Towing-Hitches/Curt-Adjustable-Multi-Ball-Mount
http://www.autoaccessoriesgarage.com/To ... Ball-Mount
Anyone had any experience with this product? I like the idea of one and done.
PWRider
Re: Towing-Hitches/Curt-Adjustable-Multi-Ball-Mount
Might be handy but also how often you need anything but 2" ball. If you do than sure. If you own a trailer than get appropriate drop hitch and be done. Little point for lugging around extras you will never need. Adds more rattles and something to catch the ground.
Here's what I run. Trimax Razor with Reese interchangeable balls. I rarely use 1 7/8" or 2 5/16" but I have them when needed. It's also much cheaper than some of the billet alternatives. Hitch is about $100 and balls were about $30.
http://forum.powerwagonregistry.org/vie ... 273&p=3921
http://www.amazon.com/Reese-Towpower-74 ... sim_auto_2
http://www.amazon.com/gp/product/B005TC ... 02_s00_i00
I have the Rapid Hitch 10" for my truck
http://www.andersenhitches.com/Catalog/ ... hitch.aspx
- verdesardog
Here's what I'm going to get for the camping trailer I'm building:
As much articulation as a pintle hitch without all the clanging and banging.
http://locknroll.com/
04Ram2500Hemi wrote:I have the Rapid Hitch 10" for my truck
I like this one a lot. Which did you get? The greaseless or the original?
Last question, do you guys find that you really need the 10" or would the 6" work ok? My PW has not been lifted. I'm going to order one today just not sure which size or whether to go with the greaseless ball or not. Decisions, decisions.......
I like these.
But my concern would be our factory hitches integrity without using weight distribution... Thoughts?
They have a similar set up that does have the weight distribution. Looks like three height adjustments on this one.vanished wrote:I like these.But my concern would be our factory hitches integrity without using weight distribution... Thoughts?
http://youtu.be/HRoQ_yQZQwQ
Although there is NO standard, MOST trailer couplers are about 18" from the ground to top of ball.tat6272 wrote:Last question, do you guys find that you really need the 10" or would the 6" work ok? My PW has not been lifted. I'm going to order one today just not sure which size .
Thanks tat. That's pretty sweet setup. But considering I already have a Reese wd setup I just need to get the longer drop to get my trailers level... Biggest question I have is how do all the other work truck 2500 & 3500 rams that are towing lowboys with bobcats, tractors & backhoes on them do it safely? They gotta have a higher tongue weight than my camper or 3 horse slant trailer and rarely ever have wd bars...
cruz wrote:Although there is NO standard, MOST trailer couplers are about 18" from the ground to top of ball.tat6272 wrote:Last question, do you guys find that you really need the 10" or would the 6" work ok? My PW has not been lifted. I'm going to order one today just not sure which size .
This was helpful. Thanks. I went with the 10 inch greaseless.
- MOPARManiac
I use fixed receiver hitches, lest chance of failure IMO. I use a 6" drop for my flatbed trailers and a 4" drop for our camper (it sets up pretty high).
Got the Andersen Rapid Hitch 10" with greaseless balls. This hitch is a thing if beauty. Solid aluminum (yes, aluminum, but it's heavy as hell). Probably should have gone with the 6" though. 10" is probably better for a lifted truck.
blathrop99
I have one. Have had it for several years. It works great and is really convenient.
You're not kidding- the 10" is heavy. However, I never want to have to buy another hitch again, so that's why I went with the big one.tat6272 wrote:Got the Andersen Rapid Hitch 10" with greaseless balls. This hitch is a thing if beauty. Solid aluminum (yes, aluminum, but it's heavy as hell). Probably should have gone with the 6" though. 10" is probably better for a lifted truck.
- Stickman
Actually just ordered one of these today, in a 7", comes with a 2" and a 2 5/16" ball. Most people run a Reese around here, unless you can afford a B&W, quality stuff:
Check them out: http://www.turnoverball.com/ (site isn't working now, was this morning)
- verdesardog
I didn't get the hitch I orginally posted I got this one:
No ball! Can't pop off unless something breaks......
