Fire Extinguisher
EasyDoesIt
Fire Extinguisher
Post by EasyDoesIt » Sat Jun 01, 2019 11:10 pm
Looking to pick up a new fire extinguisher to mount in the cab or bed somewhere. What fire extinguisher are you guys using?
Anyone spending that tall cash on a Halon?
verdesardog
Re: Fire Extinguisher
Post by verdesardog » Sat Jun 01, 2019 11:34 pm
I have a 5 lb carbon dioxide extinguisher right at the tailgate of my truck but am considering one of these https://elementfire.com/products/element-e50 for my camping trailer.
This is an old dry chemical I had at one time, same location as the new co2 one now.
Post by DamageWagon » Sun Jun 02, 2019 12:03 am
Having fought car fires with extinguishers, and done several huge writeups on extinguishers, and having a fire in my own truck from a cut electrical wire... I carry a 2.5lb dry chem extinguisher under the driver’s seat. If you have a fire in the truck it’s likely electrical and can probably be solve by yanking a battery terminal, or is from gas catching fire and an extinguisher isn’t going to do shit. A shovel for putting out camping fires will see far more use.
Halon/Halotron are expensive and very very limited in how little of a charge is in those extinguishers due to the size and lower pressure. If a dry chem extinguisher isn’t going to put your fire out, it isn’t going out. Halon exists for a dedicated purpose and is not the right pick for a vehicle fire, even though I see people blow money on them all the time without understanding why it exists.
Post by Colibri » Sun Jun 02, 2019 11:00 pm
I have a halotron 1 extinguisher in cab, but it’s only for my expensive shit in the cab ie lowrance gps ham radio laptop etc that would be damaged by a dry chemical extinguisher. I have a big dry chem in the bed and an onboard AFFF system for engine bay and gas tank. All I have to do is yank the safety pin flags and hit the release cables and the engine bay and fuel tank get foamed.
If you’re gonna do an AFFF system you need to be able to shut down your electrical system to be 100% safe.
That element extinguisher is something I’ve been eyeing for a while, I want to test it on a tire fire before I trust it in one of my vehicles though. It looks really promising to me
Post by Reloaderguy » Mon Jun 03, 2019 12:08 am
I wouldn't be heartbroken if it burned to the ground.
Post by OffroadTreks » Mon Jun 03, 2019 7:21 pm
:rofl:
EasyDoesIt
Post by EasyDoesIt » Mon Jun 03, 2019 10:58 pm
Awh man you guys aren't messing around, especially you @colibri.
Good info Marcus.
To be honest I'd probably let it burn too as long as I wasn't 50 miles from civilization!
EasyDoesIt
Post by EasyDoesIt » Sat Jun 08, 2019 2:03 pm
I picked up a 2.5lb abc marine/auto and an Element e50. Best of both worlds.
The element extinguishers look pretty sweet and the price/size is hard to beat.
Post by Retired BLM Rig » Sun Jun 09, 2019 3:01 am
I like the concept of the Element, but after watching the videos, my only concern is how close you have to be to the fire for it to be effective (since there's no pressurized propellant). I guess as long as you catch it early and small, it wouldn't be too big of a deal. I'll probably pick one up to have as a first line of defense. I like that there's no residue to clean up after.
Mule
Post by Mule » Sun Jun 09, 2019 7:31 pm
I've got a little RV extinguisher between door and drivers seat. Just enough room there, out of the way, and easy access if needed.
Post by Bill2014 » Mon Jun 10, 2019 11:41 am
I wonder if it would be better with the handle and nozzle positioned toward the rear of the seat? That might reduce potential kicking the extinguisher head with a boot... :rockon:
Mule
Post by Mule » Mon Jun 10, 2019 1:01 pm
I'm not sure how you're getting in/out of the truck, but I have literally never had that issue. :rofl:
JRHPWRWAGON06
Post by JRHPWRWAGON06 » Sun May 30, 2021 2:16 am
Mule inspired me a few months ago to install one. This is a 2.5 lb halotron from H3R Performance. I was going to install a dry chemical on the passenger side but lost interest due to the PITA install.
Yeah my floor is dirty so what? Yes that is yellow Labrador hair, it's everywhere.
OPTIONS-
MODS-
