Locker Bypass Rebirth
Re: Locker Bypass Rebirth
Post by Retired BLM Rig » Wed Feb 06, 2019 9:15 pm
Buck316 wrote:
Wed Feb 06, 2019 7:55 pm
Ok cool how many people in line? How long of a wait?
Hello Buck316,
The list is in my "Abel Components" vendor area and in the "Parts for Sale" sub-forum. It's the same thread in both places.
viewtopic.php?f=47&t=5876&p=102038#p102038
You would be #23 on the list and there is a 60 day lead time for anyone added to the list. Right now I'm building units for people that ordered in the middle of December. I'm trying to get faster but it's tedious work to do it right".
Let me know if you want to be added to the list.
Post by olyelr » Wed Feb 06, 2019 10:51 pm
I’d like to see a timelapse video of you getting one of these whipped out in under a minute :lol:
Jack187
Post by Jack187 » Thu Feb 21, 2019 2:00 pm
I received my locker bypass today. The quality of the kit is top notch.
I had previously bought a shelby kit, but never installed it, as it seemed highly questionable, given it essentially disassembled itself in shipment.
The cables in the new kit look better than I would even expect from Mopar itself.
It will probably be a couple of months before I can install though due to time constraints and weather, but I am looking forward to it!
benking
Model Year: 2019
Post by benking » Thu Feb 21, 2019 4:39 pm
Many thanks for taking the time to do this, Retired! I did this to my 07 Tacoma and it was F’ing A! I have a scheduled build date of March 11 for a 19 Tradesman PW (Dial transmission shift and push-button lockers). Is the wiring for the new ones largely the same as the 17-18s and would your unit install the same? If so, I would love to be put on the list. Thanks again!
Post by Retired BLM Rig » Thu Feb 21, 2019 5:04 pm
I’m going to have to get my hands on one locally so I can do some R&D, but I suspect it’s going to require a new prototype. I’ll post info as things progress.
2017PW
Post by 2017PW » Fri Feb 22, 2019 12:59 pm
Add me to the list, 2017. Thanks!
cb1987
Post by cb1987 » Sun Mar 10, 2019 1:55 pm
put me on the list for '17. also i want to put a disabling toggle switch in the cab
Post by Retired BLM Rig » Mon Apr 08, 2019 12:04 pm
Ram just released connector diagrams for the 2019 trucks, everything has changed and the current locker bypass won't work on 2019 and newer trucks. When you compare the 2018 diagram to the 2019 diagram, you can see that all switch inputs have been removed. Now all control of the final drive control module (FDCM) is coming through the CAN C data stream apparently.
The next generation of locker bypass will need to be a reprogrammer or a completely stand alone hardwired unit. I'm not capable of manufacturing a reprogrammer, but I can build the other option and it would be plug and play with no cutting of wires. However it would more than likely set codes and turn on warning lights. :angry:
Post by PWJouster » Mon Apr 08, 2019 1:38 pm
you mean to tell me there will be a time when an 18 4th gen may be "best gen"???
truth be told, you do not know how useful 2Hi locked with no ABS is on gravel roads until you have tried it.
a diesel powerwagon with a transfer case and lockers warrantied is a great idea, but i dont see why i need to move on quite yet
this guy will set you 14-18 4th gen owners straight. No other Options as clean and simple as we have here.
Quality in parts and service is not a premium here but a standard option.
Post by RustyPW » Mon Apr 08, 2019 8:26 pm
Get real. The 4G's don't even have a RC/LB like the 3G's. You're 9" longer and can't see over the hood.
Post by OffroadTreks » Mon Apr 08, 2019 8:31 pm
Your grab handle falls off, dashes explode, paint peels and you have an underpowered motor. Should I mention an interior fitting of a Dodge Neon?
:poke:
:thppt: :lol:
Post by RustyPW » Mon Apr 08, 2019 8:35 pm
:poke:
:thppt: :lol:
Damn..........you're thin skinned. :poke:
Post by DamageWagon » Mon Apr 08, 2019 8:44 pm
Every gen is the ‘best Gen’ when you don’t own a truck that isn’t from the current gen
Post by OffroadTreks » Mon Apr 08, 2019 9:07 pm
:poke:
:thppt: :lol:
Nah bro, it's the internet. This is all fun.
