Why is My Front Axle Leaking?
I've got gear oil leaking out both sides of my front axle, and I'm looking for some idea of why.
The axle shafts have no side-to-side play, and the breather isn't plugged. The fluid is Royal Purple and is in perfect condition: no water or any other obvious contaminants.
Is this a typical side effect of installing lockout hubs, then?
The dealer wants $950-ish for the repair, and a local shop wants $350, so I want to avoid a repetition of this problem.
Thanks.
Thanks.
'08 Flame Red Quadcab with Spyntec & Teraflex hubs, Mag Hytec pan & covers, Carr rock rail steps, Warn wireless winch controller, Hawk Performance brake pads, Ranch Hand crossover box, and Turbolined bed.
Re: Why is My Front Axle Leaking?
Sounds like the seals have gone bad. I had a string of front axle seal issues under warranty when I first bought the truck. There was no real reason. Then I got them done at merchants and havent had the issue since. Wondering if it was the aftermarket axle seals that did it.
Sent from my DROID DNA
Performance Mods:
Performance Mods:
Did you just recently install the lockout hubs? Sounds like the seals were damaged on reassembly.
FirerescuePW wrote:Did you just recently install the lockout hubs? Sounds like the seals were damaged on reassembly.
This ^^^.
http://www.quad4x4.com/cgi-bin/commerce ... n&key=4685
http://www.quad4x4.com/cgi-bin/commerce ... &key=10945
I installed those 2 1/2 years ago. That's part of the reason I'm mystified as to why this just happened. On BOTH sides.FirerescuePW wrote:Did you just recently install the lockout hubs? Sounds like the seals were damaged on reassembly.
It makes me think the diff carrier bearings are going south.
There are no aftermarket seals around here-- dealer-only item.pdavey wrote: Wondering if it was the aftermarket axle seals that did it.
- VA_Wagon Man
I had both of my inner Axel seals replaced at a dodge dealership fir $400 and some change......i had a nice special favor done for me. Its normally a $1000+ job.
I had the left side start leaking after a significant deer hit to the front left tire. They replaced both for the $400....
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
When replacing the axle shafts back in the housing. You have to be careful of the axle seals. They nick real easy. In your case, 2 1/2 years. How many miles?
30K +-RustyPW wrote:When replacing the axle shafts back in the housing. You have to be careful of the axle seals. They nick real easy. In your case, 2 1/2 years. How many miles?
To my way of thinking, 2 1/2 years & 30,000 miles takes the lockout installation off the list off probable causes for this sudden hemorrhage. If those seals had been compromised during that install, it seems to me they would have started leaking right away or not at all. I could be wrong, but it doesn't seem logical that all of the sudden they would just start leaking due to damage incurred so long ago.
IIRC, we reinstalled the axle shafts very gingerly with these seals and their preservation in mind.
Yes, you did.VA_Wagon Man wrote:i had a nice special favor done for me.
- verdesardog
I took my axles out to replace ball joints several months ago, my seals aren't leaking...yet. you must have dammaged them slightly.
Fix'd.
$371 was all it cost.
Hope it lasts.
Thanks for all the input.
Hope it lasts.
Glad to hear. What was the fix?
Performance Mods:
Performance Mods:
- VA_Wagon Man
That's great! I'm with Peter, what was involved?Nailhead wrote:Fix'd.
Hope it lasts.
Long Gone:
Been away a while...
I actually don't know how they fixed it, but I'm almost certain they didn't remove the diff.
Still working great, though.
