023 9:15 am, edited 1 time in total.
Re: Abel Components Sway Bar Bypass® - $249
Great job, David!!!
- Oilbrnr
It works as advertised! Makes my 3 mile off-pavement journey to my house just a tad softer. It was a pleasure working with David.
'16 with '17 FWC
Thanks for your ideas/input and beta testing Oilbrnr!
lol hahahaha
cant believe im about to ditch my EVO Mfg on demand air release for this electric system which serves the same purpose....
Wait, yes I can, its an Abel Components Product helping my Powerwagon become most Abel
bye bye ARB solenoid!!!!!
THIS IS THE COOLEST THING EVER!!!!!!!!!!!!!
- Oilbrnr
I use mine every day I drive the PW. Pretty much disengaged all the time unless I'm going over 60 or its real windy with the FWC.
'16 with '17 FWC
I have had my sway bar bypass sitting on a shelf for months waiting for warmer weather to arrive. I finally installed the kit this weekend. The entire kit is super! The directions, the wire length even the switch is just great! Installing the kit was really simple and I couldn’t be more pleased with it!
Thank you for proving such nice improvements. I am really happy with the all of your kits!
