New Member Here
Bianjames
New Member Here
Post by Bianjames » Sat Nov 02, 2019 12:13 am
New guy here,
I acquired my dad’s 2011 PW in August. I actually picked this truck up for him in 11’ brand new in Denver and shortly after installed a Northern Lights Slide-In for him. He rarely drove it over the years, and now it has a mere 32,000 miles on it.
I drove it back to Montana from West Virginia and on the way home experienced DW. I mounted a set of 315/70R17 Toyo MTs and never experienced it again. Then I went with Thuren Control Arms, Thuren Track Bar, and Day Star Cradels for the Firestone Air Bags. I also installed a new Mopar Steering Kit (wasn’t necessary, but fairly cheap on Amazon), Marathon Seat Covers, and Weather Tech Mats.
I had Dodge change out the plugs, flush brake fluid, and install new front rotors (not sure why they were warped).
The truck feels rock solid, I haul a 325 gallon water tank off road with it and with 50 psi in the bags it handles it really well. We also ordered a Four Wheel Camper Hawk model to put in the back. It does have surface rust on the axles form being driven occasionally on salted roads and then sitting for long periods of time. Everything works, lockers engage (slowly), winch works, sway bar disconnect works...
Re: New Member Here
Post by Bill2014 » Sat Nov 02, 2019 7:24 am
Looks like you're getting your rig all set up.
Re: New Member Here
Post by Mule007 » Sat Nov 02, 2019 9:38 am
Welcome to the forum, Enjoy 🌞👍
NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton Hemi transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist, Hill control;recalls; 5” oval SS steps; Brakes: Extreme Z36 Truck and Tow Drilled/Slotted F&R rotors & pads; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Re: New Member Here
Post by RustyPW » Sat Nov 02, 2019 2:52 pm
:winchmob:
Bianjames
Re: New Member Here
Post by Bianjames » Sat Nov 02, 2019 10:39 pm
I just noticed that only one pic downloaded...
Bianjames
Re: New Member Here
Post by Bianjames » Sat Nov 02, 2019 10:42 pm
Very happy with the Toyos so far.
Re: New Member Here
Post by FirerescuePW » Sun Nov 03, 2019 8:44 pm
That's a great looking truck!
Welcome. I really liked my Toyo MTs. The RTs are almost as good, but the next set will probably be MTs again.
TommyG
Re: New Member Here
Post by TommyG » Mon Nov 04, 2019 7:36 am
Welcome.
