Acceleration lag?
- Model Year: 2019
Acceleration lag?
I have a 2019 and its driving me crazy with a 1-2 second delay in acceleration. Can this be adjusted or programed?
I go to pull out onto roadway and I step on gas pedal and by the time the truck starts to move the gas pedal is already halfway to the floor then I have to back off.
Re: Acceleration lag?
Seems like all modern trucks are that way, things like pedal commander help. I put one on our 4 Runner.
I drove a 19 like that and it was absolutely ridiculous. It shouldn't be like that but a pedal commander would help that.
Sent from my Pixel 3 XL using Tapatalk
Is that something new they did? My 16 seems fine as far as that goes.
2007 and 2019 Power Wagons
Talk to the dealer and see if there's a reflash available. Maybe they mistakenly applied 4Lo throttle mapping to the 2019's.
Or - just image you have turbo - and have to wait a moment for the boost!
- Model Year: 2019
Thanks, I just ordered a pedal commander.
Keep us updated on how you like it.
a friend of mine has a pedal commander for his 2018' 2500 Cummins. He absolutely loves it!
mike
mike
Gooseneck
SOLD 2012 Power Wagon Laramie
2016 GMC Yukon Denali XL
2016 Volvo XC90
Gooseneck
2016 Volvo XC90
I have one on the 1500, if you turn it all the way up, you can put pressure on just your big toe and it'll be like you floored it. Haha
- Model Year: 2019
So it came but the connectors dont fit, is there more than 1 plug on the gas pedal?
Should tee into the gas pedal and that's all. If it's not plug and play, it must be the wrong one.
a pedal commander should help...but it wont help if they went and fudged up the transmission tuning with the new 8speed.xtrememachines wrote: ↑Mon May 27, 2019 3:30 pmSo it came but the connectors dont fit, is there more than 1 plug on the gas pedal?
if you bought it specific to your truck, it will fit.
send over some pics?
it connects inline
Won’t the pedal commander make your warranty void on a lot of stuff? I wouldn’t do it till it’s out of power train warranty.
Fastnlight wrote: ↑Wed Jun 05, 2019 5:53 pmWon’t the pedal commander make your warranty void on a lot of stuff? I wouldn’t do it till it’s out of power train warranty.
You can unplug and plug it back in within a few minutes. Shouldn’t effect the warranty at all. It doesn’t tune or change any points. Basically just a voltage amplifier from what I gather about it.
I have a 14’ and it’s made a night and Day difference.
- Model Year: 2019
They sent over the right one, it just plugs in. It helps with the lag.