But it's still a turd gen. :excited:
Post by RustyPW » Mon Apr 08, 2019 10:29 pm
:poke:
:thppt: :lol:
yea.......and I don't have all the nannies that the 4G has to baby sit you.
Post by PWJouster » Tue Apr 09, 2019 10:49 am
i actually dont have any babysitters, which is why i said, because it may be the last gen to that we can effectively bypass the computer without being disabled, codes, or locked out.
truth be told, the front camera ive added (Garmin GPS/Bluetooth) helps me see exactly what my bumper is creeping into (mounted over the A)
i would not purchase a Regular cab so makes no difference to me.
4th gen 'soon to be' Best gen
Post by OffroadTreks » Tue Apr 09, 2019 11:00 am
Yeah, but my babysitter is hot. I slide right up in there daily. 8-)
Canbus programming is a pain. But it can be done with some simple electronics. My BMS is canbus and I setup a raspberry pi to pull info out of it. And I know you can do some things with.... crap I sat here for 5 minutes trying to think of what it's called. I guess I'm getting old. So... what was I talking about?
¯\_(ツ)_/¯
2017PW
Post by 2017PW » Fri Apr 12, 2019 3:37 pm
I finally got the kit installed today. Pretty straight forward once you get the wiring laid out and understand where it goes and how to run it. It was a quicker install than I expected.
Once I had everything “roughed” in, I tested the lockers and everything worked as it should. I ran into a problem when I went to mount the module box. I think it’s because I used an impact drill to secure the self tapping screws to the inner fender. Once I had it mounted, but before I put the air filter box back in I tried the lockers and it just buzzed. I took the module box back out and as indicated in the directions I removed the module cover (4 small screws) and turned the dial on the relays. After several times of adjustment I got it working again. This time, I used a screwdriver to secure the module box to the inner fender and had no problems. I think the vibration from the impact drill caused an issue the first time with the relays.
Once I mounted the module box I tested the lockers and everything worked again. I then put everything back together and zip tied the cables to existing mounts on the truck. The finished product is very clean and I think most people would have no idea that it wasn’t factory wiring.
I’m excited to actually try the kit off-roading, but was able to try it on a dirt road. The lockers locked immediately and it was nice to engage the rear locker in 2hi.
Thanks again Retired BLM Rig!
Post by olyelr » Fri Apr 12, 2019 4:17 pm
:rockon:
Post by PWJouster » Mon Apr 15, 2019 9:09 am
Just as a tale for others.
Dont be like me and assume the settings are correct. Every truck is different, and the Design however perfect, can not anticipate any abnormalities in each and every Truck. Rough in The harness and test the system. make any necessary adjustments, and assume you may need to access them in the future. Do not permanently or artificially make it any more difficult to access.
I can only assume that many will need adjustments during install, or shortly there after.
I have Relocated the box and secured it to the S and B intake in clear view. This is probably not advisable for a truck that visits dealers often, as the box to a "trained" eye is not typical under a ram hood.
The mounting Location described in the instructions is the most ideal unassuming and discrete way to unlock your true potential!
Buck316
Post by Buck316 » Mon Apr 15, 2019 1:14 pm
Got my locker bypass last week in the mail cant wait to get it installed! Thx BLM rig!
Sent from my SM-N960W using Tapatalk
IDIOTCARL
Post by IDIOTCARL » Mon Apr 15, 2019 9:33 pm
Hey all,
Wanted to give my feedback on the two systems offered.
First of all these kits are of high quality, are professionally put together, and just top notch as hell.
Start to finish it was a painless process... my turn came up, i paid, i received both the locker bypass and nannie kill system within the week.
Once i got started the kit was fully prepped and ready to go, everything you need.
I did have a couple of questions and i received answers right away..again huge 👍.
Installation was easy and it looks factory. I tested the system and it worked like a charm.
If your on the fence about the system or the cost, GET OFF THE FENCE AND START WHEELING. These set-ups are the bees knees.
Retired blm, you da man!
I find myself using the nannie kill alot when just hopping about on dirt fire roads and the 2wd drive locker option is awesome when pulling a dry hill or a boat at the launch.
Thanks for the awesome system you figured out, R. BLM.
(Side note: on a 2014 at least, the passenger inner fender there is a 1/4 twenty threaded factory stud, it works perfect for mounting the control box for the locker bypass. Its between the firewall and the air box. Takes some riggermaroe to get the box in position, but its a solid, safe spot to mount.)
