Clearance lights
HeavyDuty
Clearance lights
Post by HeavyDuty » Tue Jun 18, 2019 2:03 pm
Anybody know if there is an easy way to get the rooftop clearance lights to stay on all the time without turning headlights on?
“ROCKY MOUNTAIN” TESTED
pdavey
Re: Clearance lights
Post by pdavey » Tue Jun 18, 2019 2:07 pm
What year is your truck?
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
Post by PWJouster » Tue Jun 18, 2019 4:39 pm
i would love to use my clearance lights and amber DRL as full time DRL....
pdavey
Post by pdavey » Tue Jun 18, 2019 4:45 pm
Maybe it is just me because I use Tapatalk but could folks post the year of the vehicles they are talking about. Likely based on the year the solution will be different.
My thought is that if you want them with the DRL you likely are going to have to jumper into where the DRL is but would need to look at the wiring diagram for the model year to determine that.
For older PW’s without DRL likely it is a matter of just rerouting the power wire to an accessory switched line. I know my 2005 PW will have the clearance lights on with just the parking lights on and I drive all the time with Parking or Headlights.
Performance Mods:
Other Mods:
Style/Other Mods:
HeavyDuty
Post by HeavyDuty » Tue Jun 18, 2019 10:16 pm
Sorry. 2018 ram
pdavey
Post by pdavey » Tue Jun 18, 2019 10:25 pm
Here is the wiring diagram. They are tied to the parking lights which is normal. If you have DRLs you could always try to run a piggyback pin from the Body Control Module
I don't believe the clearance lights are part of the monitored lights on lights out so you may be able to repin just fine.
Performance Mods:
Other Mods:
Style/Other Mods:
Post by olyelr » Tue Jun 18, 2019 10:39 pm
I know the tazer ram allowed me to choose if the drl’s are on or off, and what lights would be used if it is on. But i cant remember if the clearance lights were one of the choices or not.
pdavey
Post by pdavey » Tue Jun 18, 2019 10:41 pm
Based on the wiring diagram it doesn't look like they would be part of that circuit but would need to see the pin out on the BCM
Performance Mods:
Other Mods:
Style/Other Mods:
Post by Reloaderguy » Tue Jun 18, 2019 10:41 pm
AlfaOBD can activate DRL's.
