Hey all,
Wanted to give my feedback on the two systems offered.
First of all these kits are of high quality, are professionally put together, and just top notch as hell.
Start to finish it was a painless process... my turn came up, i paid, i received both the locker bypass and nannie kill system within the week.
Once i got started the kit was fully prepped and ready to go, everything you need.
I did have a couple of questions and i received answers right away..again huge
Installation was easy and it looks factory. I tested the system and it worked like a charm.
If your on the fence about the system or the cost, GET OFF THE FENCE AND START WHEELING. These set-ups are the bees knees.
Retired blm, you da man!
I find myself using the nannie kill alot when just hopping about on dirt fire roads and the 2wd drive locker option is awesome when pulling a dry hill or a boat at the launch.
Thanks for the awesome system you figured out, R. BLM.
(Side note: on  a 2014 at least, the passenger inner fender there is a 1/4 twenty threaded factory stud, it works perfect for mounting the control box for the locker bypass. Its between the firewall and the air box. Takes some riggermaroe to get the box in position, but its a solid, safe spot to mount.)
