Looks good!
									 SOLD: Never forgotten: Mule - 2005 Power Wagon, “Laramie”
 SOLD: Never forgotten: Mule - 2005 Power Wagon, “Laramie”NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Mule your truck has a serious case of hemorrhoids
lund who is AVS style is called aeroskin. its texteured  like the new grills/ black bumpers
https://www.lundinternational.com/newpr ... eroskin+ii
- Punishher7
I use my winch for stuff like that 86% of the time. 13.6% pulling other people out and 0.4% to pull myself out.Punishher7 wrote:
  vie ... =13&t=2333
- Punishher7
This weekend was the first time I’ve used mine and I’ve had it just over a year. Kept the trees from taking out the fence and falling in the street. Also pulled three stumps with it as well. Came in handy for sure.
Wen't to Joshua Tree last week to do some rock climbing with some buddies.  My plan was to cut through Berdoo Canyon Road to Geology Tour road and make a loop through the park but the forest service gated Berdoo Canyon.  It was a super bloom down there so tons of flowers n tourists.  Not much of em 4x4 so that was good.
						- Rodeoflyer
I tried adding some camouflage to my government issue A-pillar spotlights, attempting to make them look a little more off-roady. Not sure how I feel about it yet.
									2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Full SmartBar Bypass®,  Abel Components Nanny Kill Switch®,  2000 Watt ProMariner TruePower Plus Pure Sine Wave Inverter, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God,  Share the Umbrella, Make sure you're right with God before you meet him!
BraapWerks brought their rig up.  It'll be on the snow all weekend... Muddy Creek lot, between Kremmling and Ears.  Big party's saturday night.
My new 2018 Power Wagon. Looking forward to upgrading it in the near future!
						- VA_Wagon Man
Carli front diff and Purple Cranium rear protectors installed.... Now I can pull up and pose on rocks for fun LOL (it wasn't installed in the last pic)
									Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
Just finished two weeks on the north rim of the grand canyon and white rim at island ING the sky in Canyonlands.
Sent from my G3123 using Tapatalk
						- 1pieceatatime
To add some more White Rim photos...
Guess who's getting a new rear end!
Been getting more diff noise than usual from the back under acceleration, especially 30-50mph. Local shop I have oil changes done at noted a leaking pinion seal again - was replaced last year by my buddy's shop. Had them take a look at it again while I was out on a 10-day training cycle - bearings are toast. Got the parts on order slow-boat, had them button everything up for now. Got another week of training in MT coming up, parts will be in by then and i'll have 'em knock it out while i'm out on snow.
New toy... Seek ShotPRO.
Almost had a house fire a few weeks ago when a breaker failed. Grabbed the cheapo FLIR (TG165) from work to chase down that issue and confirm the fix. Had a FLIR C3 in my shopping cart for a while, after using the TG165 and comparing specs on the FLIR and Seek units, the Seek turns out to be a much better unit for about the same price. The C3 and TG165 both use the same 80x60 sensor. ShotPro's got 320x240 sensor, 50°FoV, optical camera with a nice "fusion" mode, twice the battery life, and built-in flashlight.
With the electrical/plumbing issues in this house, probably doing in-floor heat with remodels, and equipment work I do... money well spent imo. Great diagnostic tool.
			At the power plant. We used thermocameras all the time to track down bad grounds, overloaded circuits, bad insulation, leaking valves, etc. Our good camera was $40,000.
It sprouted more antennae
   (700meg mag-mount)
  (700meg mag-mount)
Got a great deal on five new wheels when I went to replace my Toyos. (Click for large image.)
Nice  , looks good!
, looks good!
									 , looks good!
, looks good! SOLD: Never forgotten: Mule - 2005 Power Wagon, “Laramie”
- SimonandSimonBeast
Nice.  Like the bronze on black.  Also like the cap.
Truck now has internet anywhere it's parked.  Definitely waited too long to buy that Hughes kit...
Rolled over 200k this weekend.
Pulled coax from the cab into the bed.  Makes it easy to hook up the dish/radio with fewer connections.
Set it up in the truck a few times this summer, figured out an arrangement to pull the dish as close into the bed as possible to minimize wind jerking it out of alignment (0.5° to Echostar 19...) but still keeping it high enough to not have people/vehicles in front of it.
Terminal between rear window and back seat, ps/inverter/power pack shoved in wherever it'll fit in the cab.
The hoops i'll jump through just to have wifi on the shitter.
I'll be back up here in a few days for a level-1/rescue/level-2 training cycle.
Hopefully next week will be warmer than this weekend was. Snotel 1/2mi from the trailhead read an overnight low of -24°F.
