That's not the worst. Check out this post >>
EMF steering linkage?
Re: EMF steering linkage?
All you need is a good tack weld with a MIG.
It’s not as complete a weld as I thought, but it’s pretty solidly in place.
My Thuren drag link showed up today. It's been installed.
The V06 recall calls for a weld the length of one flat on the nut on each end of the collar. I'm not letting them do it on my '16 3500 yet, as there is still the possibility of an ACTUAL fix somewhere down the road, according to my dealer service manager.
They actually had to buy a welder for this recall. How much practice time do you think the techs had before they struck an arc on a customer's truck???
Maybe 5 minutes of practice if you are lucky enough. "Hey, I made sparks." "Ok , you're ready to go, NEXT!"FirerescuePW wrote: ↑Sun Jun 09, 2019 10:03 amThe V06 recall calls for a weld the length of one flat on the nut on each end of the collar. I'm not letting them do it on my '16 3500 yet, as there is still the possibility of an ACTUAL fix somewhere down the road, according to my dealer service manager.
gents, I think I'm finally in the market to replace my linkage as well (knuckles to the pitman). Glad I found this before I decided on DOR...sorry Rusty. DamageWagon, do you have the part number(s) for the Mopar kit you recommend or do I have to buy individual parts? Going to replace the original damper too.
The whole kit is usually cheaper than the individual parts. I don’t have the number but that should be easy to look up. I use moparpartsamerica.com, they’re local to me and I don’t know if they still ship but you can at least grab the part numbers from them.Max Power wrote:gents, I think I'm finally in the market to replace my linkage as well (knuckles to the pitman). Glad I found this before I decided on DOR...sorry Rusty. DamageWagon, do you have the part number(s) for the Mopar kit you recommend or do I have to buy individual parts? Going to replace the original damper too.
yeah, I see it looks cheaper. Anyone try this one: https://www.amazon.com/gp/product/B012B ... QZNN&psc=1
